This is probably a fine point, and may not matter either way, but I'd just like to know which way is correct, for future reference.
The pic is part of the schematic for my DSO150 Shell kit scope. On the right, you will see analog power (VDDA) and analog ground (VSSA), which I assume power the ADC conversion process. Then on the upper left pin 10 is the input point for the signal being converted from A to D (ADCIN). Not shown, but ADCIN connects through a 150-ohm resistor to the output of an opamp buffer on the analog board.
My question concerns the two 100K resistors on the ADCIN input. I'm not sure why they are there, but they are connected to the digital power and ground rails, and I wonder if they should instead be connected to analog power and analog ground.
It seems the existing setup might introduce digital noise into the ADCIN signal. On the other hand, perhaps connecting the resistors to the analog rails might result in changes on ADCIN contaminating them via the resistors.
What's the right way to look at this?
This company produces a variety of scopes, and based on the published schematics, they're all done this way. So maybe it's correct.
