I'm not sure they are actually that short. If you rotate the picture by 45' they look about the same span as a normal meter movement. Linearity starts to suffer once you get much past 90'. I've seen ~270' meters used in similar control room applications, not sure how how they work though.
The meters shown do have visual impact though, maybe easier to spot deviations in an array.
