Author Topic: Yet another resistance decade box  (Read 58902 times)
Offline PeterZ
« on: May 16, 2016, 09:50:12 pm »
I got some of these cheap thumb wheel switches (smaller ones, ~18mm height) recently.
Unfortunately, the overall quality and the drilling precision, as you can see on the attached picture, may occasionally lead to increased contact resistance. Pretty significant increase ;)
Since it is a PCB, i decided i'll make a new one, 0.6mm thick, easy to cut and trim with scissors, already accommodating footprints for one decade of 1206 resistors.
The small jumpers near the terminals pads allow to configure them as input or output. Makes the wiring easier:
     1R  10R 100R 1k
out---+   +---+   +--- ... +
      +---+   +---+        +--- in
The PCB with 6 such modules is smaller than 5x5cm. I designed it using SprintLayout6.
Design files (gerbers for 1206, 0805 version and the original SprintLayout project) are HERE (github repo).
The following users thanked this post: kripton2035, bitseeker, meandeev, anfang
Offline Dave
  • Country: si
  • I like to measure things.
Re: Yet another resistance decade box
« Reply #1 on: May 16, 2016, 09:56:05 pm »
Pretty clever idea. :-+
What sort of resistance are you getting on zero setting?
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
The following users thanked this post: meandeev
Offline PeterZ
« Reply #2 on: May 16, 2016, 10:10:40 pm »
Thanks! :) Using 4 wire method on my 3456A the measured resistance on 0 setting is about 60 mOhm.
I didn't bother to order these PCBs with gold plated pads, it's just a standard lead free HASL.
Offline Fortran
« Reply #3 on: May 16, 2016, 10:27:12 pm »
Clever indeed.  :-+
Do they still stack together despite the added height of 1206?
I might steal this idea and make a larger batch with ENIG.
Offline matseng
    • My Github
« Reply #4 on: May 16, 2016, 10:38:05 pm »
If you do and decide to sell some of the pcbs please sign me up for a dozen....  :-+
Offline PeterZ
« Reply #5 on: May 16, 2016, 10:46:33 pm »
That was my first  :palm: moment when i got the pcbs ;)
It's not perfect, but good enough (for me):
Offline Fortran
« Reply #6 on: May 16, 2016, 11:28:40 pm »
I had a feeling that might happen  :)
Not a huge deal to correct though. Just make the board a bit longer.
If you want to remake them, I'll buy a dozen or two.
If not, I'll remake them as soon as I get some computer quality time. :)
Offline linux-works
    • netstuff
« Reply #7 on: May 16, 2016, 11:35:07 pm »
cool idea.
I see a group-buy coming (perhaps)?
I'd grab some if there is a GB.
Offline Photon939
« Reply #8 on: May 16, 2016, 11:50:44 pm »
Seconded on the group buy motion  :-+
Offline PeterZ
« Reply #9 on: May 17, 2016, 12:02:16 am »
Guys, hold on, new version in the works.
Another possible issue: do all of these switches have the same layout for mechanical holes? Probably not. First we'd had to find the source for exactly this type. Of course, if you don't want to redesign the board.
I don't think i will be ordering the new version, but will do the design/post the gerbers for you.
Offline Dave
  • Country: si
« Reply #10 on: May 17, 2016, 12:43:55 am »
I see these being useful for experimenting with values for something like loop feedback adjustment and whatnot, but there is one major problem that these have. They go open circuit while you are switching a value, which could leave the loop momentarily without feedback, making it go crazy. The solution to this problem would really be quite simple, you'd just have to make sure one of the wipers hits the next contact before the other one leaves the first contact.
I sketched up something in altium that I think might work.
Offline Macbeth
« Reply #11 on: May 17, 2016, 12:57:58 am »
Genius idea! I much prefer the original compact design than the longer one. Perhaps some of that spare PCB could be used to make L shaped shims for stacking them without gaps?
@Dave - Another great idea!  :-+
Offline Fortran
« Reply #12 on: May 17, 2016, 01:22:42 am »
@Peter - Well you could always post a drawing of the mechanical layout of your switches.
Anyone who has one that matches could post where they got it.
I have no problems with ordering enough of them to be able to sell for around 1USD each, with ENIG. (Board only)
Plus 2-3USD per order for shipping anywhere in the world.
Dave has an excellent point.
Offline PeterZ
« Reply #13 on: May 17, 2016, 01:52:03 am »
@Dave - great idea! I don't have any access to altium, but i tried to "draw" something similar in Sprint Layout.
I will try to etch a test board, only one layer to see if it works.
@Fortran - i added one extra layer to the gerber files (board outline + npth holes). You can import it to your PCB software and use as a template.
The following users thanked this post: Priestblood
Offline Fortran
« Reply #14 on: May 17, 2016, 03:03:06 am »
I made a quick drawing from the gerbers, as one would measure with calipers.
Offline Dave
  • Country: si
« Reply #15 on: May 17, 2016, 03:06:06 am »
I forgot to mention that the similarity to the Aperture Laboratories logo is strictly coincidental. ;D
You could remove those direction selection jumpers on the bottom and reduce the size of the board slightly. It doesn't matter which way the current flows through a resistor.
Offline Fortran
« Reply #16 on: May 17, 2016, 03:20:58 am »
@Dave - In order to avoid lawsuits, this too was strictly coincidental  ;D
Made it for my nephew.  It's a "lights and sound thingamajig(tm)".
Offline PeterZ
« Reply #17 on: May 17, 2016, 08:27:40 pm »
I etched a small test pcb today to check if the make-before-break operation of the switch. I used the continuity tester to check if there is a short beep when the switch passes from one setting to another.
Result: yes, it does work.
I think i will make two versions of the board: one as in original: break-before-make and the new make-before-brake, maybe a few versions of a small 5x5cm panel (sort of), consisting MBB only, BBM only and MBB+BMM versions.
Online BravoV
« Reply #18 on: May 17, 2016, 10:41:11 pm »
Subbed, just in case there is a group buy, count me in.
Offline nuno
  • Country: pt
« Reply #19 on: May 18, 2016, 02:45:37 am »
Offline PeterZ
« Reply #20 on: May 18, 2016, 06:02:56 am »
Meanwhile, i've built one decade R box using the PCBs i have and set of 1% resistors (1M, 100k, 10k, 1k, 100R, 10R):
The total resistance when all switches are set to 0 is about 370mOhm.
I used these jumpers only to make the wiring easier, like this:
Removed them in the final version. The PCB size is 46.5x46mm (filled up the remaining space with an SOP/SOIC adapter, adapters are always handy).
Offline Dave
  • Country: si
« Reply #21 on: May 18, 2016, 08:04:20 am »
You can still wire them the exact same way even without those jumpers. Again, they are resistors, it makes no difference which direction the current flows through them.
Offline Fortran
« Reply #22 on: May 18, 2016, 02:56:08 pm »
Nice!  :-+
If you're making both BBM and MBB it might be a good idea to put that somewhere on the silkscreen so you don't have to take it apart to know which type it is.
For a group buy, it would be more economical to arrange them 1x6 or 2x6.
The 50x50 format is great for those who want to order themselves though.
Offline linux-works
    • netstuff
« Reply #23 on: May 19, 2016, 07:42:05 am »
even more, to differentiate, put ribbed edge or something on one but different style on the other.  something physical that you can use as a cue.  I always like seeing stuff like that.
(OT: pet peeve of mine: when you have a thruhole electrolytic and your silk symbol has the index (plus or dot or whatever) INSIDE the inscribe circle, so that once the cap is installed, you can't visually tell, easily, if its in right or reversed.  just another plus symbol added outside the cap circle would do wonders to allow desk checking.)
Offline PeterZ
« Reply #24 on: May 21, 2016, 10:22:09 pm »
Okay, the github repo is updated with multiple versions of the board:
LINK
including:
  • single boards - if you'd panelize them yourself
  • about 50x50mm format - 4xMBB, 4xBMM and mixed 2xMBB+2xBMM versions and an SOP/SOIC to breadboard adapter to fill up the space
  • 1x6 MBB
  • 2x6 MBB
I made only the MBB version of the last 1x6 and 2x6 formats. I think this one will be better suited for R decade boxes.
The MBB version is not 100% verified yet. I am going to order a small set of ENIG ones and build another, more precise box with 0.1% tolerance resistors.
Offline Fortran
« Reply #25 on: May 26, 2016, 01:40:11 am »
Looks really good!
Do you have a link to where you bought your switches?
At first glance I thought they where the cheap "KM1 Pushwheel switch" from Ebay, but it doesn't match.
Offline PeterZ
« Reply #26 on: May 26, 2016, 02:25:38 am »
Offline Fortran
« Reply #27 on: May 26, 2016, 03:19:14 am »
Great!
I'll buy a few sets of random KM2 and see if they match the design.
They might not arrive until I'm on my honeymoon though, but a group-buy should be available in August if everything goes to plan.
I'll do my best to keep costs down (I'm not taking any profits at all. This will be a zero gain deal for me).
Early estimates put this at around $5 per 6 boards, plus $2 for shipping and handling anywhere in the world.
A shoutout from anyone interested at this price would be nice. Just to get a sense for the scale of it.
Hopefully it will be lower.
Offline matseng
    • My Github
« Reply #28 on: May 26, 2016, 03:39:20 pm »
"Shoutout" for three sets. :-)
Offline chickenHeadKnob
« Reply #29 on: May 27, 2016, 12:11:55 pm »
I am interested in the make before break boards,20 to 24 individual (little) boards, so depends on your panalization.
Offline Fortran
« Reply #30 on: May 27, 2016, 05:12:10 pm »
I was actually planning to get them V-scored, so any number will be fine.
Makes handling a lot easier if you don't need to cut them by hand.
Offline krivx
  • Country: ie
« Reply #31 on: May 27, 2016, 08:25:04 pm »
Great!
I would like a couple of sets.
If you have any plans to do capacitor boxes that uses BCD switches I would also like some :) http://www.electricstuff.co.uk/capbox.html
Offline Fortran
« Reply #32 on: May 27, 2016, 09:14:54 pm »
I've thought about making capacitor decades as well.
If there's some interest, I'll probably make one.
Offline alank2
« Reply #33 on: May 27, 2016, 10:18:22 pm »
Very nice!  Are you going to offer them as a kit or group buy?
Offline Fortran
« Reply #34 on: May 27, 2016, 10:38:37 pm »
Plan is to get a few hundred boards made and sell them (board only) as cheap as I can.
Although, price per resistor is significantly lower in 1000's then in 10's, so I'll take a look at the kit option.
Offline Fortran
« Reply #35 on: May 28, 2016, 04:43:26 pm »
So I've looked in to it.
I would be able to offer a set of Vishay Dale CRCW resistors for an additional ~$0.80.
That's for 6 values from 1R to 100K, 10 of each. Quick specs are 1/4W, ±1%, ±100ppm/°C.
And you don't need to buy in groups of 6. Since I'm getting them V-scored I don't need to spend hours cutting boards, so buy whatever amount and value you like to match the number of switches you have.
I would have loved to be able to offer higher power and precision, but even though the price per set would still be reasonable, it adds up to amounts that would make my wallet cry.
So. ~$0.85 per blank board
or   ~$1.00 per blank board +10 resistors of either value.
I can populate a few for those who really need it.
Sound good?
Offline matseng
    • My Github
« Reply #36 on: May 28, 2016, 05:39:33 pm »
But 1% is really crappy... ;-(
How much more expensive would 0.1% be?
Online BravoV
« Reply #37 on: May 28, 2016, 05:58:10 pm »
Count me in for 2 groups (12).
Offline Fortran
« Reply #38 on: May 28, 2016, 07:42:57 pm »
If I do a less bulky-ish order I can manage to get 0.1% on all but 1R. (Simply because I can't FIND any 1R 0.1%)
But picking on the poor 1R only being 1% is mean since contact resistance is probably more then that.
The lineup would then be Wishay Dale CRCW 1/4W, ±1%, ±100ppm/°C for 1R,
and Yageo RT 1/4W, ±0.1%, ±25ppm/°C for 10R-100K
I'm only capable of buying these in 100 quantity at a time though. 1000 quantity would mean about $750 upfront for resistors alone and that's just too much for me.
Due to the limited number of sets I'd prefer to sell all 6 values per order to keep an even stock. When all resistors are sold I can order 100 new ones and repeat as long as there is demand.
That would add up to $12.60 for 54 resistors. (No spare to drop under the bench never to see again)
Plus ~$5.10 for the boards and ~$2 for shipping gives a total of ~US$19.7 delivered. (Actual switch not included)
Offline Dave
  • Country: si
« Reply #39 on: May 29, 2016, 03:37:14 am »
I don't think 0.1% resistors would even make sense, because the contact resistance of the contacts would dominate the error in the lower ranges. You wouldn't use this sort of resistance box for any precision application, so 1% is more than good enough for the purpose.
Put me down for 6 boards. :-+
Offline Fortran
« Reply #40 on: May 29, 2016, 05:37:13 am »
0.1% doesn't make sense on 1R.
Probably not on 10R either.
But after that it would make a difference.  Even though a small one.
1% is good enough for me, and probably for most.
Majority rules.  :)
1% is practically free and that kind of money up front makes no difference to me.
