Author Topic: Yet another fast edge pulse generator  (Read 172093 times)
Online HighVoltage
Re: Yet another fast edge pulse generator
« Reply #100 on: July 22, 2017, 07:24:24 pm »
Your pulse generator arrived today in Germany, thanks for the fast shipment.
One question.
When I run your software on my PC, (Win7), I get weird selection numbers for the voltage selection.
Is it the software or anything I am missing?
See attachments
Offline Leo BodnarTopic starter
« Reply #101 on: July 22, 2017, 07:28:34 pm »
One question.
See attachments
It looks like a decimal dot/comma confusion.
Temporary bugfix: for now assume it is in microvolts :D
I will try to change my locale and see if I can replicate and fix this.
Leo
Online Berni
  • Country: si
« Reply #102 on: July 22, 2017, 07:44:34 pm »
Aww so it doesn't have a secret 2kV output range in select European places? Would be pretty impressive with that rise time. ;D
I'm on vacation so Il know if I got mine once I get back home.
Offline rx8pilot
« Reply #103 on: July 22, 2017, 08:50:38 pm »
Today mine arrived. I guess my TDS580 wins the prize for the most ringing display
It will be interesting to learn what contributes to the different responses seen on various scopes.
Online HighVoltage
« Reply #104 on: July 22, 2017, 09:21:02 pm »
OK, I will wait for you to figure out the decimal point.
Here are my measurements on my slowest scope.
This is an Agilent branded DSO-X-2002A, 70 MHz
« Last Edit: July 23, 2017, 12:07:15 pm by HighVoltage »
Online HighVoltage
« Reply #105 on: July 23, 2017, 11:50:17 am »
OK, tested on my Agilent MSO-X-3104A, 1 GHz scope
Rise time 440 ps
The software is running on an older XP
This time I get good numbers like 1000 but if I select a different number, like 1400, the signal is not changing at all.
« Last Edit: July 23, 2017, 12:09:50 pm by HighVoltage »
Online HighVoltage
« Reply #106 on: July 23, 2017, 12:06:06 pm »
Now tested on my Agilent MSO 7045B 500 MHz scope
Rise Time 1.03 ns
No overshoot, may be the scope is too slow!
This time Software running on a Lenovo Laptop with Win7 Pro and all works as expected
« Last Edit: July 23, 2017, 12:07:52 pm by HighVoltage »
« Reply #107 on: July 23, 2017, 12:08:34 pm »
Rise Time 1.03 ns
Don't forget to terminate input to 50R if you want fastest and cleanest risetime.
Leo
Online HighVoltage
« Reply #108 on: July 23, 2017, 12:21:24 pm »
Now my last scope for this test, a Keysight MSO-X-6004A, 6 GHz, 50 Ohm
Rise time is 88 ps
Online HighVoltage
« Reply #109 on: July 23, 2017, 12:43:57 pm »
Rise Time 1.03 ns
Leo
You are right, I forgot the 50 Ohm setting.
Here again the same scope, 50 Ohm turned ON
Rise time 630 ps
Online HighVoltage
« Reply #110 on: July 23, 2017, 12:52:31 pm »
Just for fun I tested your pulse generator on a 20 year old Fluke PM3394B, 200 MHz
50 Ohm input
1.84 ns rise time
« Reply #111 on: July 23, 2017, 01:07:19 pm »
Rise time is 88 ps
Assuming total system risetime Tsystem2 = Tscope2 + Tpulser2
It checks out reasonably well:
Tsystem = 88ps, Tpulser = 50ps
From there Tscope = 72ps
MSO-X-6004A specification lists 75ps risetime.
Pleasant UI on that Fluke.
« Last Edit: July 23, 2017, 01:14:20 pm by Leo Bodnar »
Online Berni
  • Country: si
« Reply #112 on: July 23, 2017, 04:45:32 pm »
Neat to see some CROs join in even if they are hybrids.
Oh and do all your scopes have names like that?
Offline capt bullshot
« Reply #113 on: July 24, 2017, 12:59:54 pm »
Found some time and tried the Wavewhatever MX104 @work
Online HighVoltage
« Reply #114 on: July 24, 2017, 04:30:26 pm »
Only on my high voltage bench, Scope-1 to Scope-6 because I am switching the RS232 connection manually to one PC input for data acquisition.
Offline WastelandTek
« Reply #115 on: July 24, 2017, 04:48:12 pm »
now that is pretty
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Online H.O
« Reply #116 on: July 24, 2017, 06:23:48 pm »
Received mine today, thank you Leo!
Here's my Rigol DS4000 series:
Offline Gixy
« Reply #117 on: July 25, 2017, 10:18:01 am »
Hi Leo,
News from order 20535?
« Reply #118 on: July 25, 2017, 11:06:46 am »
Hi Leo,
Hi Denis,
Shipped on the 20th of July with Airmail.
Thanks
Leo
Offline TheAmmoniacal
  • Country: no
« Reply #119 on: July 25, 2017, 11:22:28 am »
Mine has arrived, all good. Thanks.
Will have a look at the output on my scopes when I get home from vacation.
Offline Gixy
« Reply #120 on: July 25, 2017, 11:53:45 am »
Should be there today hopefully. Thks Leo
« Reply #121 on: July 25, 2017, 01:38:58 pm »
Today we had a demo of some Tek stuff here.
I managed to get screenshots from the new MSO58 2GHz flagship. This has a frickin large screen - with lots of space for ringing. I believe my TDS580 (see somewhere above) isn't that bad in terms of Tek-ringing. I do still like more the clean edge of the LeCroy.
(first two pictures)
Then there was the fabulous fiber optic isolated probe with 500MHz bandwith - the signal looks a bit different (third picture)
Fforgot to adjust the timebase for the rise time display to work, too many people around distracting me.
Online HighVoltage
« Reply #122 on: July 25, 2017, 02:40:39 pm »
Do I see this right, the Tektronix 2GHz MSO58 has 213 ps rise time with this 50ps pulse generator ?
« Reply #123 on: July 25, 2017, 04:18:11 pm »
Thtat's what I've seen. The specification (taken from Tek website) is:
Bandwidth (calculated rise time)   350 MHz (1,15 ns), 500 MHz (800 ps), 1 GHz (400 ps), 2 GHz (225 ps)
They must have different frontends for the 2GHz models, since many specs are different between 2GHz and less than 2GHz models.
Offline Gixy
« Reply #124 on: July 25, 2017, 08:02:31 pm »
Hi Leo,
Received mine today as hoped.
Tested on Rigol MSO2302A (300MHz, upgraded...) and Tektronix 2445A (150 MHz). Results as awaited, perfect!
Rigol MSO2302A (300MHz): 1.050ns (rise), 1.090ns (fall)
Tektronix 2445A (150 MHz): 2,00ns (rise), 2,10ns (fall)
The software rose an error when launched: Error '13' uncompatible type (Windows 10).
Thanks again.
