Author Topic: Yet another fast edge pulse generator  (Read 69051 times)
soren, tford and 1 Guest are viewing this topic.
Offline Jwalling
  • This is work?
Re: Yet another fast edge pulse generator
« Reply #275 on: November 27, 2017, 11:30:55 pm »
Got mine a week or so ago. Build quality is excellent and it works great!
Results:
Agilent   54832D   1000         331
Tektronix   TDS784A   1000         270
Tektronix   TDS3052     500           620
Tektronix   TDS694C   3000         106
Agilent   54855A   6000         68
Jay
System error. Strike any user to continue.
Offline HighVoltage
« Reply #276 on: November 28, 2017, 02:59:45 am »
Results:
I had to look up the Agilent model number 54855A.
It is a real-time scope with a bandwidth of  7 GHz?
Nice result of 68 ps!
Offline grumpydoc
« Reply #277 on: November 29, 2017, 12:12:46 am »
Keysight DSO1024A
2.48ns seems borderline slow for a 200MHz 'scope - I guess it comes in as 0.5/BW and the DSO1024A drops to 500Ms/s when all channels are in use so it probably has a pretty tight filter on the front end.
Offline Howardlong
« Reply #278 on: November 29, 2017, 12:19:45 am »
Keysight DSO1024A
Is the scope 50-ohm terminated?
Offline grumpydoc
« Reply #279 on: November 29, 2017, 12:33:31 am »
Keysight DSO1024A
No and I suspect that might have something to do with the response.
Disappointingly though for a 200MHz 'scope the DSO1024A has no built in 50 ohm termination.
However the path from Leo's pulser to the front end is so short that I suspect putting any external termination in will make things worse, not better.
I have a home made 50 ohm pass-through somewhere - I might dig it out and see if my suspicion is correct.
Offline grumpydoc
« Reply #280 on: November 29, 2017, 08:43:40 am »
I have a home made 50 ohm pass-through somewhere - I might dig it out.....
OK, so, makes a huge difference! 1.24ns
Trying to get my head around the interaction of the termination resistance and the input capacitance of the 'scope (18pf, so about 8.8 ohms at a GHz).
Fair bit of ringing though, similar with a T piece and the usual crappy 50 ohm terminator.
The data sheet gives 1.8ns but that is just a calculated figure (using 0.35/BW)
Offline WastelandTek
« Reply #281 on: December 02, 2017, 03:52:22 pm »
hey Leo
Are you thinking the design iterations are pretty much done now?
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Offline Leo Bodnar
« Reply #282 on: December 02, 2017, 08:44:54 pm »
hey Leo
Hiya,
Pretty much so.
Pulser performance went beyond what I originally wanted it to do. It even has an LED now.
Cheers
Leo
« Reply #283 on: December 03, 2017, 04:33:59 am »
hey Leo
Hiya,
Pretty much so.
Cheers
Leo
right on, I think I am deserving a Christmas present  ;)
Offline FriedLogic
« Reply #284 on: December 03, 2017, 09:53:32 am »
It's not that the performance of the BNC connector is unacceptable in itself, it's that the whole idea behind a fast pulser is to test fast hardware.  Having to use a BNC-to-SMA adapter with a fast DUT is certainly worse than having to use an SMA-to-BNC adapter with a slower DUT.
I accept your reasoning but I had problems with people not being able to find suitable USB cable locally.
Looks like I'd have to make and stock SMA version as well at some point.
Leo
Has anyone come across any readily available good and cheap SMA(f) - BNC(m) adaptors? (not surplus expensive ones, but cheap when bought new)
The main problem with most of the cheap BNC adaptors and plugs that I've seen is that they are missing the raised flange around the end of the ground connection on the plug, so don't connect well with the socket. The plating on a lot of them does not help much either.
I've sometimes bent the contacts out a little so that they connect better, but that's certainly not ideal.
Offline Leo Bodnar
« Reply #285 on: December 03, 2017, 10:00:07 am »
I use these https://www.digikey.co.uk/products/en?keywords=314-1184-ND when testing the pulsers.
« Last Edit: December 03, 2017, 10:02:13 am by Leo Bodnar »
Offline Berni
  • Country: si
« Reply #286 on: December 04, 2017, 05:26:28 pm »
I would buy another one of these if a SMA version becomes available.