0.1% isn't.  But if 10 people want a set so I know I'll sell it, it's fine by me.
Offline Macbeth
« Reply #41 on: May 29, 2016, 07:21:28 am »
I agree - my own resistor decade I made with the bigger version of these switches I debated even having a 1 ohm setting, then went ahead and also made sure to use 500mW resistors there and the tolerance wasn't particularly relevant. The other ranges all done with 250mW and I selected from 1% resistors for the job. Certainly the higher range resistors would benefit from 0.1% tolerance but even then, that's not good enough - 1k per 1M - renders the bottom 3 digits untrustworthy.
Offline julian1
  • http://blog.julian1.io
« Reply #42 on: May 29, 2016, 06:06:28 pm »
I'm interested - 2x sets (12) including resistors. The prices seem incredibly reasonable so 0.1% would be great if it can be managed.
Anyone scoped possible boxes/enclosures?
Offline PuterGeek
    • SolutionsPLUS engineering
« Reply #43 on: May 30, 2016, 03:52:43 am »
Quick question on the contact plating, are you going to have them hard gold plated or just ENIG?
The gold plating on ENIG isn't very robust since it's only intended for solderability. Once the gold wears of the contacts will be the nickel underneath with its higher resistance.
Hard gold would add to the cost but it is designed for this application.
Something to consider.
Offline Fortran
« Reply #44 on: May 30, 2016, 04:48:22 am »
Just ENIG.
I can't seem to find a manufacturer that does hard gold and are willing to give me a quote. I'm guessing I can't afford it.
I'm not too worried though..  Even if you wear it down to the nickel it's probably still going to be better then original.
Offline garnix
« Reply #45 on: May 30, 2016, 08:37:46 pm »
I can't judge the gap from the pictures - but would 0805 type resistors help? They seem to be 0.1 mm less thick? Ultimately I liked your first "in-package" concept, because of the reduced amount of space it needed.
Offline gdewitte
« Reply #46 on: May 31, 2016, 06:25:47 am »
I would like two.
Offline PeterZ
« Reply #47 on: June 01, 2016, 07:20:38 pm »
I don't think using 0805s would help much:
The MBB ENIG boards are on the way:
Offline Fortran
« Reply #48 on: June 01, 2016, 08:07:20 pm »
Not to mention that 0805 only has half the power rating of 1206.
I wouldn't want to go below 1/4W, but maybe that's just me.
Glad to see the boards are on the way  :-+
ETA 1-2 weeks?
Offline linux-works
    • netstuff
« Reply #49 on: June 07, 2016, 04:14:34 am »
if I can get a set of these, I can try to do a laser cut style box using acrylic (or maybe wood for those that like that).
Offline krivx
  • Country: ie
« Reply #50 on: June 07, 2016, 05:04:36 am »
A design that could be run on itead/seeed's lasercutting service would be useful
Offline linux-works
    • netstuff
« Reply #51 on: June 07, 2016, 05:59:40 am »
not sure what their limits are, but I tend to do pretty simple things that are designed in 2d and use a 'tabbed box' style of assembly.  nothing tricky about that.  its not glued, its floating and just screwed with standoffs and screws, so its open-able and fixable (the way I like it).
Offline meandeev
  • Country: at
« Reply #52 on: June 07, 2016, 06:14:40 am »
I would like to have 2 sets (12 boards) including resistors an 4 additional boards.
Online bitseeker
« Reply #53 on: June 07, 2016, 08:52:21 am »
Very cool project. I don't yet have decade boxes for either resistance or capacitance, so both types are of interest to me.
Has there been confirmation on which switches to use with the MBB boards and is there a vendor that ships them to the US? The listing that was posted previously says they don't ship to the US.
You don't acquire TEA. It acquires you.
Offline all_repair
« Reply #54 on: June 07, 2016, 09:41:53 am »
Count me in for 5 set with resistors.
Offline PeterZ
« Reply #55 on: June 10, 2016, 03:59:44 am »
Enig MBB boards arrived. I can confirm they work fine.
Tested one with 10k resistors. The meaured 0 setting contact resistance was about 60mOhm (vs about 360mOhm with HAL board).
Regarding the switches: look for KM2 type 18x6mm decimal code thumbwheel switches. Found these on ebay:
http://www.ebay.com/itm/10-x-Black-Decimal-Code-Single-Unit-Thumbwheel-Pushwheel-Switches-18mm-x-6mm-KM2-/310827089552
Online BravoV
« Reply #56 on: June 10, 2016, 04:11:28 am »
So how many sets for each board ? 4 as above pictures ?
Just fyi, cheaper 18mm x 6mm KM2 alternative -> http://goo.gl/HgTVya  >:D
Offline Fortran
« Reply #57 on: June 10, 2016, 05:32:05 am »
They will be sold individually. I've been counting a set as 6 boards though but you can buy whatever amount you want.
I bought these and they match:
http://www.ebay.com/itm/301726653090
Offline linux-works
    • netstuff
« Reply #58 on: June 10, 2016, 03:19:49 pm »
put me down for a set of boards, too.
thx
Offline Fortran
« Reply #59 on: June 10, 2016, 03:29:00 pm »
You're already on the list :)
Offline Zkronk
« Reply #60 on: June 10, 2016, 06:43:51 pm »
I'm interested in buying a pack of 6 boards from you :)
Offline cucumbers
« Reply #61 on: June 13, 2016, 10:57:51 am »
Cool idea guys - and great timing, I just bought a bunch of eBay KM2s! Just joined the forum to say I'm interested in 2 sets of MBB boards + resistors, if they're still going.
Cheers!
Offline Back2Volts
« Reply #62 on: June 13, 2016, 02:43:17 pm »
If still open, I am interested in 2 sets of MBB boards + resistors
Offline natman69
« Reply #63 on: June 13, 2016, 05:09:42 pm »
Please, keep me informed!!!
I am interested in 2 sets of MBB boards + resistors 1% (or even better 0.1%).
Thank you.
Offline Fortran
« Reply #64 on: June 13, 2016, 05:40:37 pm »
Everyone who has shown interest have been counted and there will be more then enough boards made.
Since PeterZ has confirmed that they work I'll be ordering later this week.
Once they arrive I'll start shipping them out.
Offline JohnPen
« Reply #65 on: June 14, 2016, 06:24:52 pm »
Please can you add one set with resistors (1% is fine) for me.  Also can you advise the payment process you will be using.
Thanks,
John
Offline Fortran
« Reply #66 on: June 14, 2016, 07:51:44 pm »
You've got a point there.
I'll be accepting PayPal.
Online bitseeker
« Reply #67 on: June 15, 2016, 07:28:05 am »
Thanks for the info on the model of switches to use.
Fortran, put me down for 1 set of MBB with 1% resistors to populate them.
Online bitseeker
« Reply #68 on: June 15, 2016, 07:34:37 am »
I tend to do pretty simple things that are designed in 2d and use a 'tabbed box' style of assembly. ...  its not glued, its floating and just screwed with standoffs and screws, so its open-able and fixable (the way I like it).
That sounds good. Binding posts on the short side?
Offline m100
« Reply #69 on: June 15, 2016, 07:44:35 am »
Please put me down for a set of MBB boards and resistors
Thanks!
Offline Fortran
« Reply #70 on: June 15, 2016, 04:59:22 pm »
1000 boards have been ordered. That should be enough :)
They should arrive in a few weeks so I'm going on holiday in the meantime.
Resistors will be ordered so they arrive when I get back.
Offline natman69
« Reply #71 on: June 15, 2016, 05:43:29 pm »
Thank you!   :-+
Online bitseeker
« Reply #72 on: June 15, 2016, 05:44:59 pm »
Excellent. Have a wonderful holiday! :popcorn:
Offline linux-works
    • netstuff
« Reply #73 on: June 16, 2016, 02:47:33 am »
maybe people can throw together some images (3d mockups) of what they have in mind and we can find something that works for most of us.
I often start with this site
http://boxdesigner.connectionlab.org/
its pretty well known, by now, and its pretty simple.  enter the dimensions (outer, I believe) and it creates a pdf for you; you import that into your 2d editor (I use corel draw since its what our lasers at tech-shop mostly use) and you add whatever panel cut-out shapes and lettering you want.  edit some of the tab notches, if needed, do a dry run using cheap cardboard instead of plastic (I often will get something wrong and its nicer to waste cardboard instead of good material).
what I do beyond the standard box maker is to add a rim around the top and bottom plates and allow for pcb style standoffs to be used (long ones) to screw into top and bottom holes.  if the rim is extended beyond the box dimensions, then you need to edit the 'zipper' tabs into rectangles that the laser will cut; those become locking tabs that keep the sides from falling out.  this method is glue-less and depends on the standoffs being the interior height of the box and being screwed to the top and bottom.  here's a photo of one of mine, maybe it will be obvious what I was trying to decribe ;)
'top and bottom' are relative, if it makes sense to put the rails this way, whatever works for you.  one optimization is to use those standoffs as ways to secure rubber feet to the real bottom of the box.  rubber feet with holes and #6-32 screws work well and its easy to find 6-32 thread hex or round standoffs and either stack them in unison, all 4 corner posts; or get long ones to-size or cut them all to-size.  if they are threaded on one end and tapped on the other, they will stack and you can screw the rubber feet into the female side of the standoffs.  the top of that stack has exposed thread ends, and so I tend to use finished nice-looking acorn nuts and just hand tighten them.  it holds the box together, it lets me get inside easily, there is no need to glue things this way and each panel is replaceable since its just a bunch of panels.  if you get panels made, get extras made and when things get scratched or broken or old looking, refresh it with replacement panels ;)
anyway, that's what I do for DIY panels.  its cheap, it works well and while it has a bit of a strange look, its very practical in many ways and if its not meant to sit on a shelf and look pretty, its actually pretty enough for its job ;)
Offline PeterZ
« Reply #74 on: June 18, 2016, 12:06:09 am »
I was looking for a suitable box to accommodate the new longer MBB switches, found the Hammond 1591L at the local store.
Will do the job, there in enough space to mount the switches and binding posts on the top or any sides of the box.
Offline linux-works
    • netstuff
« Reply #75 on: June 18, 2016, 12:32:32 am »
how are the switches going to be mounted?  I don't have mine yet (on the way in the mail) but its not obvious how they securely mount.  is there a rod that would go thru them all, side to side?  I think I've seen TW switches with holes like that before.
the neat thing about lasercut boxes is that you can make them custom to-size, and since there is probably a square corner style hole to be cut, that's not something I would want to do at home with hand tools, for example.  round holes, sure, I won't invoke a laser for that.  this isn't round holes and so I'd hate to have to machine a pre-made box; might as well just blast the whole thing out on a laser and have it be exactly what you want.
Online bitseeker
« Reply #76 on: June 18, 2016, 03:25:13 am »
That laser-cut box looks good. I like the way the top and bottom panels overhang with the tabs inset. I suppose there could be a group buy on such an enclosure as well.
Thanks for the link to the box designer.
Offline linux-works
    • netstuff
« Reply #77 on: June 18, 2016, 01:34:52 pm »
if enough people like a design, I could run off a small bunch of them during some scheduled time at my hackerspace.  the design would be in .pdf format so any art tool should be able to import it and edit it for re-print (re-burn?)
I'm still wondering HOW this is going to mount!?
before boards are sent out (have they been?) - has thought been given to how to mount this, remove sections for fixing or update or replacement and so on?
would it make sense to have the pcb's terminate in a finger backplane (think: pci cards and slots, etc) or something, that would help the whole thing mount?  maybe a backplane board with sockets and the rotary switches would plug into that?
if these become 'plugins', then some plastic box around that could be made to guide the modules into a backplane.
what do you guys think?
at any rate, there has to be some thought as to how these get mounted ;)
« Last Edit: June 18, 2016, 01:36:25 pm by linux-works »
Online bitseeker
« Reply #78 on: June 19, 2016, 04:21:14 am »
Very good points. I haven't thought about it. However, I'm awaiting arrival of an IET decade box and will see what they did. Based on the service manual, they only use five resistors per decade (e.g., for 1 - 9 Ohm decade: 1 x 1 Ohm, 4 x 2 Ohm), having the thumb wheel route current through the appropriate combinations.
I kind of like the enclosure of the RBOX Mini. It's very much in the spirit of the method you described, but with the standoffs on the outside. Using a two-layer, white and black, acrylic would make for nice etched lettering, but I suppose you'd also see the layers along the cut edge of the panel.
Offline PeterZ
« Reply #79 on: June 19, 2016, 05:07:37 am »
Normally, if you buy these switches from any large supplier, like Digikey or Mouser, at a different prices of course, they come with two ending caps having a snap in function (see the pic). No idea if you can get them for KM2 switches.
I used a high quality hot snot in my box ;)
Wouldn't adding more finger type springy contacts significantly increase the overall residue resistance?
Online bitseeker
« Reply #80 on: June 19, 2016, 01:55:08 pm »
High-quality hot snot. Infinitely configurable.
Offline m100
« Reply #81 on: June 21, 2016, 12:44:17 am »
Never seen them myself, are these 'KM2' switches actually a knockoff of another manufacturers part?
