Hi guys - I have a decent (supposedly) quality dual port LiPo battery charger. I mainly use it to charge 3 cell LiPo's but have found cell#1 on port 2 is always balanced lower. I have calibrated both ports with a decent meter (to the mV).
The charger is a Thunder Power TP820CD. I have had a look inside and I know that this charger is essentially two discrete chargers. I can see the two banks of through hole 10 ohm 1% load resistors (for discharge as well as balancing ?? I am not sure) and a bunch of surface mount resistors used in the voltage divider parts of the circuit.
I am thinking that the low resultant cell voltage on cell#1 is because (maybe) the resistor tolerances are not so great. I was thinking that if I could narrow down the locations of the resistors used in measuring the individual cell voltages I could replace them with lower tolerance items.
I have attached a pic of the board. Port two is on the right hand side and the balance lead plug is the white external connector on the right side. The uppermost pin (pin 1 in picture) is ground and the next pin down (pin 2 in picture) is cell#1. I haven't taken the board out of the case and given it will be a multilayer board I assume that because I can't see the trace for cell 1 it may be underneath.
The battery packs are in series so cell 1 voltage is measured between pin 1 and pin 2, cell 2 voltage measured between pin 2 and pin 3 etc.
Not sure if it's worth investigating but thought it would be fun to give it a go. Happy to pull the board all the way and get pics of the PCD traces.
I don't know 100% how the circuit works but the LiPo charger has a built in balancer the compares each cell voltage and attempts to keep them balanced. This charger can handle an 8 cell battery, looking at the board there are opamps there that I assume are being used as comparators ? Each side (left / right) has its own discrete set of balancer components.
Can anyone help !! I would like to keep this charger and given cell balancing on port #1 (left side) is spot on I know it has the potential (no pun intended
) to be a good unit.
