After collecting some 18650 batteries, I've noticed a lack of smart Open Source battery management systems.
I've begun to tinker with the idea of wifi connected Arduino monitoring large packs of batteries and regulating series cells. (3S 40P, etc)
(before anyone says it, LiIon and LiPo's love exploding when you mistreat them.
The goal here is to design a management strategy which safely contains their angry pixies.
Extreme caution + testing should be used with such a BMS as outlined below.)
I've been researching this stuff and have come up with the following design ideas:
* Arduino monitoring voltage of each series
* Main relay N.O. and held closed by Arduino GPIO to help prevent pack damage if Arduino is offline.
* Voltage > 4.2v , turn on a resistor (relay controlled) connected to the impacted series to drain (able to dissipate max charge current?) the excess voltage to 4.2v.
* Any series voltage < 3.10v , main relay (large, full pack current+voltage) turns off.
* Voltage applied to relay > total voltage, re-enable pack.
* Current monitoring
* Each series vs the whole pack?
* Turn off main relay in over-current situations.
* Temperature monitoring?
* Turn off main relay in over-temperature.
I think the rules above cover the most critical aspects of keeping a large group of LiIon's healthy... thoughts?
I've started writing some Arduino code here:
https://github.com/kallisti5/erisbmsSome great resources:
