Author Topic: Yet another resistance decade box  (Read 102381 times)
Offline JacquesBBB
Re: Yet another resistance decade box
« Reply #375 on: September 18, 2016, 02:31:12 am »
On One of the external holes, there is a pin that has been melted to hold firmly the board. Just cut the top part as close to the board you can ( i do it with a sharp wire side cutter).
Then press on the other side starting with the side with no pins. It should come now easily.
Do not break the pins. They will be useful to hold firmly the new board.
To put the new boards you need to be sure they are completely engaged on the pins. This needs some local pressure, they will snap nicely.
The following users thanked this post: anfang
Offline mrjoda
  • Country: sk
« Reply #376 on: September 18, 2016, 10:43:47 am »
check this. It is easy
https://youtu.be/6eoKMs7ws6U
The following users thanked this post: nuno, anfang
Offline nikifena
  • Country: bg
« Reply #377 on: September 21, 2016, 07:03:25 am »
Finally I finished my decade box.
The enclosure is made from 1mm sheet metal.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #378 on: September 21, 2016, 08:29:03 am »
Looks good! However, a couple of suggestions:
1) Connecting a metal box to one of the terminals might not be a good idea if you plan to use the box as a resistor substitute in a live circuit. IMHO either the box should be plastic with an internal shield or a metal with a separate connection to the case (this also would provide a nice reduction in the stray capacitance across the resistors stack if the box is grounded separately).
2) You've connected the case to the high resistance end of the stack. This way the parasitic capacitance and leakage across the high value resistance is maximized. It makes more sense to connect the case/screen to the lower resistance side if you don't have a separate connection for the case.
Cheers
Alex
Offline nikifena
  • Country: bg
« Reply #379 on: September 21, 2016, 03:08:31 pm »
Thanks for your suggestions Alex.
I will use for testing multimeters or if I need a variable resistor in some situations. The highest resistance values are to check the maximum measured capabilities of the DMM.
Yes, you are absolutely right! Grounding the isn't the best idea which I made ;) Unfortunately there is not enough space for a switch. I will leave the existing box as is, but I will keep in mind about your recommendations in the future :)
Thanks again ;)
Offline ivaylo
« Reply #380 on: September 22, 2016, 06:20:43 am »
Goog job, Niki! You didn't say how. you produced the metal box from the nice drawing you posted before...
Offline nikifena
  • Country: bg
« Reply #381 on: September 22, 2016, 09:44:00 am »
Thanks ivaylo. I'm making electronic devices and have good experiance with sheet metal work. I made all of my enclosures 3D and then I send the files for production in my town. The process is pretty simple - laser cut, bending on a press brake and finaly powder coating. Because this is only one enclosure I prefer to place labes made with transparency foil printed with laser printer, but silkscreen is much better for mass production and gives much higher quality looks :)
If you guys like this enclosure, I can make similar like this one in a small batch. The price will be about 12-15 Euro imho.
Offline Back2Volts
« Reply #382 on: September 22, 2016, 02:26:49 pm »
It looks great!   Did you actually build the box yourself ?
Offline nikifena
  • Country: bg
« Reply #383 on: September 22, 2016, 02:31:50 pm »
^ I made all necessary sketches for fabrication, but I use few local companies to produce the enclosures.
Offline ebclr
« Reply #384 on: November 03, 2017, 06:21:34 am »
I used a hot hair, on the plastic pin, instead of cutting, On this way I can remelt after change the board
Offline Leo Bodnar
« Reply #385 on: November 03, 2017, 10:47:27 am »
Where is the link where you buy these kits from?
Leo
Offline ebclr
« Reply #386 on: November 03, 2017, 10:56:05 am »
Isn't a kit , was a group buy for the PCB and resistors only, I'm not sure if still available
Offline Mr. Scram
  • Display aficionado
« Reply #387 on: November 03, 2017, 11:47:48 am »
It's open, right? So making more shouldn't be too much of an issue.
Offline Leo Bodnar
« Reply #388 on: November 03, 2017, 12:34:14 pm »
Somebody please make them and stick on their web shop.
This is impulsive buy thing-o like mints at the checkout, not something most people would spend a week reseraching and then wait for a month to arrive.
Please?
Offline ebclr
« Reply #389 on: November 03, 2017, 03:41:58 pm »
"It's open, right? So making more shouldn't be too much of an issue."
Make yourself
Offline Mr. Scram
« Reply #390 on: November 03, 2017, 04:22:17 pm »
Make yourself
Why so terse? I wasn't suggesting anyone specific should make them, I'm just saying making more is possible without having to steal the design.
Offline Fortran
« Reply #391 on: November 03, 2017, 04:43:14 pm »
I've still got a lot of PCB's laying around.
You're welcome to buy as many as you want. :)
But supplying resistors is a bunch of work, so I'd need to up the price a lot on those.
Edit: I've got about 200 pcb's left, and enough 1% resistors for all of them.
It's the 0.1% resistors that's annoying to source in quantity.
« Last Edit: November 03, 2017, 04:53:26 pm by Fortran »
Offline Mr. Scram
« Reply #392 on: November 03, 2017, 04:57:05 pm »
Can you give a ballpark price?
Offline Fortran
« Reply #393 on: November 03, 2017, 05:10:31 pm »
6 PCB's = 1.50 USD
1% resistor kit = 2 USD
Shipping worldwide  = 3 USD
Edit: All gone :)
« Last Edit: January 02, 2018, 12:46:55 pm by Fortran »
Offline bitseeker
« Reply #394 on: November 03, 2017, 08:55:18 pm »
Wow, I didn't know you still had that many, Fortran. Glad to see new folks are interested in them.
Offline Fortran
« Reply #395 on: November 03, 2017, 09:12:15 pm »
Many?
Considering how many I ordered, I'm scraping the bottom :)
Offline Leo Bodnar
« Reply #396 on: November 03, 2017, 09:25:04 pm »
How much is for 0.1% kit?
To put it into perspective $2 is 12 minutes of unskilled labour in the UK (i.e. barely navigating into resistors section on Farnell)
« Last Edit: November 03, 2017, 09:27:54 pm by Leo Bodnar »
Offline Fortran
« Reply #397 on: November 03, 2017, 09:49:40 pm »
I dunno.  30 USD?
If there's a craze for them (again) I could go a lot lower, but they are expensive so I don't want to order unless I know I can sell them all.
To put in perspective, I bought a reel of 1% for the price of a set of 0.1%
Offline Leo Bodnar
« Reply #398 on: November 03, 2017, 10:03:11 pm »
Heh, i have recently bought a single 0201 resistor for the price of a full reel of 1% :)
http://uk.farnell.com/1714024
« Last Edit: November 03, 2017, 10:15:38 pm by Leo Bodnar »
Offline Fortran
« Reply #399 on: November 03, 2017, 10:16:03 pm »
Then you know why I'd rather sell the stuff I have in stock :)