The only time I've ever used these dirt cheap far eastern sourced switches they were wrapped in black insulation tape and not even fitted to a panel.   :D
Offline linux-works
    • netstuff
« Reply #82 on: June 21, 2016, 01:19:50 am »
for a midnight build, if a deadline is tomorrow - yes.
for a real build, I'd prefer to find something that was clean enough so that you are proud enough of the insides that you'd build it with a clear front (or all clear) panel.
also, glue is less repairable; meaning that if I needed to pull things apart and clean contacts or fix things, I don't want to deal with a previous glue job.
btw, my set of switches from ebay is due for delivery today.  I'll give mine a look and see if there is a non-glue (lol) solution to mount this acceptably.
I don't have the boards yet, but I'll see if I can do a dry fit into some plastic lasercut box and see how it goes.  when I get laser time, I'll make something and post an update.
Online bitseeker
« Reply #83 on: June 21, 2016, 03:38:41 am »
Yeah, I was being facetious on the hot snot. Looking forward to your impressions on the switches you receive.
Offline linux-works
    • netstuff
« Reply #84 on: June 21, 2016, 04:49:52 am »
I use plenty of hotmelt glue, but only on things that I don't plan to show to anyone or things that are temporary.
perfect use-case: some diy perf board with standoffs; and I'm still working on it and need some chassis just to hold the jacks up.  I'll hotmelt the alum or nylon standoffs to the chassis (pcb is screwed to the standoffs, first) and that will let me try out a wiring config or routing.  I might change a few more things over time before I want to commit to an expensive metal chassis (that someone else makes, at high cost to me).  I can pull up hotmelted riser posts easily, yet they stay down long as I need them to, to run test wires to.  as long as I don't ship it, I can even bring temp work to demo events and shows.  you'd never have a clear cover over such things, though ;)
the procedure is quick, too; with the pcb screwed to 4 alum/etc posts, dab some hotmelt quickly on the screw areas of the bottom posts and quickly position to the plastic base/box.  it sets in under a minute.  requires just hand force to pull up when you are ready to change a config or try some other board in that place.
anyway, I'd like to see something that is held down by screws or a pressure plate that pushes something against the front panel, so that its undo-able, for future service.
if people have ideas, post them!  this is not my specialty, so if others have better ideas, lets hear them.
Offline linux-works
    • netstuff
« Reply #85 on: June 21, 2016, 04:54:33 am »
if those fingers are the ones I've seen before, such as on IEC inlets on those snap-in power jacks, that works great for stiff strong sheet metal that is thin.  it does not work well at all on thicker plastic that isn't so strong.  with plastic, I tend to use 1/8" (common, cheap, easy/fast to cut, strong enough for most things).  you can go thinner than that but you don't get stronger that way ;)  polycarb would be thin and strong but I don't have laser privs that cut such poisonous stuff as lexan/polycarb.
I wonder if a hybrid would even be possible; a metal front panel (simple, cheap, strong) and the rest would be plastic to save weight and mostly cost.
otoh, if you go to that much trouble, maybe going all metal is the way to go.  going all metal would be more durable and also give the chance for some level of shielding, such that it is.
Offline linux-works
    • netstuff
« Reply #86 on: June 21, 2016, 04:56:55 am »
I have to ask....
so, when is the automated SCPI controlled version going to come along?
LOL
(half serious, though)
Online bitseeker
« Reply #87 on: June 21, 2016, 07:05:25 am »
Yeah, I was half-seriously thinking about something like that. Would you switch in the resistors electronically, electro-mechanically, or go all out and rotate the switches with servos (not too practical, but cool looking)?
Offline linux-works
    • netstuff
« Reply #88 on: June 22, 2016, 05:19:56 am »
these things are too small!  are you guys SURE you want to work at this size?
they make larger style thumbwheels.  I really wonder if people are going to be able to do this mod..
first, removing the pcb from the switch seems mostly destructive, in that you have to cut or unweld a few plastic posts.  it can't easily be redone, either.  how are the new pcb's going to be glued or connected to the switch again?  there is no ability to use screws or anything like that.
fwiw, the unit I got did have 2 end caps with those finger stock things but that really is not going to give a reliable mount, imho.
my gut feeling - fwiw - is that it would be better to have the switches send signals to a cpu and have that controller drive a bunch of low-R contact relays with precision resistors.
don't know; now that I see this thumbwheel unit, it does not long strong or robust or worth hacking.  maybe I'm wrong, but it seems like - once you open it - its never going back together again.
we want something that will work and be trustable, right?  I guess more people have to get this and open them and then we'll get some opinions.  right now, I'm not all that hot on this particular thumbwheel.  its just too small and fragile for anything close to metrology, even DIY level.
Offline PeterZ
« Reply #89 on: June 22, 2016, 06:22:50 am »
I think you haven't read my very first post in this thread. The whole idea of this hack was to pimp up a cheap Chinese thumbwheel switches from ebay (i guess they are a knock off of some brand, what else?) which otherwise i would thrash and generate more e-waste, definitely it wasn't to build the worlds best piece of art resistance decade box.
Thanks to Dave, the idea evolved into making a make-before-break version, which in my opinion made this hack even mode useful.
I also mentioned the size of the switches, i don't understand how it comes as surprise to you now.
Removing the pcb from the switch requires to cut off three posts, but the new pcb, once pushed in sits tight. Definitely not going to come off due to the force generated by the spring contact. If that's not enough, a very tiny drop of gel superglue will secure the spots.
I have built two decade boxes using these modded switches now, they work ok. Maybe they won't last forever, but for the price - that's ok.
If you prefer to make a relay based, mcu controlled decade box, which you can be proud of, there is no point in modding these switches. There is no point in using them at all.
This is a quickie project using cheap parts with the intention to make the best out of them.
Offline Fortran
« Reply #90 on: June 22, 2016, 09:13:25 am »
I second what Peter said.
It's never going to be a high-end product. But with a new board it's probably good enough for most hobbyists.
It will definitely be good enough for most beginners!
And for the price of 1USD for 6 boards, complaints isn't an option.
I've poured a few hundred bucks into this already just because I like the idea, with basically zero margin. If I don't sell enough of them I'll loose money.
If you want a professional device, spend the extra 500USD or so and get one.
This is basically putting makeup on a pig, and should be treated as such.
But for what you're paying.. it's quite an attractive pig :)
Offline m100
« Reply #91 on: June 23, 2016, 04:36:47 am »
Indeed they do, but ten KM2 switches cost me about GBP 4 delivered.  Larger switches from recognised suppliers and distributed by Farnell in the UK are around GBP 20 each
http://uk.farnell.com/crouzet-automation/84210054/switch-decade/dp/143617
At GBP 120 just for switches on a six decade box such a project would be a non starter for me especially when I could buy a significantly larger form factor one fully assembled and off the shelf for GBP 100
http://uk.rs-online.com/web/p/decade-boxes/3826439/
or for those with much deeper pockets an IET Labs one for GBP 600
http://uk.farnell.com/iet-labs/rs-200w/resistance-decade-box-0-99999999/dp/9769765
or a Time Electronics one for roughly the same GBP 600
http://uk.farnell.com/time-electronics/1040/resistance-box/dp/5058284
« Last Edit: June 23, 2016, 04:59:51 am by m100 »
Offline linux-works
    • netstuff
« Reply #92 on: June 23, 2016, 05:09:33 am »
I understand the original motivation and yes, after 4 pages and talk of group buys, its gone beyond one guy who has a surplus of parts he wanted to get use out of.
that said, if people have put money in, it would not be fair to leave them; and so I would continue to support the project and buy my reserved boards so that the organizers don't lose money.
Online bitseeker
« Reply #93 on: June 23, 2016, 01:14:13 pm »
Yep, I like this little one because the size and cost are good for tinkering. I got a used IET box for long-term, "serious" use (and higher wattage). It's all good.
Offline all_repair
« Reply #94 on: June 23, 2016, 03:44:12 pm »
I am going to throw a few into my site-work bag, and a few in the lab when testing some process meter.  Save me finding, filing or buying loose resistors for setup need.  Yes, I do have a tank-like decade box.
Offline Fortran
« Reply #95 on: June 25, 2016, 05:33:12 pm »
The boards have been shipped and should arrive in 1-2 weeks.
And the resistors have been ordered and should arrive in about a week.
So we're getting close  :-+
Online bitseeker
« Reply #96 on: June 26, 2016, 08:34:29 am »
Thanks for the update. Looking forward to it.
My IET boxes arrived. Unfortunately, they didn't go unmolested during their former lives, so I've got another project for my queue.
Offline ez24
  • L.D.A.
« Reply #97 on: June 26, 2016, 10:55:48 am »
Just read this and at 98 posts I am not 100% sure what is going on.
I think this is a project taking some cheap ebay thumbwheel switches, cutting the guts out and gluing in some custom boards someone is making to make a decade box.
If I am right I am also interested in buying some
Maybe helpful to summarize what is going on in the 100th post.
thanks
YouTube and Website Electronic Resources ------>  http://www.eevblog.com/forum/other-blog-specific/a/msg1341166/#msg1341166
Online bitseeker
« Reply #98 on: June 26, 2016, 02:00:05 pm »
Unless someone beats me to it, this is only post 99 (reply 98), but here's a quick summary:
   You are correct.
And a slightly longer summary:
   6x inexpensive thumbwheel switches from China
+ 6x custom make-before-break PCBs
+ 54x 1%, 1/4 Watt SMD resistors
+ 1x enclosure of your wildest dreams
= Fun little six-decade resistor box
Offline ez24
  • L.D.A.
« Reply #99 on: June 26, 2016, 02:23:09 pm »
54x  whew !   What size?
Could a learner solder them?  I finished a SMD practice board, cannot remember how many components it was.  If 0402 (metric  .1mm - smaller than a baby flea), I probably could not do them.  If 6332 (metric - 1 cm) probably can  :-DD
Just curious - what is the normal way to spec these  - metric or imperial ?
thanks
Online bitseeker
« Reply #100 on: June 26, 2016, 05:14:07 pm »
PeterZ posted two layouts, 1206 and 0804. I'm not sure which size Fortran used for the group buy.
Note that 0402 is 1mm long, rather than 0.1mm. The ones for this kit will be 2-3x larger than that. You should be fine, but you may want to do some practice on a junk board first.
I'm not sure what "normal" is. I see the imperial units used more often in discussion. Datasheets often list both, such as the Vishay one for the resistors Fortran ordered. http://www.vishay.com/docs/20035/dcrcwe3.pdf
Fortran mentioned that he might be able to presolder a small quantity of boards. I'm not sure if that's by hand or if he has a reflow oven to do them in bulk. Depending on the price difference, I might be interested in that option.
Offline PeterZ
« Reply #101 on: June 26, 2016, 05:53:19 pm »
All gerbers i posted in the final version on github are for 1206.
Offline Macbeth
« Reply #102 on: June 26, 2016, 09:58:03 pm »
Something else to be said about beginner soldering SMD resistors - they are much more prone to change their value if not soldered quickly and cleanly. Through hole are more forgiving. When you have carefully selected binned resistors to get spot on indexing it can be quite depressing to find it all over the place after soldering!  :-DD
Offline Fortran
« Reply #103 on: June 27, 2016, 02:17:53 am »
I ordered 10 sets of 0.1% resistors as well, since a few people wanted that.
Yes I will hand solder a few sets for those who aren't able to solder themselves.
I wasn't planning on charging anything for it if the "aren't able to" criteria is met.
Pleas of lazyness aren't good enough, and will go unheeded!  ;D
Online bitseeker
« Reply #104 on: June 27, 2016, 07:17:44 am »
No worries. For me, it's simply the age-old trade-off of time vs. cost. Since that scenario no longer applies here, there's nothing to have to decide. Easy.
Hmm, an electronics forum with no smiley that's soldering. ???
Offline ez24
  • L.D.A.
« Reply #105 on: June 27, 2016, 08:03:26 am »
https://en.wikipedia.org/wiki/Surface-mount_technology
I read the chart wrong.  0.1 mm was just a comparison size  whew
So 1206 is 3.2 mm x 1.6 mm   Still small for me  :palm:
FYI from above article
Problematically, some manufacturers are developing metric 0201 components with dimensions of 0.25 mm × 0.125 mm
Boy this is small  wonder if anyone here could solder these ?
Online bitseeker
« Reply #106 on: June 27, 2016, 08:11:10 am »
Woah, metric 0201. :o
"You're ordering another 1000 SMD resistors? Didn't you just get some yesterday?" ???
"I sneezed." :palm:
Offline Macbeth
« Reply #107 on: June 27, 2016, 11:19:34 am »
Better than inhaling them I imagine!  :scared:
Online bitseeker
« Reply #108 on: June 27, 2016, 12:59:20 pm »
Oh my! There a joke in there somewhere. ^-^
Offline Fortran
« Reply #109 on: July 06, 2016, 06:04:51 am »
Update:
Resistors have arrived and I've cut them into strips already.
The boards are in Finland so they should arrive within a day or two.
I'll start shipping out this week. Just need to know the final numbers on everything.  :)
Shouldn't differ much from what I've calculated.
The following users thanked this post: all_repair, bitseeker
Offline Fortran
« Reply #110 on: July 08, 2016, 04:30:57 am »
Everything have arrived and I'm ready to ship  :-+
I've been forced to adjust the price slightly, but I'm hoping everyone is ok with the final numbers.
