Author Topic: Difficulty repairing UC3842 power supply...  (Read 12451 times)
Offline dave_kTopic starter
« on: August 14, 2017, 12:45:21 pm »
Was recently asked to look at a small switchmode power supply to repair.
Initial diagnosis was blown mains fuse (2A), shorted FET and failed TL3842 controller. Dead semiconductors were replaced, along with 2 small electros on the primary side.
Applied power (via isolation transformer and 100W series bulb). 100W bulb glowed briefly confirming main filter cap charged up, however no output voltage was measured.
After some probing and measuring it appears the 3842 is not starting up, pin 7 not reaching the 17.5v needed to begin operation (measured a peak of ~14v).
Feeding 18v from an external supply into pin 7 causes the 3842 starts up and the supply runs. During operation, pin 7 has between 10.5-11.5 volts present (coming from the AUX winding supply).
The start-up supply for the 3842 is a little unusual in this design. Instead of a resistor from the main DC rail, a small capacitor is connected to one leg of the incoming mains (used as a voltage dropper) then rectified by a pair of diodes. The value of the cap is 0.22uF which has a reactance of about 15k ohms at 50Hz.
All other components on the primary side have been individually checked and tested OK.
My question is what would be stopping this supply from starting up normally?  :-/O
Reverse-engineered schematic:
(secondary side has been omitted, it's a bog standard TL431 driving the opto).
« Last Edit: August 15, 2017, 01:35:54 am by dave_k »
Offline Armadillo
Re: Difficulty repairing UC3842 power supply...
« Reply #1 on: August 14, 2017, 12:52:54 pm »
Have you replaced the 0.22uf?
« Reply #2 on: August 14, 2017, 12:55:13 pm »
Offline Armadillo
« Reply #3 on: August 14, 2017, 01:03:28 pm »
Would you be able to probe the aux supply?
« Reply #4 on: August 14, 2017, 01:09:15 pm »
At one stage D1 and D2 were removed. Starting the 3842 using a pulse of 18v external supply, pin 7 measured 10.5v after external supply was disconnected.
It appears the AUX winding is able to power the 3842 without difficulty (once it starts)..
Offline Armadillo
« Reply #5 on: August 14, 2017, 01:11:07 pm »
Maybe the secondary needs to be loaded?
« Reply #6 on: August 14, 2017, 01:18:05 pm »
I thought this as well. Loading the output with 1A doesn't change the result .. still refused to start on it's own.
Once started, it can happily run and supply up to 3A. Voltage regulation is quite good, output dipping by only a fraction of a volt at this load.
Fundamentally the supply works, it just doesn't start. This is where I am stuck, there is something I am overlooking.  :-//
Offline kripton2035
« Reply #7 on: August 14, 2017, 01:26:08 pm »
I would replace C2
« Reply #8 on: August 14, 2017, 01:27:56 pm »
Already did that .. C2 and C4 both replaced.
Offline carl_lab
« Reply #9 on: August 14, 2017, 01:46:00 pm »
Are you sure your wiring of the optocoupler is correct (emitter is open)?
OK, you have corrected now...
« Last Edit: August 16, 2017, 08:41:32 pm by carl_lab »
Offline Armadillo
« Reply #10 on: August 14, 2017, 01:48:28 pm »
I am sure you have dig through the power supply and replaced all that can be replaced, except the aux windings.
The aux could be a bit nicked.
Maybe the short cut, would be to replaced the 0.22uF to something a bit higher, say try 0.47uf.... 0.68uf.... if you have the appropriate capacitors.
Just a suggestion.
Offline CJay
« Reply #11 on: August 14, 2017, 02:01:19 pm »
I reckon D1 should be a Zener and C2 should be a higher value, they're usually around 22uF-100uF, has someone else been in there first?
Offline xavier60
« Reply #12 on: August 14, 2017, 02:07:43 pm »
I notice there is no Gate to Source bleed resistor shown. With some versions of the UC382, the output pin stays in a Hi Z state while the IC is in UVLO state. If there is no Gate bleed resistor, the Gate eventually charges up, blowing the MOSFET again.
http://www.st.com/content/ccc/resource/technical/document/application_note/3b/42/e6/d9/78/47/4d/df/CD00003930.pdf/files/CD00003930.pdf/jcr:content/translations/en.CD00003930.pdf
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline xavier60
« Reply #13 on: August 14, 2017, 02:28:06 pm »
Leaky diodes often don't test bad with a DMM. I notice that when small glass diodes have corroded leads, they tend to be leaky.
The value of C2 seems unusually small.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #14 on: August 14, 2017, 04:01:25 pm »
Dang, full schematic capture?  Very nice! :-+
The 3842 is supposed to be off (<1mA supply consumption) until it kicks on.  If it can be powered by the startup circuit, it should more than start up normally.  That's your mystery to solve: what is sucking down all the current, or keeping the startup from delivering enough current?
I wonder if the 3842 has been damaged in such a way that it's very leaky, but still otherwise functional?
