I'm a bit bored so I built this circuit quickly.
It uses an old school BF981 dual gate N channel depletion mode MOSFET transistor which is probably older than most forum users...
By tying the two gates together it effectively becomes the circuit in figure 1c in the assignment. I used a 1k resistor in the drain and something 'big' in the gate (220k ohm?)
The supply is 12V and it runs at about 6mA drain current. See below for the crudely built circuit and the waveforms on my scope. It gives a reasonable amount of voltage gain and is fairly linear. Basically, this circuit in figure 1c would have been an exam question in the 1970s or maybe the 1980s.
I'd probably be asking the tutor where I was supposed to buy a suitable device in 2014 because I doubt there will be much choice especially if you want a device that biases with just a few mA at 0V Vgs.
you are still assuming the course was going to teach me all you know, like i said, the sum total on mosfets and mosfet amplifiers was 3 A4 pages - with big diagrams.
I'm really just addressing your (incorrect) claim that the FET circuit in Task 1(3)c is somehow 'not' a proper amplifier circuit. Your claim that the amplifier circuit in fig 5.5 is drawn incorrectly seems to be the basis of your rather angry video on Youtube.
In reality I think you need to admit your assessment of the circuit was incorrect and that it is indeed a valid amplifier circuit because it shows an old school N channel D MOSFET. You got confusing results in your youtube video because you used an E MOSFET instead. This device has a different circuit symbol to the D MOSFET device shown in the assignment.
However, I can sympathise with your error here because I think a lot of modern students will fall into the same trap as yourself. But your course tutor might have been a bit offended by your video. Maybe you should take it down or produce a new version?
I suspect that the course material is based on old material and the reason that you didn't get supplied with the (effectively obsolete) FET in question is because they are so hard to find in 2014
Back when I was a student in the 1980s these devices were sometimes (casually) called single gate IGFETs but even then they were going obsolete in favour of the dual gate flavour of the device. So strapping gate 1 and gate 2 together was a common workaround even in those days if you wanted a small single gate D MOS FET which had a drain current of a few mA at 0V Vgs bias.
So maybe the fact these parts are hard to source in 2014 is the reason why they ask you to describe the operation of the circuit rather than directly instruct you to build it. If this course material dates back a few decades then maybe there was a time when they supplied you with the FET?
But the bottom line is that this old school D MOSFET is the simplest to understand because it can operate with 0V bias and still produce a reasonably linear signal.
Therefore, the sample answer given by IanB back in post #24 would probably have achieved high/full marks. Some people write books on these devices but I think IanB tried to give the 'expected' answer for high/full marks in your course