6 PCB's = 1.50 USD
1% resistors for 6 boards = 1 USD 2 USD ** Out of stock **
0.1% resistors for 6 boards = 14 USD ** Out of stock **
Shipping worldwide = 3 USD  (good for about 6 kits)
So a kit with 6 boards, 1% resistors and shipping is 6.50 USD ** Out of stock **
A kit with 6 boards, 0.1% resistors and shipping is 18.50 USD ** Out of stock **
Edit: All gone. Removed payment details.
« Last Edit: January 02, 2018, 11:57:12 pm by Fortran »
The following users thanked this post: gblades, Dbldutch
Offline Dave
  • Country: si
« Reply #111 on: July 08, 2016, 05:33:05 am »
Payment sent for 1 kit w/ resistors. Thanks again for putting these kits together. :-+
Online bitseeker
« Reply #112 on: July 08, 2016, 07:39:55 am »
Payment sent for 2 kits. PMed you with the details.
Offline cucumbers
« Reply #113 on: July 08, 2016, 08:30:31 am »
6 PCB's = 1.50 USD
So a kit with 6 boards, 1% resistors and shipping is 5.50 USD
Simply add up the stuff you want and send that sum via PayPal to dldm04@gmail.com, along with your list and address.
If anything is unclear, let me know.
Sorry for the silly question, but I've never used paypal to send money directly before. Do I choose the "send money to friends" option, or the "pay for goods and services" option?
Offline Macbeth
« Reply #114 on: July 08, 2016, 08:43:10 am »
In this case I would pick friends. I mean we are all friends here, right? Unless you feel charitable towards paypal at Fortrans expense of course. I'm sure he has costed the commission scenario in?
« Last Edit: July 08, 2016, 08:44:57 am by Macbeth »
Offline ebclr
Offline Back2Volts
« Reply #116 on: July 08, 2016, 12:46:15 pm »
Payment sent for 2 kits. Thanks again for putting these kits together
Tony (PM sent also)
Offline JohnPen
« Reply #117 on: July 08, 2016, 05:43:30 pm »
Fortran. Payment sent for 1 off 1% Kit via PayPal.
Many Thanks for all your efforts.
John
Offline TheAmmoniacal
  • Country: no
  • Cut me some slack, I'm a biochemist!
« Reply #118 on: July 08, 2016, 06:24:38 pm »
Payment sent!  I sent it as a personal payment as to avoid any fees on your side.
I collect [corporate] mugs.
MTBF ~ 700.000 h
Offline Fortran
« Reply #119 on: July 08, 2016, 07:44:39 pm »
First orders have been sent and hopefully everyone has been notified.
If not, let me know :)
  • Country: no
« Reply #120 on: July 08, 2016, 08:45:34 pm »
No idea what I just paid for, will be fun anyway I guess :-DD
MTBF ~ 700.000 h
Offline all_repair
« Reply #121 on: July 08, 2016, 08:52:15 pm »
Just paid fot 6 pcb set, 1x 0.1% resistor set, 4x1% resistor set, 1xship.
Thank you.
Offline Fortran
« Reply #122 on: July 11, 2016, 08:43:53 pm »
Update:
Only 3 of the 0.1% kits remaining.
I've got about 20 of the 1% kits left, and about half a kilo of boards  :)
I'm in no danger of running out of boards..
Offline garnix
« Reply #123 on: July 11, 2016, 09:06:50 pm »
While I'm waiting for the board&resistors to arrive I'm looking at AliExpress for the remaining needed components (KM2 switches, enclosure-box, banana-socket).
While I settled for this switch http://www.aliexpress.com/item/Black-18mm-x-6mm-0-9-Digits-BCD-Code-Pushwheel-Thumbwheel-Switches-KM2/1804257049.html I'm still undecided for the enclosure as I don't exactly know the height of the switch+PCB board - I would like the enclosure to be as small as possible.
Has anybody measured the required height? The plain-vanilla switch (according to AliExpress) seems to be 28 mm, but I guess approx. 2-3 mm of it will stick out of the encasing (pushbuttons, frame), so the case needs a minimal "inside" height of approx. 25 mm?
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #124 on: July 11, 2016, 09:15:41 pm »
Just paid for 2x 6 pcbs only.
Thank you.
Cheers
Alex
Offline Fortran
« Reply #125 on: July 11, 2016, 09:22:34 pm »
The switch is 29mm from the buttons to the edge of the PCB. (the original one)
Height is about 16.15mm inside the box, and 18 outside.
With the new pcb mounted it's 29mm from the front of the box to the edge of the PCB.
The following users thanked this post: garnix
Offline Dave
  • Country: si
« Reply #126 on: July 11, 2016, 09:34:27 pm »
Has anyone found a source for KM2 switches that come with the two end bits? Sellers on ebay and aliexpress only seem to sell just the switches alone.
Offline Fortran
« Reply #127 on: July 11, 2016, 09:37:06 pm »
The ones I linked earlier in the thread came with endbits.
Don't know if they always do or it was just luck, but I guess I'll know soon since I ordered a few more of them.
Online BravoV
« Reply #128 on: July 11, 2016, 11:38:25 pm »
Payment sent, check PM, thanks for making this available.  :-+
Offline natman69
« Reply #129 on: July 11, 2016, 11:45:25 pm »
Payment sent for 2x pcbs set and 2x 1% resistors set plus shipping.
Thank you!!!
Offline johnmx
  • Country: pt
« Reply #130 on: July 12, 2016, 12:33:24 am »
The original PCB is fixed by melted plastic that has to be cut to replace the board.
So, how do you fix the PCB on the switch?
Best regards,
johnmx
Offline Fortran
« Reply #131 on: July 12, 2016, 12:44:15 am »
If you are concerned, glue.
But it's a tight fit so you shouldn't need to.
  • Country: no
MTBF ~ 700.000 h
Offline johnmx
  • Country: pt
« Reply #133 on: July 12, 2016, 01:54:17 am »
Fortran, I would like to buy some PCBs.
I just sent you a PM regarding the payment.
Best regards,
johnmx
Offline PeterZ
Offline ez24
  • L.D.A.
« Reply #135 on: July 12, 2016, 02:02:32 pm »
It is hard to work for free - don't do it
Offline Fortran
« Reply #136 on: July 12, 2016, 02:22:00 pm »
Working for free is easy!
It's earning money that's hard :)
The following users thanked this post: johnmx, bitseeker
Offline ez24
  • L.D.A.
« Reply #137 on: July 12, 2016, 02:51:29 pm »
Are there some kits left?  If so do I PM for Paypal account info or you just tell me (and the price)
I am in the US
Offline Fortran
« Reply #138 on: July 12, 2016, 03:06:00 pm »
6 PCB's = 1.50 USD
There is only one 0.1% kit left and 12 of the 1% kits.
If demand remains I'll order more resistors.
Boards are pretty much infinite.
The following users thanked this post: LeonV
Offline LeonV
« Reply #139 on: July 12, 2016, 03:35:19 pm »
Ill be getting some in the coming weeks... once i have saved up my pocket money (A grown ass man saving pocket money  ::))
Damn forum is making me procrastinate from work!
Offline ez24
  • L.D.A.
« Reply #140 on: July 12, 2016, 03:41:09 pm »
6 PCB's = 1.50 USD
So 4  1% kits  =
4x1.5 = 6
4x1 = 4
subtotal  10
One  .1% kit
1.5 + 14 = 15.50
subtotal 15.50
ship = 3
total $28.50  for 4x 1% kits and 1x .1% kit? (5 kits total)   right ?
thanks
Offline Fortran
« Reply #141 on: July 12, 2016, 03:58:52 pm »
You've nailed it.
That means there are no more 0.1% kits left (assuming you pay and all that).
If anyone want one, drop a comment in the thread or PM and I'll order new ones if demand is close to 10 sets.
Offline ez24
  • L.D.A.
« Reply #142 on: July 12, 2016, 04:04:16 pm »
You've nailed it.
Do I need to PM you my address or does Paypal send it to you?
thanks
Offline Fortran
« Reply #143 on: July 12, 2016, 04:12:40 pm »
If you send as "family or friends", you'll need to PM or email me your address.
I like friends.. they don't cost me anything in transfer :)
Offline ivaylo
« Reply #144 on: July 12, 2016, 04:20:21 pm »
I'd be interested in 2 .1% kits when you have them. Thx...
Offline Fortran
« Reply #145 on: July 12, 2016, 04:29:36 pm »
Alright.  8 more and I'll order.
Offline ez24
  • L.D.A.
« Reply #146 on: July 12, 2016, 05:04:48 pm »
PM sent
thanks
Offline all_repair
« Reply #147 on: July 13, 2016, 01:18:30 am »
I have not studied the switch or the PCB.  For the thumbwheel switch, does the code type matters (BCD or Decimal) ?
Offline Fortran
« Reply #148 on: July 13, 2016, 01:19:19 am »
I've bought both.
Only the pcb differs.
Offline johnmx
  • Country: pt
« Reply #149 on: July 13, 2016, 01:22:53 am »
I bought this model (decimal):
I hope it is the correct one  :-\
Best regards,
johnmx
Offline Fortran
« Reply #150 on: July 13, 2016, 01:31:44 am »
It should be.
Mine are also 18x6.  :)
Depending on how you measure of course.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #151 on: July 13, 2016, 02:04:54 am »
Thank you Fortran,
PM sent and finished PayPal.
Offline gblades
« Reply #152 on: July 13, 2016, 02:47:18 am »
Payment send and I added a note with my address details.
Would these switches work. They appear to be the correct size.
http://www.ebay.co.uk/itm/291552388297
Thanks
  • Country: no
« Reply #153 on: July 13, 2016, 02:57:02 am »
Thanks
Looks identical to me.
MTBF ~ 700.000 h
  • Country: no
« Reply #154 on: July 13, 2016, 03:00:25 am »
MTBF ~ 700.000 h
Offline Fortran
« Reply #155 on: July 13, 2016, 04:17:36 am »
It's the correct one.
Now there's only 6 of the 1% kits left.
Orders that can't be sent will of course be refunded.
They sold out quicker then I expected :)
Offline Iwanushka
  • Country: lt
« Reply #156 on: July 13, 2016, 05:09:51 am »
How much for pcbs + 1% ( maybe you have 0,1% kits?) resistor kit and shipping in EU if I understood correctly I need 6 pcbs?
When all you've got is a hammer, everything starts looking like a nail.- Attrition.
Offline Fortran
« Reply #157 on: July 13, 2016, 05:12:23 am »
All the 0.1% kits are gone.
One 1% kit would be 5.50USD, including shipping.
Offline Iwanushka
  • Country: lt
« Reply #158 on: July 13, 2016, 05:14:57 am »
Do you plan on ordering more 0.1% kits with pcbs? Works case I would grab 1% one
Offline Fortran
« Reply #159 on: July 13, 2016, 05:30:46 am »
If there are enough people wanting them, sure.
A few more on the "0.1% waiting list" and I'll order some.
Offline Iwanushka
  • Country: lt
« Reply #160 on: July 13, 2016, 05:32:36 am »
Then please count me in for 2x sets (PCBs + 0.1% resistors)
Thank you!
Offline Fortran
« Reply #161 on: July 13, 2016, 05:39:55 am »
Great  :-+
That makes 4 and I'm somewhat confident that the rest of them will sell as well.
I'll probably order next week. Want to see that the ones I've sent arrive as planned :)
Offline Iwanushka
  • Country: lt
« Reply #162 on: July 13, 2016, 06:09:59 am »
Great  :-+
Cool, can you PM me when you make the order so I can pay upfornt (my memory is not that great these days)
Offline Fortran
« Reply #163 on: July 13, 2016, 06:22:39 am »
Neither is mine, but I'll try :)
Offline ez24
  • L.D.A.
« Reply #164 on: July 13, 2016, 06:44:27 am »
It should be.
What do you think of the 22x8 ones for future kits:
http://www.ebay.com/itm/Black-22mm-x-8mm-0-9-Digits-Decimal-Pushwheel-Thumbwheel-Switches-KM1-10-pcs-/261571657067?hash=item3ce6e2bd6b:g:CKcAAOSwdsFUN1Pi
Maybe easier to work on ?
Online bitseeker
« Reply #165 on: July 13, 2016, 07:17:19 am »
That's always a good thing. Thanks again for going to the trouble to make a bunch of these available as kits. :-+
Offline ebclr
Offline ebclr
« Reply #167 on: July 13, 2016, 09:50:42 am »
Payment for 28 boards sent
Offline LeonV
Re: 10 ppm 0.01%
« Reply #168 on: July 13, 2016, 10:15:54 am »
https://world.taobao.com/item/532210645700.htm?spm=a312a.7700714.0.0.XFEcUM#detail
Would the contacts from the cheap switches render such high precision useless? (I would have no idea, and don't have time to do the math right now)
Be interesting to see the precise values that a wheel would give with these.
Offline ebclr
« Reply #169 on: July 13, 2016, 12:33:13 pm »
Of course this will only happen on low ohms, if your lowest step is 10 ohms, the contact effect will be extremely low
Offline iromero
« Reply #170 on: July 13, 2016, 11:00:26 pm »
This is a great cheap project, i just ordered some boards and switches. I wonder what the tempco of the resistors in the kit is.
