Author Topic: What to do with transformer  (Read 3131 times)
Offline mscreationsTopic starter
« on: August 22, 2014, 04:05:31 am »
So I was given a 36v electric cart charger that doesn't work. I'm pretty sure it had something to do with being crushed by a forklift.  :palm:
I pulled the transformer out to check out what kind of voltage taps it had. On the secondary side, there were 2 large windings and one winding around that with both leads going to a capacitor (6mF). On the two large windings I'm reading 32v open circuit and without the capacitor attached to the winding. The voltage across the capacitor's winding is 480 VAC! If I leave the capacitor attached to that winding the other voltages jump to 44 VAC (would love to have someone point me to a reference as to why that occurs. I'm assuming it has something to do with a phase shift or something. I've only minimally started learning about AC.)
So... My question is this... what should I do with this transformer? I was thinking about using it for the transformer for a power supply, but it may be a bit overkill for that. Although having 480 VAC would be neat for certain projects I'd imagine.  >:D
Offline Richard Crowley
  • KJ7YLK
Re: What to do with transformer
« Reply #1 on: August 22, 2014, 04:31:15 am »
Sounds like it may be a "ferroresonant transformer". They were popular for higher-current "self-regulating" applications, perhaps including your charger.
http://www.allaboutcircuits.com/vol_2/chpt_9/6.html
« Reply #2 on: August 22, 2014, 04:38:23 am »
Yes a ferroresonant unit. You can use it as is, but be aware that it essentially is a close to constant power transformer, giving a reasonably constant current output up to the open circuit voltage. You will also find that it is close to constant power draw on the input side as well, as it tends to run warm. As a battery charger for wet lead acid cells it is perfect, as it charges at a high current till the battery is close to full, then it keeps the voltage constant till the cell is just entering the hydrogen generating region when fully charged. This stirs the electrolyte and means the cells last a long time even in this high current use.
You can knock out the magnetic shunts and remove the capacitor and then it will be usable as a regular transformer.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 22, 2014, 08:30:09 am »
Yup!
Nope: that would be closer to true if it were a shunted (split) transformer without the resonant winding.  But that's more like constant impedance, not constant power.  AFAIK, there's no such thing as a constant power transformer, not without some fancy mag amp trickery anyway.
...Maybe you typed 'power' when you were thinking 'voltage'?
In any case, what's going on is, the secondary side is held on the verge of magnetic saturation.  Flux is volts times time, so as long as the frequency stays constant, the average voltage must also be limited.  The shunts provide some isolation (loose coupling) between primary and secondary, and the capacitor winding is designed with a particular inductance (the secondary side may be gapped, I'm not sure) so that it resonates at line frequency.  Normally, when something is resonant (at a high Q factor), the voltage and current just keep building up until balanced by losses, but in this case, the amplitude causes saturation first.  This reduces the average inductance, raising the resonant frequency slightly above line frequency.  Depending on load (i.e., how much excess voltage gets shunted by saturation), the amount of shift varies; it should be designed so that, between open circuit and rated load, and with an input of +/-10%, the output voltage remains within a 5% margin, or something like that.
The capacitor also helps smooth the waveform; a saturating sine wave looks like it's being shorted out on the tail (imagine a TRIAC phase control waveform, but instead of passing voltage for some fraction of the tail of the cycle, it gets shunted instead), but the capacitor forces the voltage up a little bit.  The waveform will still be lopsided, so if you need really clean AC, some harmonic filtering might be desirable.  For DC rectifiers, it's no problem of course.
Because of the magnetic shunts, the primary side power factor is quite poor: inductive.  (It won't be especially distorted, though, even with a rectifier load.)  If you want to minimize current draw, you could add some PFC capacitors.  But beware they won't be friendly to switch contacts...
Seven Transistor Labs, LLC
« Reply #4 on: August 22, 2014, 05:44:03 pm »
I have some ferroresonant constant voltage transformers, they make pretty good room heaters when you power them, and draw a pretty high current on the input that is almost independent of the load applied. As it is a dual conversion UPS I added an extra fan just to keep the unit cooler than convection alone does. When this one does what they all do eventually ( or at least this manufacturers units almost always do this) and blows up 30 2N3773 transistors from faulty drive I will scrap it for the copper inside. About 20kg of copper alone in the transformers.
