"assuming" the OP claim is valid even though he didnt provide any hard proof, esp lecture content and lecturer/tutor proficiency.... either way anyway, as someone said, mission failed or directive unacomplished. its about putting the ego aside and play with the rest. there are more than skills and knowledges, things like humble, respect, willing to ask and discuss politely or simply shut up no matter how foolish the person you are facing at, esp your tutor where your fate is lying on him. now dont get me wrong i wont encourage but licking either, there are people who want to make money for a living, there are people who want the scroll for a better place, in the end both will get win win situation. if you think its a fraud? then dont do it, you get the scroll. you explained to them but they didnt listen, then leave, you get the scroll. ego aside, you get the scroll, mission accomplished, directive accomplished, otherwise its a failure no matter what mr anakin says.
back to the question, i'm nearly went mental to find amp circuit in "task 1 c", with higher level of concentration then i found its actually "task 1 question 3 c", i dont see any problem, the directive is to explain the circuit input and output result in plain verbal tone level, if its not working, then explain why (or simply say i dont know why as most normal kids will say anyway) in plain verbal tone level, if you have better suggestion (to prove your proficiency) then please do so in plain verbal tone level, thats it, whining is not required. that shows your profesionalism and to avoid being seen as a "foolish whiner" no matter how briliant you are (or think you are).
and think my last point is.... expecting an "engineer" or "a professor" to know how the "dirt bolt and nut is" or "dave should be able to fix any tv because he is an engineer" is a foolish thought no offense its just plain truth. just because you have not living the life doesnt necessarily put you in an "absolute truth" position. i dont think i want to explain further why, others have tried.