Offline Fortran
« Reply #171 on: July 13, 2016, 11:11:26 pm »
It's ±100ppm/°C
CRCW1206
The 0.1% was much better.
Also much more expensive for some reason :)
  • Country: no
« Reply #172 on: July 14, 2016, 12:14:41 am »
It's ±100ppm/°C
CRCW1206
Which 0.1% resistors did you use?
MTBF ~ 700.000 h
Offline Fortran
« Reply #173 on: July 14, 2016, 12:29:04 am »
A few different actually. The ones I linked in the beginning of the thread was out of stock. All have the same specs though.
±25ppm/°C
http://www.yageo.com/documents/recent/PYu-RT_1-to-0.05_RoHS_L_6.pdf
Offline Iwanushka
  • Country: lt
« Reply #174 on: July 14, 2016, 04:28:26 am »
±25ppm/°C
25ppm is quite good for this project, and switch resistance does not matter we can always use der ee 500 to check actual value,
I hope you will make new order soon :)
Offline m100
« Reply #175 on: July 14, 2016, 08:52:35 pm »
My kits have arrived, thanks Fortran and I love the fungi stamp   :-+
Offline Fortran
« Reply #176 on: July 14, 2016, 08:54:53 pm »
Great!  :-+
I was wondering when people would start receiving them.
Offline blackbird
  • Ooohhhh, what does this button do???
« Reply #177 on: July 15, 2016, 01:47:48 am »
Order some kits and resistor sets three days ago and received them today. Thank you Fortran ;-)
Offline Fortran
« Reply #178 on: July 15, 2016, 02:00:45 am »
You're welcome  :)
Let's hope everyone else gets theirs too.  :)
Offline JohnPen
« Reply #179 on: July 15, 2016, 05:31:54 am »
Mine arrived today as well.
Thanks Fortran will need to obtain some Switches now!
John
Offline johnmx
  • Country: pt
« Reply #180 on: July 15, 2016, 07:16:10 am »
I also received the boards today. It was a very fast delivery.
Let's wait for the switches now...
Thank you Fortran
Best regards,
johnmx
    • A.N.T. Audio
« Reply #181 on: July 15, 2016, 07:22:25 am »
I've received the boards today as well - thank you!
Alex
Offline ebclr
Offline Back2Volts
« Reply #183 on: July 15, 2016, 01:39:39 pm »
What a nice pot
https://world.taobao.com/item/41776086860.htm?spm=a312a.7700714.0.0.mrlItc#detail
At first look I they appear as ten turn pots, but are single turn with a glorified plastic dial.  Screw terminals.   In eBay/AliXpress are advertised as pots for motor control.   Not a good replacement for a decade box, but they may look good in some project.  For my hobby use I think it would be a pain drilling the 22mm hole.
  • Country: no
« Reply #184 on: July 15, 2016, 04:55:13 pm »
Also received mine yesterday, look good!
MTBF ~ 700.000 h
  • Country: no
MTBF ~ 700.000 h
Offline krivx
  • Country: ie
« Reply #186 on: July 15, 2016, 05:40:14 pm »
Mine arrived yesterday. They look great, unfortunately I won't get to put them together until next week.
Offline Fortran
« Reply #187 on: July 15, 2016, 05:53:55 pm »
Great!  :-+
When putting them together it takes some force.
I found that pressing down firmly with a flathead screwdriver right next to the pins/studs works pretty good.
It should snap in place.
Offline Dave
  • Country: si
« Reply #188 on: July 15, 2016, 11:02:08 pm »
Mine arrived today. And now we wait for the switches. :)
Offline Back2Volts
« Reply #189 on: July 16, 2016, 11:24:46 am »
Came today in the mail.   They look very nice.   Waiting for the switches but I will not be able to get to them for weeks.
Nice job Fortran  :-+
Offline gdewitte
« Reply #190 on: July 16, 2016, 11:25:17 am »
Received mine today. Now waiting for the switches.
Offline Back2Volts
« Reply #191 on: July 16, 2016, 11:36:14 am »
I recall that above in the thread, there was some dialog about possibly designing a box for the switches.   Did it get to anything concrete ?
Offline julian1
« Reply #192 on: July 16, 2016, 12:32:46 pm »
Paid for 2x 0.1 kits.
And just now read the post, that you're waiting to see if there's demand before for placing more orders.
I'm happy to wait, and no need to reverse the transaction (unless you're positively sure that there will not be another order).
Cheers,
Offline Fortran
« Reply #193 on: July 16, 2016, 11:29:27 pm »
I'm quite sure there will be another order of resistors, since most of the 0.1% are pre-booked already.  :)
I'll also be ordering another 50 sets of 1%.
However, the ones I ordered last is out of stock and replacements are slightly more expensive so I'm refunding you until I have the updated price.
Shouldn't differ much, but makes it a bit easier for me to handle.
So stay tuned for updates  :)
Offline Back2Volts
« Reply #194 on: July 17, 2016, 12:35:33 am »
Count me in for a 0.1% set
Offline Fortran
« Reply #195 on: July 17, 2016, 01:32:11 am »
Yeah..   I'm probably gonna need to buy more then 10 sets this time.  :)
I'll see how many I can afford to get.
So please everyone who still wants a 0.1% kit..  do tell.
1% isn't an issue since they are cheap, but 0.1% really digs deep in my pockets.
Offline Iwanushka
  • Country: lt
« Reply #196 on: July 17, 2016, 01:35:43 am »
Repost/Reminder
Please Don't forget my kits (2x PCBs kits with 0,1% redistors)
Thank You
Offline Fortran
« Reply #197 on: July 17, 2016, 01:46:04 am »
Yes yours have already been counted.
I'm referring to the ones that hasn't posted in the thread or sent me a PM :)
There might not be another order after this, depending on how many PCB's are left afterwards.
I haven't counted, but it looks like about half is gone.
Online bitseeker
« Reply #198 on: July 17, 2016, 04:56:03 am »
I see some US flags reporting receipt now. I guess mine will be showing up in the next few days.
Offline Back2Volts
« Reply #199 on: July 17, 2016, 02:06:50 pm »
I am in a small town in central Minnesota and received then yesterday.   I gather you are in the West coast.   You should get them on Monday.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #200 on: July 17, 2016, 03:49:17 pm »
Mine arrive Saturday also
Thank you very much and like others waiting on the switches now
Sandra
(Yes, I am a Woman :p )
Offline gblades
« Reply #201 on: July 19, 2016, 01:45:42 am »
Mine arrived today thanks.
Offline Fortran
« Reply #202 on: July 19, 2016, 02:02:29 am »
Great!  :-+
Offline Back2Volts
« Reply #203 on: July 19, 2016, 02:57:43 pm »
I received the switches today.   Ordered from Hong Kong July 7.   I think it is a fast delivery.   I am pleased because the set has the two mounting brackets.   Nice small things.
Now I am thinking about the box to mount it in and the connectivity.   The box, the smallest the better.   I am wondering if just two good quality plain wires through small holes with some mini clamps would be practical.
Any thoughts ?
Offline garnix
« Reply #204 on: July 19, 2016, 08:27:54 pm »
Nicely packaged! I think I order too much from AliExpress and I'm now surprised if I get something that nicely packaged  ;)
 I received my 3 packs last Friday - thanks!
Online bitseeker
« Reply #205 on: July 20, 2016, 03:26:50 am »
Yeah, no joy for me yet. But, I'll give it until the end of the week. Maybe someone scanned it, thought it looked like a very peculiar piece of mail, and now there's a crew behind blast shields opening it with a robot. ;D
Offline natman69
« Reply #206 on: July 20, 2016, 09:56:05 pm »
Please, can anyone suggest a reliable supplier for the KM2 switches?
This seller
http://www.ebay.it/itm/301726653090?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
can ship to Italy (out of eBay because of negative feedback from italian users) but at the moment the item is out of stock (and he answered that he must wait his supplier to produce the switches…)
while this seller
http://www.ebay.it/itm/291552388297?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
answered that he doesn't ship to Italy.
Thanks in advance!!!
Offline Back2Volts
« Reply #207 on: July 20, 2016, 11:42:17 pm »
I got mine here  http://www.ebay.com/itm/310827089552?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The ones I received have "book ends" not shown in the picture.   Not sure if it will ship to Italy
Edit: added a picture of the set with the ends.    I think that provided that the box where they are installed has a hole with snug fit, and the set of switches is bundled together with a tie or just some electrical tape, the set should snap in and stay in place securely.
« Last Edit: July 21, 2016, 06:16:18 am by Back2Volts »
Offline Blastcap
Re: Yet another resistance decade box
« Reply #208 on: July 21, 2016, 01:42:27 am »
Am i too late for the show?
Specifically a set of 6 with 0,1%, unsolderd.
Offline Fortran
« Reply #209 on: July 21, 2016, 02:38:56 am »
No you're not.
But I've sold out and need to order some more resistors.
I should be able to send some more kits around 1/8.
There will be a small adjustment on the price though, since the resistors I ordered last time is no longer in stock.
Offline Back2Volts
« Reply #210 on: July 21, 2016, 06:23:07 am »
Are all KM2 switches supposed to be the same size?    I am asking because the vendor I ordered from lists a KM2 set in white with size 22x8 instead of 18x6.   I think getting another set in white for the 0.1% I will be getting would be a nice way to differentiate them.
http://www.ebay.com/itm/10-Pcs-KM2-0-9-Digital-Decimal-Coded-Pushwheel-Switches-White-22mm-x-8mm-/230980234751?hash=item35c77eadff:g:KOwAAOSwjVVVlXPP
Offline PuterGeek
« Reply #211 on: July 21, 2016, 08:31:29 am »
No you're not.
I've thought you were all set with more 0.1% resistors so already sent my money and a PM. Let me know how much more I need to send.
Thanks!
PuterGeek (aka Joe Stockton)
Offline ez24
  • L.D.A.
« Reply #212 on: July 21, 2016, 01:29:17 pm »
Maybe Fortran can move up to 22x8 and since they would be easier to solder (if bigger SMD), he could sell these on a production basis. (until the Chinese make copies).  These seem to be a good item to have on a workbench and thus I think there is a market for them (think ebay)
Fortran why don't see if you can earn some money on this venture? (unless you do not need any)
Offline Back2Volts
« Reply #213 on: July 22, 2016, 12:57:35 am »
That was not the point I wanted to raise.   I am happy with the small size, because I believe, the smaller is the unit the closer to the test breadboard it can be placed, which in cases may be important.
What I was trying (no too well) to ask, is if there is an inconsistency between "KM2" and "22x8".   I thought KM2 implied 18x6, but I may have been wrong all along.
Offline Fortran
« Reply #214 on: July 22, 2016, 05:54:18 am »
My guess is that the seller doesn't really know?  :-//
16 or 18 is the correct height.
Offline Janne
    • Projects
« Reply #215 on: July 22, 2016, 06:18:53 am »
Sign me up for a kit of 0.1% :)
Nothing's as easy as drilling a hole in the wrong place
Offline ez24
  • L.D.A.
« Reply #216 on: July 22, 2016, 06:23:04 am »
Interesting.  I will order the large one and check it against the small one I ordered
Edit :  I found this large one and ordered it.
http://www.ebay.com/itm/10-Pcs-KM3-0-9-Digital-Decimal-Coded-Pushwheel-Switches-Black-31mm-x-10mm-/310668820375?hash=item48554dff97:g:YEcAAOSw9N1VpybP
« Last Edit: July 22, 2016, 06:27:21 am by ez24 »
Offline Fortran
« Reply #217 on: July 22, 2016, 06:29:02 am »
Will do!
It won't fit.  The board on that one is too big.
You can tell from the holes all being in a straight line.  On the correct one they go around the edges.
Well unless it's a BCD switch.
Online bitseeker
« Reply #218 on: July 22, 2016, 06:51:47 am »
Got my kits on the West coast. :phew: My first letter from Finland. :popcorn:
Thanks again, Fortran.
Offline Back2Volts
« Reply #219 on: July 22, 2016, 07:18:19 am »
I think you are right.   The seller has not ever touched or even seen the merchandise.   He is located in Hong Kong, but the shipment came direct from Shenzhen.   Before ordering I had asked him if he sold the end brackets and he replied no.   I was surprised when the black set came with the end brackets.    He must be a re-seller that forwards the orders to another outfit.
I will order the white ones for the 0.1% set which you will hopefully ship next month.   That way the 1% and 0.1% will look different.
Offline Fortran
« Reply #220 on: July 22, 2016, 07:45:57 am »
I think the gray ones are prettier :)
http://www.ebay.com/itm/391269356283
Offline smgvbest
« Reply #221 on: July 22, 2016, 07:50:40 am »
just for reference here's the 18x6 and 22x8 for comparison
Sandra
Offline smgvbest
« Reply #222 on: July 22, 2016, 07:57:47 am »
I've been playing around with a case design for the 18x6 ones.   it needs some tweaking and to actually be printed (and my 3D printer is awaiting a new hotend to arrive).   I can't print right now but here's what I've designed for a case.
