Thanks, yes, and if you have an SMPS with chunking big hardware and heatsinks, then nice super-tight layout like you can get with low power SMD designs just isnt possible....so do you find yourself compensating by damping the switching transitions and adding shielding copper pours over the switching node copper?.....i mean , if you have buckets of current, then you simply cant reduce the area of the switching node that much.