I would guess that most people would still prefer it to be BNC since that makes it a great scope speed testing tool. But with the sort of speeds this thing is going at makes the rated few GHz frequency on a BNC seam a bit lacking. While SMA on the other hand goes in to the low 10s of GHz and is pretty widespread so i'm sure anyone that dabbled with RF has some SMA cables and adapters laying around.
You can probably make the PCB compatible with both SMA and BNC, then just solder BNCs on most of them while leaving a few without connectors. That way you can make small quick runs of the SMA version, but if there is not enough interest you can still go ahead and put BNCs on those too. Guess it would make sense to make the SMA version a few dollars more expensive for the extra trouble.
Offline HighVoltage
« Reply #287 on: December 04, 2017, 09:22:22 pm »
Same here.
if you make the SMA version available, I will take one too.
« Reply #288 on: December 05, 2017, 12:44:05 pm »
OK Leo, order 23042 in
Thank you and have a good holiday!
Offline EEngo
« Reply #289 on: December 06, 2017, 07:55:03 am »
Leo, thank you very much, my order arrived today. :-+ :box:
the Lecroy DDA125 (aka LC684, 1.5GHz analog bandwith) was mentioned in your very first post with 295ps  :-//, here are some additional measurements (see attachments):
Channel A: 248 ps
Channel B: 245 ps
Channel C: 249 ps
Channel D: 241 ps
perhaps someone with access could update the list, some more scopes will hopefully follow tomorrow (HP54616B, HM2008,Rigol MSO2202)
Offline Leo Bodnar
« Reply #290 on: December 06, 2017, 08:15:48 am »
Thank you for your order, it has shipped today.
Channel A: 248ps
My pleasure!  That was the older pulser model based on ADCMP***, its design has changed since then.  Amplitude increased too.
Leo
Offline Converter
  • Country: ua
« Reply #291 on: December 07, 2017, 03:29:27 am »
Hello, Leo,
Order Number is: 23079
Please send the latest version of the design.
Sergey.
Offline EEngo
« Reply #292 on: December 07, 2017, 09:13:59 am »
another measurements (see attachments):
HP 54616B (500 MHz): 540 ps  :-+
Hameg HM2008 (200 MHz): 1,5 ns  :palm:
Rigol MSO2202 (200 MHz): 1,3 ns  ;)
cool project, thanks leo!  :-+
Offline Leo Bodnar
« Reply #293 on: December 08, 2017, 05:46:42 am »
You are welcome!
Thanks to everyone who ordered one.
All the orders have been shipped - usually within one working day from placing them.
Leo
Offline H.O
« Reply #294 on: December 08, 2017, 06:27:52 am »
The list has been updated, 94 entries this far.
Offline grumpydoc
« Reply #295 on: December 08, 2017, 07:52:36 pm »
The DSO1024A entry needs correcting to 1240ps. It turns out that termination does matter after all** :)
** In other news: Pope is Catholic etc.
Online richnormand
« Reply #296 on: December 09, 2017, 03:43:42 am »
Nice work H.O.
For the very fast systems (sampling scopes et al) you might have to note if the pulser is the early or the late version.
I would think that 40ps compared to 50ps  Tr will make a difference on a system with a 20ps risetime and such...
Offline H.O
« Reply #297 on: December 09, 2017, 04:08:15 am »
I'm sure it does but I can only put in the list what the user reports here, I unfortunately don't know which user has which version.
I usually have to Google scope sample rate and look at the attached photos/screenshots to figure out if internal/external/no termination has been used. When I don't know I leave that entry blank.
And, as you can see, for the very fast system the formula fails so the list is far from perfect.
I'll fix the DS1204A entry on the next round.
Online texaspyro
« Reply #298 on: December 09, 2017, 04:54:56 am »
My TDS3034->3054 hack and THS730A measurements were done terminated at 50 ohms.
Offline EEngo
« Reply #299 on: December 09, 2017, 08:31:41 pm »
thank you H.O.  :-+
all my measurements (DDA125, HP54616B, HM2008 and MSO2202) were done with internal 50 Ohm termination.