100mmx60mmx25.4mm   (just a starting point,  like i said needs tweaking)
(edit,  actually a bit bigger, the square part of of it is 100x600)
designed to be stackable (magnets on bottom, countersink screws on tops)
setup for 4W on back (.75in spacing)
2 piece print
One tweak is I embossed the top by 1mm,   kinda messes up the stacking after I looked at it
fixed this by adding a 1mm recessed area then embossing by 1mm (see capture4)
Comments welcome, changes, tweaks all welcome.
happy to post STL to thingverse when done (or just here if preferred)
note:
i had a 10 decade thumbwheel and that's the dimensions I used.  it could be smaller for a 6 decade unit
« Last Edit: July 22, 2016, 09:12:43 am by smgvbest »
Sandra
Online bitseeker
« Reply #223 on: July 22, 2016, 09:14:48 am »
I like it, Sandra. What's the minimum length possible (i.e., would the case bump into the switches first or the binding posts)?
Offline ez24
  • L.D.A.
« Reply #224 on: July 22, 2016, 10:09:45 am »
Just an uneducated guess - but wouldn't the larger one be easier to work with ?  (I haven't got my goodies yet)
I wonder when the Chinese will read this topic and start making these?  Seems a really good item.  Who came up with this great idea?
Any other ideas what to do with these switches.  I am thinking about a combo lock
Offline smgvbest
« Reply #225 on: July 22, 2016, 11:24:09 am »
I'm have to figure it out for sure.
6 decades with end caps is ~42mm,  with my design I need at minimum 10mm total clear so figure 6 decades at 52mm width.
the 16x8 need about 29mm depth for the PCB then add rear jacks and some clearance. so I'm sticking with the 60mm deep and that may be cutting it close.
So here's a question
what is the preference for the jacks?
do most envision plugging bannana plugs in or test probes or bare wire?
I could make the rear a separate panel to allow for different options in the design (which thinking about it I think I will)
for me personally I'm probably going with these so my initial design will be based on them
http://www.digikey.com/product-detail/en/mueller-electric-co/BU-31610-2/314-1267-ND/4692920
Sandra
Offline Back2Volts
« Reply #226 on: July 22, 2016, 11:40:59 am »
I think those are the ones I call white.   That seller does not ship to US   :(    We must give bad feedback when they ship the wrong thing  :-DD
Offline all_repair
« Reply #227 on: July 22, 2016, 12:05:00 pm »
I ordered direct from Taobao china.  I came across a similar one but dare not order as it is 2mm shorter.  The one I came across has the signs, + and -, of the button painted red.
Offline Fortran
« Reply #228 on: July 22, 2016, 12:25:54 pm »
Time for another update:  :)
I have now ordered more resistors, and they should arrive by the end of next week.
The ones I ordered the last time where out of stock, so I had to change the price a little.
6 PCB's = 1.50 USD (or 0.25 each) Edit: ** Out of stock **
1% resistors kit = 2 USD Edit: ** Out of stock **
0.1% resistors kit = 16 USD  Edit: ** Out of stock **
« Last Edit: January 02, 2018, 11:52:27 pm by Fortran »
Offline Back2Volts
« Reply #229 on: July 22, 2016, 02:16:25 pm »
I have been thinking about the case for the last week or so.   I have come up with a few thoughts:
- The box has to be as small as possible so it can be close to the breadboard (or whatever) and not be an annoyance.
- Connections have to be as short as possible (some uses may require it).
- Connection binding has to be as small as possible.  If jacks, that would point to 2mm units.
- Digits have to be visible to operator while in use.
- Utility takes precedence over stylistic shapes.
With that in mind,  I am afraid I will have to design my own...    I am not trying to convince anyone.   I have put some (retirement) hours browsing eBay, Alixpress, Mouser, Digikey...
So, if I think I would be placing the unit(s) behind the breadboard, with digits facing me, then the connections would have to be as close to the front as possible.
If using jacks, because of their dimensions, they would be 2mm ones, and to minimize case size, they would have to be placed in the front face, left or right of the switch block.   But 2mm jacks are not that common on my bench, and a good jack may cost more than the rest of the box.  So, do I really need jacks?
I have mulled over if just a couple of good silicone wires coming out of the from wall (mini grommets?) would be enough, but I think some times I may need longer or shorter ones.
All the above is taking me to think that the best solution for me is to build some custom bolt based binding posts.   May be M3 Allen head, fork lug and washer on the inside; flat nut and acorn nut outside to receive wire with fork slug.   Both bindings vertically aligned can take around 12mm to 15mm of horizontal space in the front wall.
The switch block, with 6xswitches + 2xbookends, has a total width of 42mm, plus 2x1mm lips.   The height is 16mm plus 2x1mm lips. The switch depth with the new boards is short of 30mm plus the lip which will stay outside.
A box with inside dimensions of 60mm x 30mm x 16mm should do it.   Top and bottom overlapping except where the switch block is, where they move back to account for the lip.   Top and bottom tied with 3mm screws on the inside and nuts on top.
May be I can draw something tomorrow.
Offline julian1
« Reply #230 on: July 22, 2016, 03:56:05 pm »
Ordered 2x kits!
Offline PeterZ
« Reply #231 on: July 22, 2016, 05:05:53 pm »
I'm going to order the larger switches and design an MBB pcb for them, too. Since it will be larger, maybe a version for through hole resistors (higher wattage?) would be a good idea?
Anyway, glad to see my simple hack is getting popular! :)
Make sure you post some pics of your finished decade boxes.
Offline gblades
« Reply #232 on: July 22, 2016, 09:12:55 pm »
I would probably go for terminal posts on the back so I have a choice of bare wires or banana plugs.
For use when prototyping on breadboard it would be nice if the top and bottom had guides to hold a piece of strip board where a couple of bits of 2.54mm socket strip could be soldered. There could be a small rectangle hole in the front next to the switches where this could stick out to be flush with the front.
When you are prototyping on breadboard you could then just plug your normal jumper wires directly into the socket and the whole unit would be as close as you wanted to the prototype and visible. For other uses you still have the option to use the terminal posts at the back.
Offline gblades
« Reply #233 on: July 22, 2016, 09:20:11 pm »
There is a company very local to me who does 3D printing so if you have a finished design but can't print it yet I would be happy to get a test done and post photos etc... Here are the details of the printer they have :-
http://aaisp.net/printing-3d.html
They charge £0.30 per gram which I have no idea what the normal rate is. Any idea how much the case would weigh? I am guessing very little.
Online bitseeker
« Reply #234 on: July 23, 2016, 05:29:36 am »
Binding posts are pretty flexible when it comes to connection variety. That's what are on my IET decade boxes.
The RBox Mini only uses two posts and places them on the side of the enclosure, if I recall correctly.
Yeah, folks can choose which panel they want to print.
Would jacks require more internal space (i.e., larger enclosure)?
Offline ez24
  • L.D.A.
Offline Back2Volts
« Reply #236 on: July 23, 2016, 06:25:39 am »
This is the data sheet for the above jacks:  http://muellerelectric.com/wp-content/uploads/DS-BU-31610-2.pdf
One of those jacks is about as long (depth) as the switches with the new boards; just a millimeter shorter than the switches and almost three times the width of one of the switches.   So, yes, if 4mm binding posts are used, the size of the box increases significantly.
It all depends on what one values more:   To have the flexibility to use any kind of 4mm connectivity no matter how bulk it becomes or to compromise with dedicated wire/lead solution for the benefit of smaller footprint.
FWIW I just came back from the local hardware store with some 6-32 screws(~3mm), nuts, washers and knurled nuts.   May be I will post a picture.  I am looking for the smallest footprint possible.   I will splurge in a two position 2.54 female header for straight breadboard use.   I can always snap a 4mm  crocodile clamp on the knurled nuts.
I have a piece of 2mm clear acrylic somewhere in the garage, but have no fancy tools to deal with it other than the 10" table saw, which is very much like a cannon for the flimsy sheet.   Still scratching my head as to how to approach the building.
« Last Edit: July 23, 2016, 06:27:40 am by Back2Volts »
Offline Back2Volts
« Reply #237 on: July 23, 2016, 06:33:06 am »
How about something like this
http://www.ebay.com/itm/Keystone-5010-Test-Point-PC-multi-purpose-Red-lot-of-96-pieces-/142033934902?hash=item2111e1da36:g:KqMAAOSwc1FXahMX
and use alligator clip end wires
At was looking at similar test points yesterday.   They sure are small.   It would be a compact solution.   A custom wire with a one of those small wire clamps and whatever, pin, jack or clamp on the other end.
Offline ez24
  • L.D.A.
« Reply #238 on: July 23, 2016, 06:41:05 am »
Ebay  ?
\\http://www.ebay.com/itm/20pcs-brass-Banana-Socket-Jack-Binding-Post-FOR-4mm-BANANA-Plug-/151247841828?hash=item233712ea24:g:gDYAAOxy0NtTF7hM
Offline smgvbest
« Reply #239 on: July 23, 2016, 06:51:57 am »
Made a few updates,  still basically the same but the front and back panels are now replaceable so different combinations can be done.
This box isn't going to make everyone happy.  this is as flexible as possible and stable.
it's stack-able so you could have multiple decades boxes all handy.
will accommodate up to a 10 decades including end-caps
5mmx2mm magnets on bottom and those match up to the screws on top (5mmx2mm because I have a bunch  ;) )
The depth accommodates most binding posts and I'm using 8mm (.313in) holes which seem to be common)
Still waiting on hotend for me printer
FWIW, it's estimate is 75G of material to print.
Sandra
Offline Back2Volts
« Reply #240 on: July 23, 2016, 07:05:15 am »
Ebay  ?
Those could possible be mounted on a side with relatively less increase of the box size because it seems a large part of the piece is on the outside.
Online bitseeker
« Reply #241 on: July 23, 2016, 07:44:05 am »
Cool. One adjustment to the front-panel label: "MOhm" instead of "mOhm". Lowercase 'm' is milli- vs. capital 'M' being mega-.
Nothing makes everyone happy. This is good and can be further modified by someone to suit their individual needs.
Offline ez24
  • L.D.A.
« Reply #242 on: July 23, 2016, 08:18:41 am »
Is someone making a case for these switches for sale?   Or is the talk just about personal cases?
Offline gblades
« Reply #243 on: July 23, 2016, 08:24:50 am »
My switches arrived today and I soldered and assembled them. The pcb's are a perfect snug fit.
« Last Edit: July 23, 2016, 08:30:04 am by gblades »
Offline smgvbest
« Reply #244 on: July 23, 2016, 08:31:16 am »
Thanks for the catch,   fixed it
Quick edit
Here's case with a 6 decade (as ordered from Fortran.
Another edit:
here are 2 stl files,
1. for a 6 decade with endcaps
1. for a 10 decade with endcaps
Had to zip them as the site doesn't permit stl files
if anyone wants to do a test fit that has a 3d printer let me know how they fit
since its a test a 30% or less infill would be recommended to save filament and time.
hopefully my hotend will be here Saturday or Monday
« Last Edit: July 23, 2016, 12:46:47 pm by smgvbest »
Sandra
    • A.N.T. Audio
« Reply #245 on: July 23, 2016, 09:00:40 pm »
Yesterday I've received the switches and built two 4 decade assemblies (100 Ohm steps) for my alignment cassettes recording setup - to adjust the bias voltage and recording current accurately. I've used MELF 0.1% 15ppm (Vishay MMA series) resistors, as I've found these very stable and consistent.
Cheers
Alex
    • A.N.T. Audio
« Reply #246 on: July 24, 2016, 06:37:33 am »
Ordering more boards!
Just paid for 3x 6 pcbs only.
Thank you.
Cheers
Alex
Offline rudika79
« Reply #247 on: July 24, 2016, 06:42:46 am »
Money sent for 12 boards
Rudolf
Offline smgvbest
« Reply #248 on: July 24, 2016, 08:25:54 am »
didn't reply to those questions
I'm not using binding posts in mine but the space inside the box would easy allow for them
there's all kinds of binding posts/banana jacks I choose some longer ones on purpose to allow for most fitting options.
Sandra
Offline smgvbest
« Reply #249 on: July 24, 2016, 08:57:38 am »
Just orders more PCB's and a 1% resistor kit.   already have others I need
Sandra
Offline Back2Volts
« Reply #250 on: July 24, 2016, 03:21:16 pm »
Fortran , just sent payment for one 0.1% set
Tony
Offline Fortran
« Reply #251 on: July 24, 2016, 03:32:38 pm »
No worries. You're on the pre-order list :)
I'll send it as soon as the resistors arrive.
Btw.. has anyone from the first run not gotten theirs yet?
Offline ebclr
« Reply #252 on: July 24, 2016, 05:31:50 pm »
Could you please confirm the shipment of my boards
Offline Fortran
« Reply #253 on: July 24, 2016, 06:03:40 pm »
Sure.
Send me a PM with your name and/or adress and I'll check.
I can't find an order here on the forum so I can't connect your username to a shipment :)
Offline Back2Volts
« Reply #254 on: July 26, 2016, 07:36:11 am »
Just sent Paypal for the two additional
Offline ez24
  • L.D.A.
