Hi
Can I just check that in an offline SMPS in UK,EU,USA, the primary to secondary conductor creepage distance should be >=8mm?
We have a student with us whose father is a Top Expert Chief Power Electronics Engineer, and he says the rules have just changed and its now 5mm.
Also, this student has layed out a 70W Offline Flyback for us. He has L,N & E connections to the primary mains input connector. The earth is then tracked onto the PCB and picks up the Y capacitors at the primary side. ...Also, this earth copper is then tracked to the primary FET heatsink PTH's to which the plastic TO220FP FET is affixed. However, he has then continued to track this earth on the bottom layer from primary to secondary side. First this earth connects to the secondary diode heatsink’s PTH holes. (TO220 diode). Then this earth continues throughout the secondary side where it connects to a PTH to which the earthed metal “cage” is soldered into. This cage is “holy” and is to reduce radiated emissions as it kind of “box covers” the top PCB side of the entire SMPS.
[EDIT.................
…So, the earthed copper is on primary and secondary sides. However, on both primary and secondary sides this earthed copper tracking/pouring is less than 1mm away from primary and secondary metal conductors.
So, the earthed copper is on primary and secondary sides. However, on pri side, this earth tracking is 2mm away from a pri side trace, and on the secondary side, this earthed trace is 0.5mm away from the secondary side traces..............EDIT]
He says his father told him that all this is right and the regs have just changed.
However, do you agree this is not the case, and his SMPS is very bad?
