Probably just a big inductor (choke), or at best a double balanced choke. The electrolytic forms a filter.
You won't see much of a 'waveform' unless you have a noisy car - it'll be difficult to 'scope both the input and output simultaneously in a meaningful way, but if you could, you'd hopefully see higher frequency noise on the output would be attenuated significantly.
