My Most Stupid (and Costly Mistake), Warning, EXTREMELY CRINGEWORTHY
Customer supplied a decent size Variable Speed Drive (Inverter) for one of their Oil Circulation Pumps (A large Oil Factory).
Ok, So install an outdoor enclosure, isolator, run the 3 Phase 400V Supply. Then check that the Inverter supply must connect on the bottom right of the Inverter, with the Load on the bottom Left. Ok? that seems opposite to convention. Double Check it according to the Manual, yep that is the way it is supposed to be.
Guess What I do? Yep, Even after double checking, I went and hooked the supply up to the left, and the load to the right.
Switch on the Isolator, and there are Sparks, Flames and Smoke. Completely destroyed the Output Stage of the Inverter, as well as the main control board. ZAR15000 Later for a new VSD, I have learned my lesson. I now check it 5 times, and also have my helper double check...