Seven Transistor Labs, LLC
Offline Kevin.D
« Reply #15 on: August 14, 2017, 06:43:16 pm »
Are you sure your schematic of the startup circuit is correct , ? The way it is shown it  only supplies a single startup current pulse on the first mains  cycle as C3 is initially charged  (so c3/c2 form a capacative voltage divider with C2 charging up-to ~ Vmains(peak)* C3/C3+C2).
Once C3 has charged it has no means to discharge hence no further pulses are available on following mains cycles.
If this is what is actually intended then the ratio of c3/c2 determines Vstart (and after a power down you would have to wait for C3 to discharge (shown here only possible via D2 leakage) before another startup pulse was possible).
The only other thing to check is if it's being dragged down like others suggested.
regards
« Last Edit: August 14, 2017, 07:14:58 pm by Kevin.D »
Online T3sl4co1l
« Reply #16 on: August 14, 2017, 11:38:58 pm »
Oh, yeah, that one diode is on the wrong side.  I hope?  :phew:
« Reply #17 on: August 15, 2017, 12:19:24 am »
Altium is good for something, right?  :-DD
Yes, and this is where I am getting stuck.
The schematic I posted probably doesn't tell the full story, the part numbers are of the original unit.
The SSP6N60A MOSFET (made by Samsung) was replaced with a IRFBC40PBF (Vishay). The original PWM IC was a Texas Instruments TL3842P, it has been replaced by a Texas Instruments UC3842N
One avenue of thought was the replacement MOSFET was unsuitable (thinking Qg was too high) and the 3842 was having difficulty initially turning it on. Comparing data sheets shows original MOSFET Qg is 77nC max, replacement is 60nC.
Original 3842 was replaced, plus I have tried 2 other 3842's from junked equipment - same result with each chip.
« Reply #18 on: August 15, 2017, 12:20:58 am »
Oops, yes - D1 is indeed connected to the anode of D2 (drawing error).
Original post has been modified with the correct schematic.
« Last Edit: August 15, 2017, 01:12:50 am by dave_k »
« Reply #19 on: August 15, 2017, 03:18:20 am »
UPDATE: problem found and fixed. Anybody want to have a guess at the solution?
Offline carl_lab
« Reply #20 on: August 15, 2017, 10:06:34 am »
Dead electrolytic cap?
Open soldering joint?
Some loose connection?  ;)
Offline oldway
« Reply #21 on: August 15, 2017, 02:19:41 pm »
What's the voltage on C2 ?
Offline xavier60
« Reply #22 on: August 16, 2017, 08:35:25 am »
Anything to do with the isolation transformer?
Offline mzzj
« Reply #23 on: August 16, 2017, 10:02:51 am »
Leaky diode
« Reply #24 on: August 16, 2017, 11:58:24 am »
Turns xavier and CJay were on the right path. After reading through a few data sheets and application circuits for the 3842 it was became obvious that C2 was too small. Increasing the value to 100uF allows the supply to reliably start.
Now another problem needs attention. With the supply running (even with minimal load) the MOSFET heatsink becomes quite warm after a few minutes.
Thoughts are either: 1) low gate drive and MOSFET not turning fully on, or 2) problem with snubber circuit.
Will try and capture some scope traces tomorrow..
« Last Edit: August 16, 2017, 12:00:41 pm by dave_k »
« Reply #25 on: August 16, 2017, 12:01:49 pm »
voltage is about 11.5V after increasing value of C2
Offline mzzj
« Reply #26 on: August 16, 2017, 12:11:07 pm »
I'm guessing you are talking about C3 value, not C2?
Offline xavier60
« Reply #27 on: August 16, 2017, 12:14:54 pm »
With C2 being too small, I would expect that the UC3842 would have been repeatedly making start attempts. There should have been some output voltage.
The 22 ohm gate drive resistor might have gone high causing sluggish switching of the MOSFET and higher dissipation.
« Reply #28 on: August 16, 2017, 12:28:51 pm »
Quite strange that there was originally only a 1uF cap there to begin with!
The 22 ohm resistor is okay, and substituting it for a 15 ohm resistor doesn't improve anything.
Offline xavier60
« Reply #29 on: August 16, 2017, 12:34:43 pm »
There is soft start circuitry on the Comp pin,1. So it is possible with  C2 being 1uf, the UC3842 might not have had a chance to produce any MOSFET drive before pin 7 drops to the UVLO voltage. Pin 7 might have been cycling between 16v and 10v and the multimeter reading some between average.
Offline xavier60
« Reply #30 on: August 16, 2017, 12:42:59 pm »
Take note of the operating frequency. It doesn't happen very often, I have seen the oscillator timing capacitor go low in value causing the switching frequency to go too high resulting in poor efficiency.
Offline xavier60
« Reply #31 on: August 16, 2017, 01:11:03 pm »
A shorted snubber might also explain all of the trouble.
« Reply #32 on: August 16, 2017, 01:18:30 pm »
Given the values shown in the schematic the operating freq works out to be about 115kHz. Again, typical application circuits show a normal value for Ct of 4700pF .. hmm.
