A lot of (all?) UHF dials were continuous tuned (i.e., the knob turned a variable capacitor and/or inductor), and had notches just for convenience -- it was pure coincidence that the notches lined up with real channels, but most of the time it was pretty close anyway, and a little fine adjustment (the fine adjust covered about a channel's span, so you could always hit a channel even if you got "unlucky") would get you there.
I also remember having a B&W TV that had a UHF dial out to ~80. UHF was redefined in the 80s to have 70 channels, and the rest was reallocated for cellphone use -- the earliest analog cell phones. You could see dot and line patterns, and hear sizzling or buzzing, or sometimes garbled voice, up there...
The same tuning mechanism wasn't suitable for the wide frequency span of VHF channels -- in particular, VHF isn't a single band, but is several, separated by gaps. It made more sense to use presets -- the turret tuners mentioned above.
You would also have separate antenna inputs, for similar reasons. Also, I don't think wideband antennas (anything that would be flat, as in, within 20dB kind of flat) ever caught on, probably because of material and manufacture expense, and bulk. So they were always adjustable in some way. Or people just used coat hangers, which honestly will do just as well after some lucky adjustments to a given channel.
When digital tuners took over, a PLL handled all the frequency control with exact precision, and all that was needed was a tuner with a wide range, a high 1st IF to match, and a bit of brain to set the control voltage. TV tuners make an excellent starting point for a quite reasonable spectrum analyzer.
