Ian.M. - Once again, I would like to thank you for the thought and time you put into your replies in this thread.
1 - Regarding copper foil: I haven't yet done trace repair replacement using copper foil vs just soldering jumper wires. I look forward to it. There are some copper foil tape rolls with conductive adhesive out there (such as
This one), however I assume it is better to get a sheet of it, cut it to size with a razor, and apply to a clean, de-traced area using an epoxy of some sort.
2,3 - Excellent. Will do that after the repair work is complete, then. It lets me test prior to that step as well.
4 - OK. The manual for the motherboard says that a replacement battery can be hooked up to J1 (4 pin header that I am also replacing) and be from 3V to 4.5V. I considered that when I first saw the damage, but I thought about utilizing that empty space on the board for a 2032 instead. I do have plenty of space in the case to velcro a plastic 3xAA holder and use the 4 pin header as the motherboard manual recommends, so perhaps I will stick with that.
Regarding securing the repair wires to the board - It sounds like from what you said that the PCB lacquer will help with that as well? Was considering using
this silicone conformal coating, but there is also an acrylic lacquer (keyword)
here. I assume the acrylic is much more forgiving and the better option? (You did use the word "lacquer," afterall.
Just wanted to talk a bit more about it since I don't own either)
Although each comes with a brush cap, I prefer your Q-tip suggestion for a more rigid application with minimal spread. Do you typically use something different for securing wires during a repair when only wires are needed, or is conformal coating/pcb lacquer typically a multi-purpose coating/securing tool? Most wire repairs I have done to this point have been minimal length and just float. I would indeed prefer to do a neater job on this one.