I did check the snubber diode and resistor, they are okay.
Offline CJay
« Reply #33 on: August 16, 2017, 01:59:34 pm »
You may find that whatever is causing the MOSFET to heat up is also contributing to your starting problem because the aux winding on the transformer will also be affected by the same problem and of course that will affect startup/run.
But, the typical application of that chip sees C2 being powered via a high value series pair of resistors to a zener and capacitor, the capacitor is usually 22 or 47uF* and is almost always faulty.
(which is where my 'rule of thumb' law comes from, if it's got a 4 and a 7 in the value, it's faulty, yes, I've repaired a *LOT* of SMPSUs, hundreds a month for two or more years of my life)
« Reply #34 on: August 17, 2017, 02:04:05 am »
Couple of scope captures with no load on the PSU...
« Last Edit: August 17, 2017, 02:24:39 am by dave_k »
« Reply #35 on: August 17, 2017, 02:25:53 am »
.. and with load on the PSU
Offline tautech
« Reply #36 on: August 17, 2017, 02:48:23 am »
This is what worries me:
One can only assume the gate drive is sufficient to drive the gate to ON then apparently falls below the gate threshold.  :scared:
That needs further investigation.
Avid Rabid Hobbyist
Offline xavier60
« Reply #37 on: August 17, 2017, 04:21:32 am »
The gate and source are noisy likely because non ideal probe grounding which is difficult to do with SMPS circuits.
The MOSFET turn off seems sluggish. Does the replacement MOSFET have a lower gate threshold voltage than the original?
Extra:
Take note of the plateau duration on the falling edge of the gate waveform.
« Last Edit: August 17, 2017, 04:24:53 am by xavier60 »
Offline xavier60
« Reply #38 on: August 17, 2017, 04:32:04 am »
On second thoughts it looks like there is a high capacitive load on the drain circuit. The drain voltage is still rising after the gate has gone down to zero.
Online T3sl4co1l
« Reply #39 on: August 17, 2017, 04:40:06 am »
You have to take gate waveforms with a grain of salt.  It's not mentioned if that's at the 3842, or at the gate -- the gate resistor (if present), and trace length, makes a difference.  Probing technique is important.  Some transistors simply bounce, especially when ferrite beads are involved.
I measured a similar waveform on my LED lamp, which is the same basic circuit, when I recently fixed its EMI problem finally (it was buzzing in the shortwave band; I threw ferrite beads at the switching transistor and rectifier, and that did well enough for the improvement I was looking for).
« Reply #40 on: August 17, 2017, 04:44:06 am »
The waveform on pin 6 of the 3842 looks nice and square, so I'm happy the IC output is okay. Similarly the voltage on pin 7 is stable and free of ripple, so I'm fairly sure it's not being excessively loaded down either.
The datasheet for the original MOSFET states VGS(th) is 2.0(min) to 4.0(max) - VDS=VGS, IDS=250uA. Replacement MOSFET values are exactly the same.
Similarly for input capacitance, original is 1800pF (f=1.0MHz) replacement is 1300pF (f=1.0MHz).
I'm beginning to form the opinion that perhaps the AUX winding is damaged somehow, and can barely supply enough voltage to run the 3842 properly .. pin 7 is 11.4 volts, and factoring a 0.6v drop for the internal switching transistor doesn't leave much headroom to drive the MOSFET.
Datasheet for replacement MOSFET is attached...
Offline xavier60
« Reply #41 on: August 17, 2017, 04:56:33 am »
I'm starting to think that nothing it wrong. The 2 MOSFETs have comparable specs. The replacement has slightly higher Total Gate Charge which will increase switching losses by a bit.
The UC3842 does not do any Green tricks like burst mode, it drives the MOSFET at the same frequency regardless of load. So the switching losses stay high all of the time regardless of load.
Check the waveform on the snubber capacitor anyway, it should have only DC on it.
« Reply #42 on: August 17, 2017, 05:07:04 am »
Oh, I thought the replacement had a slightly lower total gate charge than original?
Original = 77nC (max) VGS=10V, ID=6A, VDS=480V
Replacement = 60nC (max) VGS=10V, ID=6A, VDS=360V
Offline xavier60
« Reply #43 on: August 17, 2017, 05:08:36 am »
11.4v is low considering that the UC3842 stops working at 10v. The UC3843 works down to about 8v.
Maybe the AUX winding is corroded. A resistance reading might show the problem.
Offline xavier60
« Reply #44 on: August 17, 2017, 05:13:38 am »
Yes,you are right, I was looking at the wrong part.
Offline tautech
« Reply #45 on: August 17, 2017, 05:43:26 am »
Or D5 is sick.
Avid Rabid Hobbyist
Offline IanMacdonald
    • IWR Consultancy
« Reply #46 on: August 17, 2017, 06:49:01 am »
Usual reason would be R11 (820k) gone high. You did lift one leg to test this? It can't be measured in circuit.
