Someone was expecting a more dramatic fuse blow. I pulled out the second fuse I found after it didn't buzz out.
Here it is.
Yep, that's vigorously blown! The only stage above that is where there isn't any glass left either.
So, was that fuse contained in opaque shrink-tube? If not, then there's the flash you saw.
Also those RIFA caps are the death-caps others & I have mentioned. The hairline fractures let in moisture, which kills them. ALL those type caps should be replaced when found.
However, it's quite unusual for them to show no visible sign (or smell, did you sniff them?) of the kind of failure than can blow a fuse like that. Btw, try them with a multimeter. You might find one short circuit. But even if all are 'open', it doesn't prove they are blameless. They can short out, then do much the same as the fuse - burn back to open circuit.
However we still don't know for sure it was one of those caps that shorted. After replacing all these and the fuses, it would still be a good idea to power up with a bulb as current limiter.
