Hi lartsu,
Just an idea.
Are the coils the same?
They do look from the pictures, but they could be different. You are probably in a better position to answer this question.
If they are the same, I would remove the bad one and a good one as well, and would measure the good coil.
Again, this is just by looking at the pictures.
Good luck, Peter
