2 Samsung 24 inch monitors, bought new and with a 5 year warranty. Both failed about 2 weeks out of warranty. One was left running 24/7/365 and the other was switched off ( with a real power switch on the front of the unit, no soft switch here) at the end of each day. In both units the line output transistor was shorted, due to the line output transformer breaking down. The LOPT was no longer available as a spare part ( though I could actually get the 24 inch CRT complete with scan coils as a spare and they had stock of it) as it had been discontinued 4 years ago. Apparently they simply gave you a new monitor of the same or next bigger size if they failed under warranty and it was not a dead CRT. Burns were not covered, and these large CRT's were very easy to burn if you left the brightness high with a static image.
