Author Topic: wanna know torgue of this kind of potentiometers !  (Read 1250 times)
Offline ammjyTopic starter
  • Country: kr
« on: February 23, 2018, 06:34:28 pm »
Hello, guys ! ) always thanks you for help.
http://www.dwengo.org/sites/default/files/tutorials/potentiometer.jpg
i really want know torgue of this kind of potentiometer !
for example, bourns company potentiometer have torgue value in specifications.
but, i can't find about it for chinese cheap potentiometers !.
please, let me know !
Online Benta
Re: wanna know torgue of this kind of potentiometers !
« Reply #1 on: February 23, 2018, 07:23:15 pm »
I'm really surprised! Cheap Chinese potentiometers are otherwise always supported by excellent data sheets.
[/sarcasm]
The following users thanked this post: rob.manderson
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #2 on: February 23, 2018, 07:33:43 pm »
I guess you are SOL unless being able to measure it yourself though variance might be very high for these cheap pots.
If actuating force is of great importance in your design, why not stick to quality parts that give you reliable figures to work with? If I remember correctly the rotational torque values that Bournes provides are also quite fuzzy and give you a kind of best case / worst case data.
He’s like a trained ape. Without the training.
  • Country: kr
« Reply #3 on: February 23, 2018, 08:45:07 pm »
Thanks Reply !
the problem is my cheap potentiometer don't have model number on the body... but, body is almost same with linked photo.
« Last Edit: February 23, 2018, 08:54:35 pm by ammjy »
  • Country: kr
« Reply #4 on: February 23, 2018, 08:48:42 pm »
Thanks Reply !
i will buy Bourns potentiometer. but before buy, if i know torque of my potentiometer, i can understand which torque have which rotation resistance.
because, i should use potentiometer for sensing degree for my wings. so, for wing move it self, should use low torque.
my cheap potentiometer torque is little bit strong. so if i know torque of this, i can predict torque with values.
« Last Edit: February 23, 2018, 08:51:23 pm by ammjy »
Offline janoc
« Reply #5 on: February 23, 2018, 09:23:12 pm »
Thanks Reply !
Um, if your design depends on the mechanical resistance of the pot, you are doing it wrong, IMO. The resistance/force varies a lot even on good quality pots from the same series. Moreover, it will change over time as the pot wears, gets dirty, even with temperature (grease and any seals get stiffer when cold). Also pots are not great as position sensors if you want the system to be reliable.
You may want to reconsider your position sensing arrangement - e.g. an optical encoder + encoder disk could work a whole lot better than a pot. Or maybe even capacitive sensor could be used - depends on what exactly are you trying to do.
  • Country: kr
« Reply #6 on: February 23, 2018, 09:35:30 pm »
Thanks you, Mr. Janoc !
i really got your point !
yes... i agree to your advise...
Online langwadt
« Reply #7 on: February 23, 2018, 09:50:18 pm »
Thanks Reply !
or https://www.digikey.com/en/product-highlight/a/akm-semi/ak7451-magnetic-angle-sensor
  • Country: kr
« Reply #8 on: February 23, 2018, 09:56:27 pm »
Thanks you reply, Mr. Lengwadt !