« Reply #255 on: July 27, 2016, 10:52:18 am »
Just got mine in So Calif.  Got the boards out of the switches.  Now to see if I can solder SMDs
Offline Fortran
« Reply #256 on: July 27, 2016, 07:40:04 pm »
After some digging I finally found which order is yours, and yes. It was shipped on July 13'th.
It should have arrived by now. Maybe it got stuck in customs?
If it doesn't turn up soon I'll send you another.
Offline cucumbers
« Reply #257 on: July 27, 2016, 09:44:51 pm »
My kits have arrived in Australia. Look very nice, now I just need to get a few sets of the right sized thumbwheels. Cheers Fortran!  :-+
Offline ez24
  • L.D.A.
« Reply #258 on: July 28, 2016, 07:25:45 am »
Yes thanks - good for senior citizens
Offline johnmx
  • Country: pt
« Reply #259 on: July 28, 2016, 07:57:52 am »
Got my switches today. Tomorrow I'll assemble the kit and show some pictures.
Best regards,
johnmx
Offline ez24
  • L.D.A.
« Reply #260 on: July 28, 2016, 11:05:10 am »
whew
Just did my first board.  First time with these really small SMDs.  Like training fleas.
It is a really bad job.  The resistors are sticking up at all angles so no pics. |O
I snapped in the board with no problems and it holds strong.  Checked with a meter and it works  :-+
Just curious there are 10 resistors.  Is the 10th resistor an extra?   I think I am counting right??   I just have tweezers and a cheap 25w iron and reading glasses.  No fancy stations.
Shaking now so I will have to wait until tomorrow and try another one.  I started with the 100k set.
I would like to know if I need to tin the pads fist before I try another one.  Tinning the pads makes the resistors not lay flat.  How about tinning one pad so the solder makes it stick flat, by pushing down with the tweezers while soldering, then solder the other end without tinning it?
Going to order another set of switches tonight.
Good job, how many people worked on this job?  Thanks Fortran
thanks
Offline LeonV
« Reply #261 on: July 28, 2016, 02:34:51 pm »
Got the boards + resistors yesterday   :-+
All the way in New Zealand.
Now to buy the pushwheels..
Will try these:
But will need to save up, so wont be too soon.
Offline Fortran
« Reply #262 on: July 28, 2016, 03:22:58 pm »
Yes the 10th resistor is extra. In case you flick one off the table :)
The 0.1% strips are only 9 though, because of the much higher price.
Tinning one pad and sticking down the resistor before soldering the other pad is a very good way to do it.
Using only an iron you might want to use as little solder as possible just to make it stick, then come back after soldering the other side and just touch it up with some fresh solder to make it flow nicely.
Heating too long makes the joint lumpy and ugly.
If you're ordering another set, let me know if you want me to solder it for you.
Two people worked on this.
PeterZ drew the board and posted the design files, and I ordered them in enough quantity to make them affordable for everyone.
Offline ez24
  • L.D.A.
« Reply #263 on: July 28, 2016, 04:00:08 pm »
Tried another board by tinning one contact.  Had a 7 out of 9 failure rate.  I could be only the "3" digit, in other words only 1 and 2 work.
My 4 power glasses are not powerful enough so I cannot see if I have a cold joint nor do I know which one is the third digit.
Also the board would not snap in, is was too wide.  I solved this by making a very small bevel with a razor blade and it snapped in.  So for now on I am going to make a small bevel on the switch and on one side of the circuit board.
It might be possible to do one contact at a time if I had a small tip and solder.  It is very hard to get in to solder (the ends) with the large (used to be small, I think 1/8") iron that I have.  So I will go back to tinning both pads first and put up with tilting resistors.  If it is good enough for the Italians it should be good enough for me.
Also it is good to have an extra resistor.  One stuck to my iron and dropped as I moved the iron.  These things are so small they evaporate as they fall through the air.
Has anyone come up with a trouble shooting guide using via to via resistance readings?  I cannot see the traces.  In other words how can I find No. 3.  I am wondering if there is a No. 3 ?  I wonder if it depends on how the switch goes together.  In other words maybe 3 one time but 5 the next time??
thanks
Offline Fortran
« Reply #264 on: July 28, 2016, 04:59:30 pm »
You shouldn't need to trim anything to make it fit the switch, but I guess there may be slight variations in batches.
I found that pressing down firmly right next to the pilot holes using a 5mm wide flathead screwdriver worked really well.
If it still won't cooperate you can try sanding the edges a bit.
Attaching a layout of the board.
If you have problems with No. 3, you probably have a solder-bridge to the via that goes underneath it.
Check if it's shorted.
Offline garnix
« Reply #265 on: July 28, 2016, 05:39:04 pm »
Will try these:
I got those as well - seem to work. Just be aware that there are no end-caps.
BTW, is there a seller who sells end-caps for those wheel switches?
Offline all_repair
« Reply #266 on: July 28, 2016, 11:12:41 pm »
Thank you Fortran.  Got my 6 sets of PCB and 5 sets of resistor kits.  I felt bad that you must have taken so much time to pack them so nicely.  And thank you Peter for the PCB work.
I have used an electrical conduit plastic as the enclosure.
« Last Edit: July 28, 2016, 11:17:54 pm by all_repair »
Offline ez24
  • L.D.A.
« Reply #267 on: July 29, 2016, 02:39:56 pm »
I spotted that one of the vias under 3 had solder in it.  I bought 6 sets for 2 set of switches, so now I am down to 5.  I cannot fix it.
I pre-tinned my next board and was very careful of the vias and did a decent job of soldering BUT 100 % failure.  Did some random continuity checks plus I found a 10x magnifying glass and everything looked ok.  Was about to give up when I thought the "fingers" could be the problem.
I bent up the fingers and it worked, every range OK.  Now I have two boards done  :-+
Getting experience with these SMDs.  My feeling is god did not intend for humans to use these things.  Tomorrow I am going to try #3 (1k)   :-+
Once again I want to say thanks to everyone that put this project together, and especially to Fortran for selling the kits.  I am thrilled at 68 I can solder the damn things. (and see them)
I will admit I am not clear how I wire the switches together (series ?).  I think so far there is only one picture and I do not get it.  I hope people will start posting pictures so I can figure it out.
Again I really appreciate the work of the members who put this together, I am having fun.
Offline johnmx
  • Country: pt
« Reply #268 on: July 29, 2016, 06:46:31 pm »
As promised here are the photos.
ez24, you can see the connections in my pictures.
An easy way is to use two long rigid wires. Put all switches together and insert the wires through all switches.
Now solder all the pads except the two pads where the external wires go. After that just cut the wire according to the picture.
Best regards,
johnmx
Offline ez24
  • L.D.A.
« Reply #269 on: July 29, 2016, 06:59:58 pm »
Thanks
Your soldering sure puts mine to shame  :-DD
Just curious - what soldering set up do you have?  Do you pre-tin the pads?
Offline johnmx
  • Country: pt
« Reply #270 on: July 29, 2016, 08:00:51 pm »
I have this soldering station:
http://www.jbctools.com/cd-2bc-soldering-station-for-general-purposes-product-710-category-1.html
It can heat up in less than 2 s. It's amazing.
More about this:
http://www.jbctools.com/heating-system.html
And I use this microscope:
http://www.optikamicroscopes.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=254&virtuemart_category_id=5&lang=en
I do soldering since 12 years old. So I have a lot of experience in this matter.
I can get the same results with a normal soldering iron and no microscope with SMDs down to 0805.
With the microscope I can solder very well 0402 components.
About the soldering, there are several videos in the internet, but some are completely wrong. So be carefully.
What I do is the following:
- Put some solder in one pad of each footprint. Don’t put too much, it’s better to have little less than too much. Do this for all footprints.
- Now pick up the component with a good tweezer using your left hand (if you are right-handed). Place it over the footprint without releasing the component. This insures that the tip of the tweezer is higher than the bottom part of the component. If you release it, just make sure about this when you hold it again.
- Now with the component in place, heat the pre-soldered pad with the iron and press down the component while the solder is liquid.
- Remove the iron, wait some seconds. Could be 2, 3 or 5 s, it depends on how much heat you applied to the pad.
- Release the component by opening the tweezer.
- Put the tweezer on the table and hold the soldering wire (solder) with your left hand.
- Solder the other(s) pad(s) of the component.
 - If the first pad was not very well soldered, you can put a little more solder on it.
That’s it.
Some tips:
-   Don’t use “Free Lead Solder”. It’s much harder with this new type of solder.
-   Apply some flux to the pads if the solder is not fixing well to the pad or to the component. I prefer liquid flux and apply it with a small brush. I buy the flux in big bottles and put it in an old nail polish container (see the attached picture).
Best regards,
johnmx
Offline gblades
« Reply #271 on: July 29, 2016, 08:28:55 pm »
Normally I would tin one pad and then pick up the resistor with tweezers and melt the solder on the pad again and move the resistor into position. Then solder the other end. Apply some flux to the 1st joint and touch it with the soldering iron to reflow it.
However when I assembled mine I dabbed a little solder paste on the pads and stuck down the resistors and then flowed the solder using a hot air gun. I did that mainly for practice and it generally worked well apart from putting too much paste on the first board and getting a short under one of the resistors. Easy to remove with a hot air gun though.
I use a jewellers headband with a built in light and different magnification lenses that you can clip in. It works and preserves your depth perception so way better than the 'helping hands' with a built in magnifier but still a poor comparison to a proper microscope but then again they are a lot cheaper!
Offline ez24
  • L.D.A.
« Reply #272 on: July 30, 2016, 04:53:59 am »
That’s it.
This is what I did on the last one, and it works great  :-+
Nice to know I am doing it right
A fast heating iron is high on my list, my biggest fear is I will forgot that I plugged in my iron because it is so slow, I usually get distracted.  I try and set the timer on my phone (if I can remember)  :-DD
Thanks
Offline ez24
  • L.D.A.
« Reply #273 on: July 30, 2016, 04:59:01 am »
.. and getting a short under one of the resistors. Easy to remove with a hot air gun though.
I am going to save my "bad" boards just in case someday I get a hot air gun.
I found my jewelers headband, this is how I determined that board #2 had solder in the via and #3 was ok (the switch was bad)
Offline smgvbest
« Reply #274 on: July 30, 2016, 05:33:48 am »
In the FWIW area on soldering
I use one of these
https://www.circuitspecialists.com/Hot-Air-Soldering-Station-Power-Station-Plus.html
and one of these to apply solder paste
https://www.tindie.com/products/marjan_mike/electronic-solder-paste-dispenser-v5-air-freeair-/
the use the the hot air gun set to the reflow temp of the solder and move it back and forth over the boards.
done in no time.
Sandra
Offline johnmx
  • Country: pt
« Reply #275 on: July 30, 2016, 07:40:00 am »
Fortran, in order to prevent shorts during soldering I recommend you to make tented vias next time (no solder mask opening).
ez24, if you have a short circuit you can desolder the resistor (keep heating both sides 1s at a time until the resistor gets loose), remove the excessive solder on the board with solder wick and solder the resistor again.
Best regards,
johnmx
Offline ez24
  • L.D.A.
« Reply #276 on: July 30, 2016, 11:28:52 am »
I will try this if I run out of boards.
Did another one today successfully but ugly. The problem I have is leaving "whiskers" when I lift the iron.  I always have to go back and try and level them.  Sometimes I can and sometimes I cannot.
I have a question: what do people do with the standoffs?  When I started, I trimmed off all three, then I tried just the center, then I tried not to trim any.  Without trimming any I got the board out ok but I could not get the new one in.  In fact I destroyed the switch trying to get it in.  So I went back to just trimming the middle one BUT it seems the middle one is the most important to keep the switch wipers touching the board.  Just curious on what others are doing.
When I am done and before I assemble them, I think I will take a hot needle and press down in the center of the ones that I cut to make them spread out a little.
Vias
It seems to me, with a 10x glass, that the vias at 2,7, and 9 are actually touching the pads, whereas in the picture they do not.  I am afraid to test with a meter because if they are not touching, the probe would probably make it contact (it is that close). I try very hard to keep solder away from the via and it seems to work.  Comments ?
Offline Fortran
« Reply #277 on: July 30, 2016, 03:37:45 pm »
Whiskers can have a few reasons.
Heating too long burns away the "wetness" and solder clings instead of flows.
Is your tip clean?  It should be silvery and shiny.
If it is..  have you tried adding flux?
If it still won't cooperate.. try a different/better solder. The cheap stuff is usually a nightmare to work with.
What's the dia on your solder? It might be too thick and that's no good either.
Standoffs:
You only need to cut the two. Use a scalpel or box-cutter to cut them flush to the board.
The vias on 2, 7 and 9 are connected to those pads, so a short there does nothing :)
It's only the one under 3 that's a potential risk of shorting.
Offline ez24
  • L.D.A.
