Hi!
I wish just check if my thinking is ok.
I have to power on 7 car bulbs which have 21W/pcs through 7 separated FET's.
The car bulb on 12V is actually using 1.7A current consumption.
So, the main problem is the heat what I have to get cool as possible, because the housing
of the device should be water proof and filled with some sort of silicon.
I made some test's with two FET's.
1. IRF3205
2. IRF510
Each other meat my requirement for one bulb/FET.
When I tested the IRF3205 with Vg=10V and the bulb was attached on the FET 24H the FET
was on ambient temperature, what means for me cool.
When I made the same test with the IRF510, but with a very short time, compared to the first testing(10min),
the FET was around 80C.
What means for me hot.
In both testing method I monitored the the current, which was flow through the bulb,
and it was 1.7A.
For me that means the FET was properly in an ON state.
Question:
Why was the IRF510 so hot with the same bulb and same setup?
If I put 7 IRF510 in the same box and fill it with silicon, I assume it would be
very hot after 10-15H of working, mean in an ON stage.
What I think:
The "problem" with the IRF510 is the Rds(on)=0.54
but on the IRF3205 the Rds(on)=0.008
Am I right?
Thanks in advance.
My best regards.
