In case you have the Min or something Nominal it can work with 3.3 V logic, but what about Max at 4.0V? The Vgs(th) is the point where the MOSFET will start to conduct, similar to when the water starts dripping from the tap. As the Vgs voltage is increased, the MOSFET conducts better, similar to a higher rate of water flow from the tap.
So does this mean only use it at 3.3v, do NOT use it with 5v logic ?
2. The capacitive parameters (Ciss, Coss etc) a little bit further down are hinting about possible issues with switching frequency for the PWM. Let's assume that the capacitor is a bucket that you want to fill with water from a hose. The current that the Arduino board can source is equal to the water flow in that hose and that is quite limited (a few milliamps). With a low rate of water flow it will take some time to fill up that bucket and each PWM period must be able to completely fill the bucket.
what capacitor is this? also:
3. Use very low frequency (several kiloherts) if you do not have a proper gate driver.
im using the sketch detailed in the 3rd "reference" link,
can you give me some pointers about the PWM frequency ? im not sure about this
1. Use a mosfet with vgsth lower than 1V.
2. As stated before, use 1 high current mosfet instead of 2.
would I be able to use one of the ones im using here?
Ive just spent $20 on 4 of them at expensive-car err, jaycar so i would prefer to use them, i think if im reading the datasheet correctly they handle 100A + ??
as far as i know the MAX I will be using is 12.
I spotted another thing that will inhibit this circuit from working. You have diodes from the Arduino PWM to the gate pins on the MOSFETs. You will only be able to turn the MOSFETs on, but the diodes will block any attempt to discharge the gates. The diodes also have a forward voltage drop that will remove at least 0.5 V of the 3.3 V.
Replace the diodes from the Arduino PWM to the MOSFETs with resistors of 100-200 ohms (100, 120, 150, 180, 220...) something. Also add a 10k resistor from the Arduino PWM down to GND to make sure that the gates are discharged if the Arduino will reset and have a high impedance output.
ooh thank you, this completely skipped my mind
its small like 1A isnt it!?
shoot,
this is gonna sound stupid, but do resistors have a current limit...?
(I presume they do for obvious reasons, but like, would cheap jaycar [radioshack?] ones be fine in this case...?
In addition to what's already been said about the FET's, you are running all the power for your strips through the two diodes.
That's fine - but keep in mind the diodes have a max amp rating and will dissipate power, so your strips can't be too long.
Right! as mentioned above I didn't even think of this...
ill be rid of the diodes there, I only used them to get over the other wire without as much risk of shorting hahaa
Thanks for helping me guys
Pretty new to this stuff but keen to learn!
also, sorry how messy this reply is!
also also,
Its perfectly fine to hook up the two PSUs in parallel right?
http://www.ebay.com.au/itm/261740183173
