No - if you don't increase the voltage to the first peltier it willl still only pump 12W with a 10C delta. That's where you have been going wrong. The water can now be cooled by 20C but the flow rate will have to be halved to .5l/hr. As you say, the second peltier will move 12W + 3.69W, requiring 4.83W (at a COP of 3.25) so outputing 20.52W to the copper block. Total electricity supplied is 3.69W + 4.83 = 8.52W
I know I'm not great at explaining things but I was sure my example was quite clear.
Your example was clear enough, it was just that you made a mistake when you analysed the effect of the second peltier.
When I added the second peltier element the hot side of the first peltier element has dropped from +27°C to +17°C provided by the cold side of the second peltier.
Each peltier element will pump around 12W (ignoring those IR losses) and those add up if the hot face of the first peltier is in contact with the cold face of the second one.
Yes but the bit you keep missing is that they are the same 12Ws so they don't add up.
Same as if you inverse the current flow on one of the peltier you cancel the work of the first one.
So you either have the Qc1 + Qc2 or Qc1 - Qc2 and in case Qc1=Qc2 the you have either 2xQc or you have zero in the second case.
If you have two of those cheap peltier module you can do the experiment but is not necessary since it should be obvious.
The peltiers don't generate any power - ignoring their I^2R and thermal resistance losses, they simply transfer the power that's passed to their cold side to the hot side but increases the temperature. Higher temperature does not equate to more energy or power out than was put in. So if you have 5 in series you still only get 12W out of the hot side - each peltier passing on the 12W whilst increasing the temperature by 10C. The 12W that comes out of the last was the 12W that was passed into the first from the water. An analogy is a human chain passing along a bucket of water, where each person heats up the water by 10C but pours some away before passing on exactly the same thermal energy they received. Alternatively the first person gets a load of paralleled batteries. They rearrange the batteries so some are in series and passes it on. The total energy in the batteries doesn't change but the output voltage increases at each step. So you don't get QC1 + QC2, you get QC1 only.
They don't remove or destroy energy or power either so QC1 - QC2 != 0. If you reverse the second, both will pump heat from their cold faces to the joined hot sides. That heat would have nowhere to go so the hot sides will get hotter and hotter until they destroy themselves. As the hot side gets hotter, and their cold sides remain at constant temperature, their COP reduce and the amount of heat they pump will reduce but not probably not enough to avoid damage. Consider this configuration as two peltiers in parallel with their hot sides connected to a common (very poor) heatsink but their cold sides connected to heatsinks at different temperatures and thus operating at different delta-T.
I'm an EE so my knowledge of thermodynamics is limited but I'm smart enough so that if I'm wrong you will be able to explain where I'm wrong to me and so far I see no problems with my understanding of how a two stage heat pump will work.
I also have no problem admiring when I'm wrong since that is not something uncommon.
I expect that's more likely to be one of D. Trump's many interesting characteristics
I also think my first analogy with water pumps was not that bad so you should look at that one again if you still do not get what I'm saying.
The height delta there is the equivalent of temperature delta here.
In your analogy the water gains height and thus potential energy. Peltiers increase the temperature but don't increase the energy. Consider them more like transformers which change the voltage but not the power of a signal.
With the first stage you do half of the work by moving 12W of heat and with the second stage you take that work already done and move another 12W.
Not
another 12W, the same 12W. The second peltier can't pump another 12W as the only heat available for it to pump is that delivered by the first. It can't create energy, it can only move it from the cold side to the hot side whilst transforming the temperature.
So the total output is 12W plus the heat losses in the peltiers. It's really quite simple to calculate the COP - its the total heat moved from the input, cold side divided by the amount of electrical power used. The COP usually shown in peltier datasheets relevant for cooling performance where the heat out is a waste product and is better described as COPcooling. In cases like yours where the heat out is what you are after, COPheating is relevant and is the total heat delivered to the hot side dived by the electrical power used.
With one peltier the output is 12W + 3.69W = 15.69W; COPc = 12/3.69 = 3.25; COPh = 15.69/3.69 = 4.25
With two peltiers the output is 12W + 3.69W + 4.83W = 20.52W; COPc = 12W/(8.52) = 1.41; COPh = 20.52/8.52 = 2.41
The COP almost halve when delta T doubles from 10 to 20C
For an EE analogy consider a 12W, 12V 1A power supply driving a 12W constant power load. The power supply is the 12W that comes from your cold water, the voltage is analogous to the water temperature. Now add two 100% efficient 10V voltage boost convertors in series. The output voltage is now 32V but it still can only deliver 12W. The voltage/temperature has been increased by the boosters/peltiers but they don't add or subtract any energy/power.
To model the peltier I^2R losses, add constant power, power supplies in series with the output of each booster, the first set to 3.69W and the second to 4.83W. Reduce the boost voltages so that each stage still only increases the voltage by 10V (so the output is still 32V) and increase the load's power to 20.52W.[/quote]
So in the example with one stage you will be able to cool 1liter of water with 10°C lower than hot side you can call that ambient (the huge copper cube so that the small energy transferred will not influence the cube temperature).
When you add the second stage that has sufficient power pumped to cool the hot side of the first stage 10°C lover than the huge copper cube it is almost like if there was a single stage but the copper cube had just +17°C instead of +27°C
Yes the water will be 10C below ambient with one stage, 20C below with two stages. But the energy extracted from the water will be exactly the same in both cases - 12W - so you will have half the quantity of water in the second case after any given amount of time.
Hope that helps.
