Replaced the MOSFET (red circle and the adjacent MOSFET) along with the fuse and it repeated itself.
You need to make yourself a dim bulb tester and stop needlessly torturing semiconductors.
Just get a mains lead, put a bayonet cap socket in series with the active wire and plug in a small wattage lamp somewhat larger in value than the idle current of the device under test. You'll get the lamp flash brightly as the main filter cap(s) charge up and then it'll settle down to a nice dim glow. Of course, if you have a semi-frying fault the lamp will generally continue to glow at or near full brightness, but limiting the current to a value that generally will prevent the smoke coming out.
Also good for reforming capacitors on old Valve kit that has been idle for more than a couple of years, and with the addition of a diode, making a "get me out of the poo" battery charger.
I have an assortment of lamps from about 5W up to 100W. Much nicer than hitting the power switch and ducking for cover as things explode.
