Author Topic: What kind of antenna is this.  (Read 2008 times)
Offline mrpacketheadTopic starter
  • D Size Cell
« on: September 26, 2017, 03:15:36 am »
Can any one tell me what kind of antennas these are?   They are for 900Mhz..
Offline T3sl4co1l
    • Seven Transistor Labs
Re: What kind of antenna is this.
« Reply #1 on: September 26, 2017, 03:39:55 am »
Seven Transistor Labs, LLC
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #2 on: September 26, 2017, 04:45:04 am »
Don't mess with an Electronics Engineer, it Megahertz!
Offline hcglitte
« Reply #3 on: September 26, 2017, 07:35:19 am »
To me they look like end fed half wave dipole antennas.
Offline LukeW
« Reply #4 on: September 26, 2017, 11:27:56 am »
Are the wider cylindrical pieces 80mm long, or so?
It just looks like a good old half-wave dipole.
Offline cdev
« Reply #5 on: September 29, 2017, 05:56:24 pm »
I think it may be a collinear but because the gaps between the wider sleeves, are not 100% consistent with what I would expect, its hard for me to say 100% unless you can give us images with more detail.
The closer images look more like sleeve dipoles, the ones in the upper rear part of the picture are more likely collinear. Its probably collinear.
« Last Edit: September 29, 2017, 06:03:53 pm by cdev »
  • D Size Cell
« Reply #6 on: September 29, 2017, 06:07:23 pm »
Im guessing i'm going to have to pull apart the antennas i have to find out for real! these pics are taken from a factory in china...
Online PA0PBZ
« Reply #7 on: September 29, 2017, 06:29:30 pm »
Looks like stacked dipoles, the bigger parts do seem to have a hole or even a circle around them in the middle.
Offline cdev
« Reply #8 on: September 29, 2017, 06:40:53 pm »
This is a coaxial collinear antenna, you can see the difference-
http://www.nodomainname.co.uk/Omnicolinear/2-4collinear.htm
Its likely possible to make one with sleeves, but its not so clear to me yet how they'd handle phasing...
does anybody know?
