That exact version is probably unobtainium. If there's a bad component, you'll probably have to replace the entire switchplate at the very least. Save the good parts as spares for other locations.
But the 3-in-1 combination concept is still available. See here for some good general info and an expensive source of a similar style: https://www.kyleswitchplates.com/despard-switches-outlets/
Also search your favorite auction sites for "despard switch" and "despard outlet".
Thanks!
Beware...insulation on wiring that old may be total crap once you disturb it, so the job may get bigger once you start. In places where you have the wall space for a larger box, you might consider updating to modern parts instead.
Yup, I learned that already from other jobs there.
That paint-encrusted faceplate was enough to stop me.
The switches are OK but no longer have detents, it's the plug that is useless. Nothing modern fits, and it makes bad contact in any case. Looks like there is a grounded outlet available but like you said, once I get behind the faceplate, everything would go sideways!
The problem is the kitchen is a 1950s or 1940s design. There are no other outlets on the counter, except for the courtesy plug on the stove, but that's only rated for 5 amps.
The switches control counter lighting and the range hood fan.
You won't find that anywhere else, I think, except other equally old non-updated houses.