« Reply #278 on: July 30, 2016, 04:34:18 pm »
--> I do not think this is the problem, I do not spend much time on the pad
-->  Yes I clean it each time I use it
--> I will order a flux pen, I do not have any
--> I use Dutch Boy, I think it is good  (but very old maybe 50yo)   I will order some new solder - Kester
https://www.amazon.com/KESTER-SOLDER-24-6040-0027-Stand-Diameter/dp/B00068IJPO/ref=sr_1_7?s=hi&ie=UTF8&qid=1469859605&sr=1-7&keywords=rosin+core+solder
--> Very small, my guess .5 mm  The Kester is .031", which sounds very small to me
Standoffs:
--> now that I think of it, it is probably better to cut the pair and leave the center.  I will try that on the next one
--->  :phew:  this will help a lot. I was trying very hard not to get solder near the edge of the pad
So far I have done 3 good ones and 1 bad one  :-+   Not bad for an old fart.
thanks a lot - this will help
Offline Fortran
« Reply #279 on: July 30, 2016, 05:08:45 pm »
Yeah that might be it.
Solder usually have an expiration date. It's probably fine a decade or so after that, but still. If it's 50 years old it wouldn't harm to try a fresh one.
I've never used Kester, but from what I've heard it's good stuff.
0.031" is about 0.78mm.  That's quite thick for SMD.
I'd go for 0.5mm or smaller just to have better control over the amount of solder you're putting on.
If you want to I can send you some 0.3mm, 0.5mm and 0.7mm to compare.
Offline sq9nje
« Reply #280 on: August 01, 2016, 08:08:56 pm »
Hey Guys,
I just ordered 3 sets of boards with 1% resistors. The switches will probably take ages to arrive though...
Przemek
Offline Fortran
« Reply #281 on: August 02, 2016, 12:10:01 am »
Thanks Przemek.  It's been shipped.
Update:
The new resistors have arrived!
But the pre-orders grew during shipping so I'm already out of 0.1% kits.
So, ONLY 1% kits are available at this time, but I have plenty of them.
Offline johnmx
  • Country: pt
« Reply #282 on: August 02, 2016, 12:28:55 am »
Here is the finished decade box.
I used an old lithium battery box.
The overall size is rather small: 114 x 52 x 20 mm.
The banana connectors keep the box closed without using any screws.
The parasitic resistance is around 0.5 Ohm.
Best regards,
johnmx
Offline Fortran
« Reply #283 on: August 02, 2016, 12:50:31 am »
Nice and compact  :-+
Offline sq9nje
« Reply #284 on: August 02, 2016, 02:28:23 am »
Man, you're fast! Thanks Fortran! Will report back when I receive them.
Online bitseeker
« Reply #285 on: August 02, 2016, 04:13:34 am »
That is excellent, johnmx! Looks good and is very compact.
You don't acquire TEA. It acquires you.
Offline Blastcap
« Reply #286 on: August 02, 2016, 11:20:38 pm »
Doing some last minute shopping, could anyone confirm that these will fit?
http://www.mouser.de/ProductDetail/CHERRY/PBC1-E015/
Its a 10 pack from "Cherry", they can't be too bad.
EDIT:
Don't buy these... they won't work!
« Last Edit: August 09, 2016, 06:37:45 pm by Blastcap »
Offline BFX
  • Country: sk
« Reply #287 on: August 04, 2016, 02:46:39 am »
Just got mine two sets   8)
Waiting for switches.
Thank you  :-+
Offline Janne
    • Projects
« Reply #288 on: August 04, 2016, 05:27:30 am »
2 sets received today, very neatly packaged!! thanks  :-+
Offline Fortran
« Reply #289 on: August 04, 2016, 05:45:30 am »
Great  :-+
Happy to see that everyone seems pleased  :)
Offline ez24
  • L.D.A.
« Reply #290 on: August 04, 2016, 08:58:56 am »
I got better at soldering, the main improvement was to hold the iron on the pad for about 2 seconds before adding solder (to prevent whiskers)   Now I have gone from 10% success to 90% i :-+
I got a sample of the "big" switch and I like it.  It is easier for me to use.  I thought maybe I could wire up external caps and make a cap decade box BUT it is a BCD switch.  I never saw one of these.  I assume you need TTL logic to make it work, but I wonder if some sort of decade box could be made with it without TTL or MCU?   Maybe I should start a topic on it.  Does anyone have any ideas?  thanks
Again I want to say thanks Fortran for this project.  The professional quality was a surprise.
YouTube and Website Electronic Resources ------>  http://www.eevblog.com/forum/other-blog-specific/a/msg1341166/#msg1341166
Offline Back2Volts
« Reply #291 on: August 04, 2016, 01:25:40 pm »
...  I thought maybe I could wire up external caps and make a cap decade box BUT it is a BCD switch. ...
There are at least two variants of the switches I know of,   BCD and (straight) decimal.   Just because I was looking for different colors ones I ended up ordering some decimal and some BCD.
Offline ez24
  • L.D.A.
« Reply #292 on: August 04, 2016, 01:46:41 pm »
Thanks I will look for a large decimal switch.
Offline Narmaraktuk
« Reply #293 on: August 04, 2016, 04:51:09 pm »
Just received a well-packaged set from Fortran. Many thanks!
    • A.N.T. Audio
« Reply #294 on: August 04, 2016, 07:20:26 pm »
I've received the second packet as well - thank you!
Cheers
Alex
Offline gblades
« Reply #295 on: August 04, 2016, 11:25:37 pm »
I would have thought BCD might actually be better for a capacitor box due to the way you stack capacitors in parallel to combine the capacitance.
With a digital output you would need 1 of 1nf all the way through to 9nf. With a BCD output though you only need a 8nf, 4nf, 2nf and 1nf. The 1,2 and 4nf you can make up by stacking capacitors side by side or on top of each other of there is enough room. The 8nf then is a bit more awkward as 8 caps are a bit too many to stack but even so it does make it simpler and reduces the number of different value capacitors you need to purchase.
Offline Fortran
« Reply #296 on: August 05, 2016, 12:21:13 am »
Here's my box :)
They're both supposed to be short, but I broke my last M2 tap on the first hole  :palm:
Can't screw it together until I get a new one so I'm using an uncut box until then.
Offline Back2Volts
« Reply #297 on: August 05, 2016, 02:45:52 am »
Fortran, nice!     What are the dimensions of the box, 60x55x25 ?    Is the body just one tube piece?   How do you cut it?    I was thinking about running an aluminum box through my 10" table saw, but it kind of scares me :-//
Offline Iwanushka
  • Country: lt
« Reply #298 on: August 05, 2016, 03:49:32 am »
Here's my box :)
Nice boxes, do you mind sharing a link to them?
Offline Fortran
« Reply #299 on: August 05, 2016, 04:28:32 am »
It's 80x50x20
http://www.ebay.com/itm/172255252886
But I cut it down to 60x50x20 with a metal band saw.
Mine looks like this:
But a regular vertical one would work too. Just screw it together first so the pieces are aligned, and cut slow and carefully.
The endplates where cut with my CNC mill, because I'm too lazy to do it manually :)
Online bitseeker
« Reply #300 on: August 05, 2016, 05:03:28 am »
Those look great, Fortran!
Offline Iwanushka
  • Country: lt
« Reply #301 on: August 05, 2016, 05:05:44 am »
Got the package, thank you!
Now need to check the thread and find out which switches to order
Offline blackbird
« Reply #302 on: August 05, 2016, 05:40:21 am »
I don't know if anyone already asked but where can I get end plates or caps for my Km2 pushwheels? Anyone got a good source? Got some without the end caps, usable offcours, although I would like to have them with the caps.
Offline Fortran
« Reply #303 on: August 05, 2016, 06:11:37 am »
The one I linked a few pages ago came with endcaps.
I haven't found any place to buy them loose.
Offline ez24
  • L.D.A.
« Reply #304 on: August 05, 2016, 06:16:04 am »
You probably will have to buy new switches with end caps and use those.
Offline krivx
  • Country: ie
« Reply #305 on: August 05, 2016, 06:31:36 am »
I have a feeling that the BCD and decimal switches are mechanically the same, only the PCBs are different.
Look at the pattern of traces for this BCD switch:
« Last Edit: August 05, 2016, 06:33:46 am by krivx »
Offline Fortran
« Reply #306 on: August 05, 2016, 06:37:02 am »
Yes they are the same switch.
As I mentioned earlier, I bought both and only the pcb differs.
Offline ez24
  • L.D.A.
« Reply #307 on: August 05, 2016, 06:47:01 am »
Fortran - there was some talk of decade capacitor boards, any new news?
Again thank you, I am learning how to solder SMDs
Offline ez24
  • L.D.A.
« Reply #308 on: August 05, 2016, 06:56:34 am »
Here is a completed switch on ebay, I think using a big switch:
http://www.ebay.com/itm/Seven-decade-resistance-box-0-1-0-ohm-to-9-999999-Mohm-resistor-substitution-/152192192192?hash=item236f5c8ec0:g:stEAAOSwaB5Xjkud
I wonder if by a member.
Edit - there are more sellers than this one
« Last Edit: August 05, 2016, 07:47:55 am by ez24 »
Offline Fortran
« Reply #309 on: August 05, 2016, 07:02:16 am »
ez24:  Well I've had my hands full with these boards and a coffee monitoring system for work.  :)
I'm not even sure if I'll ever get time to make them, but since I want some for myself it might happen eventually.
Offline ez24
  • L.D.A.
« Reply #310 on: August 05, 2016, 07:51:38 am »
umm   a coffee decade switch -  goes to one million cups ?
Deliver and counts the coffee beans?  Seems endless possibilities
Offline PeterZ
« Reply #311 on: August 05, 2016, 04:47:15 pm »
I just got a set of KM3 switches. A new through hole version is to be expected in the near future.
Here's the comparison in size against the KM2:
Offline garnix
« Reply #312 on: August 05, 2016, 05:44:49 pm »
Wow those are big - nice  8)
I don't know if I'm the "outlier" but looking at all switches (including the ones I bought) I was wondering why the "+" button is on the bottom and "-" is on top? Instinctively I would have done it the opposite... (Up = +, Down = -) but anyway  :-//
Offline Fortran
« Reply #313 on: August 05, 2016, 05:52:51 pm »
My guess:  So you can see it increment.
Pushing the top button covers the window with your finger. Pushing the bottom doesn't.
Offline sq9nje
« Reply #314 on: August 05, 2016, 06:16:55 pm »
Received my kits today. Beautifully packaged indeed. Guess I know what I'll be soldering during the weekend :)
Przemek
Offline BFX
  • Country: sk
« Last Edit: August 06, 2016, 04:33:29 am by BFX »
Offline ez24
  • L.D.A.
« Reply #316 on: August 06, 2016, 05:38:49 am »
I have an dilema about the case :)
First choice is much small one.
http://www.ebay.com/itm/New-Aluminum-Box-Enclosure-Case-Project-electronic-for-PCB-DIY-100-100-48MM-/331174761868?hash=item4d1b8dd58c:g:iFAAAOxyrrpTfXRx
Second one is little bit different
http://www.ebay.com/itm/Desktop-Aluminum-Enclosure-Project-Box-Case-DIY-4-33-3-27-1-57-0-75-L-W-H/380867568516?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D2%26asc%3D20131003150253%26meid%3De1e988d906274c408ca17d56461141ef%26pid%3D100034%26rk%3D2%26rkt%3D8%26sd%3D401162940032
and I decided pull outside each decade output to have like divider.
What do you think about it? (I'm prepared to have also ground connected to case)
Can I ask how are you going to cut square holes for the switch.
FYI  this message is the first one I have seen with its own scroll bar because of the link
Offline Back2Volts
« Reply #317 on: August 06, 2016, 05:48:52 am »
Wow!  Those KM3 switches are like twice the size!   Very big.   I think I like better the small ones, although have not yet tried to solder the kits I received.   I still need to go through the learning experience like EZ24 has been doing.
Offline ez24
  • L.D.A.
« Reply #318 on: August 06, 2016, 05:57:44 am »
Actually the large one is easier to use because the buttons are larger thus easier to get your finger on it.  But this has been a fun project and I am sure you will have fun like me.
I think I lack one thing (it is on order) is solder paste.  I think with solder paste, the SMD would lay flat, then I could tack solder it then go back and add solder.  I saw this method by watching a video on pick and place machines.  The video said the board had solder flux added to it first in order to stick the SMDs to the board.  Once I get the paste I will let you know how it goes.
Offline BFX
  • Country: sk
« Reply #319 on: August 06, 2016, 07:06:40 am »
Already prepared to finalize :)
Thank you Fortran  8)
« Last Edit: August 06, 2016, 07:08:15 am by BFX »
Offline Blastcap
« Reply #320 on: August 08, 2016, 08:29:55 pm »
Depending on the tools available, CNC milled would be the most elegant overkill solution.
Make a cardboard prototype, to ensure you have the right cutout, and everything fits, then mark the cutout on the faceplate, and drill a hole in each corner. Cut the lines between with a Dremel or other tool.
Then with a square jeweler's file, make the corners... square.
Finish by chamfering the edges slightly with a file or sandpaper so you won't cut yourself.
Mount, and enjoy.
If done right, everything will snap into place and fit snugly, and there will be no need for "hotsnot" or other adhesive.
« Last Edit: August 08, 2016, 08:31:39 pm by Blastcap »
Offline all_repair
« Reply #321 on: August 08, 2016, 10:26:02 pm »
KM3 still with SMT resistor but no protruding PCB and a provision to tap out 2 resistance end point.  Just end-cap and hole on end-cap for connection, and no need for ENCLOSURE.  possibile?
