What is this connector called? The one with one pin plugged so that you can not plug it in the wrong direction.
Where can I buy housings for this connector? Or where can I buy pin "plugs" for a 2.0mm Milli-Grid connector?
I do not want to pay extra shipping cost, so it will be better if I can get them from Mouser.
As a reference, the connector housing I'm using is Mouser 51110-1050. I want one with a corner hold plugged, or a plug that I can permanently plug into its corner hole.
The connector in this picture has 2.54mm pitch, I need 2.0mm pitch.
Thanks in advance for all inputs.
