Hi again all!
Just thought I'd update everybody on the progress of this project. I've finally chosen a connector. There's some IP65 connectors available that are targeted at these types of LED strips, rated to 10A. They are these:
They can be got for £10 for a pack of 10 pairs with 20cm cables on each - perfect! I will buy 2 sets of these so I can make my own extensions if required. I'll then obviously need 2 more pairs to make the initial cable run. (A female cord out my controller box secured with a grip grommet, then the initial cable run)
I've decided to go for the snaked approach to interconnecting so a cable on each end of the tube - means I can daisy chain them neatly, or hang them without the need for the extensions under normal circumstances.
Control will be via my Enttec Open DMX unit, controlled from JINX! on my laptop with the DMX to WS2811 driver I have.
The power will come from one of those metal chassis PSU's like this:
Via an IEC like this:
I just need a bit more advice. I was going to colour code all my spades, so blue for N, red for L and Yellow for GND/EARTH. But obviously the connector colours usually indicate the gauge of wire used in them. So how would you go about this? Use all the same colour spades with different colour wire?
Also, I've never used or seen up close one of those PSU's, so what size spade forks/disconnects should I be using?
Any other advice or pointers you may have?
