Just curious - what soldering set up do you have? Do you pre-tin the pads?
I have this soldering station:
http://www.jbctools.com/cd-2bc-soldering-station-for-general-purposes-product-710-category-1.htmlIt can heat up in less than 2 s. It's amazing.
More about this:
http://www.jbctools.com/heating-system.htmlAnd I use this microscope:
http://www.optikamicroscopes.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=254&virtuemart_category_id=5&lang=enI do soldering since 12 years old. So I have a lot of experience in this matter.
I can get the same results with a normal soldering iron and no microscope with SMDs down to 0805.
With the microscope I can solder very well 0402 components.
About the soldering, there are several videos in the internet, but some are completely wrong. So be carefully.
What I do is the following:
- Put some solder in one pad of each footprint. Don’t put too much, it’s better to have little less than too much. Do this for all footprints.
- Now pick up the component with a good tweezer using your left hand (if you are right-handed). Place it over the footprint without releasing the component. This insures that the tip of the tweezer is higher than the bottom part of the component. If you release it, just make sure about this when you hold it again.
- Now with the component in place, heat the pre-soldered pad with the iron and press down the component while the solder is liquid.
- Remove the iron, wait some seconds. Could be 2, 3 or 5 s, it depends on how much heat you applied to the pad.
- Release the component by opening the tweezer.
- Put the tweezer on the table and hold the soldering wire (solder) with your left hand.
- Solder the other(s) pad(s) of the component.
- If the first pad was not very well soldered, you can put a little more solder on it.
That’s it.
Some tips:
- Don’t use “Free Lead Solder”. It’s much harder with this new type of solder.
- Apply some flux to the pads if the solder is not fixing well to the pad or to the component. I prefer liquid flux and apply it with a small brush. I buy the flux in big bottles and put it in an old nail polish container (see the attached picture).
