Author Topic: Duracell CEF14N NiMH battery charger - need R28 value  (Read 1931 times)
Offline HogwildTopic starter
« on: November 18, 2017, 12:03:27 am »
Hi friends:
My Duracell CEF14N (the old model, looks like this) died a while back. See attached image for photo.
I opened it up and first noticed a bulging cap. Shame Duracell! I bought some replacement caps. Unfortunately, I didn't notice until now that the R28 surface mount resistor was burned. When I touched it, it disintegrated into dust and so now I can't see the value of R28.  I Googled, but found nothing at all on this charger, maybe because it's older.
Does anyone know what value and physical size that resistor is? I'd like to save this thing if I could. It was a great charger when it was working.
Thanks in advance.
Re: Duracell CEF14N NiMH battery charger - need R28 value
« Reply #1 on: November 18, 2017, 09:28:53 pm »
Update: It looks like the R28A resistor across from it also may be blown. It's hard to tell. I will report back my findings as soon as I get them.
Offline IanB
« Reply #2 on: November 18, 2017, 10:16:05 pm »
If it can only charge batteries in pairs I think I would retire it and replace it with a charger that monitors each battery individually. Pairwise charging was a cost saving measure that should not be needed in modern chargers.
« Reply #3 on: November 19, 2017, 03:54:46 am »
I prefer not putting things in the landfill. Plus, it's a challenge.
« Reply #4 on: November 19, 2017, 07:31:02 pm »
IanB:
Can  you point out any teardowns or analsyses of newer chargers which charge each battery individually? I'd like my next charger to last longer than this one.
Offline IanB
« Reply #5 on: November 19, 2017, 07:59:49 pm »
Forum member HKJ has a webpage with reviews of many chargers here: http://lygte-info.dk/
I personally own and use the Panasonic BQ-CC17. It is a smart, "overnight" charger which charges the cells individually and has good management of the charging process. I cannot say how long it would last, but Panasonic seems to be a reliable brand with quality products. I have other Panasonic chargers and they have all worked well (which is more than I can say for other brands of charger).
HKJ has a review of it here: http://lygte-info.dk/review/Review%20Charger%20Panasonic%20BQ-CC17%20UK.html
« Reply #6 on: November 20, 2017, 03:12:53 am »
I noticed that SMD resistors R28 and R28a appear to be burned or singed. Damaged, at least. Also, capacitor C5 on the beige side seemed be bulging a bit. I have extra capacitors, but no resistors. If I get some resistors soldered in, I'll post back and share my results.
Thanks for that site. Wow, that's unbelievable how many chargers and batteries he's tested.
Offline floobydust
« Reply #7 on: November 20, 2017, 03:17:05 am »
Another method is to find the controller IC datasheet/app notes/eval board and see what values are used.
« Reply #8 on: December 06, 2017, 03:35:17 am »
Okay, I got it fixed. In my case, it was a capacitor. I took some photos and wrote a quick guide on iFixit.
Duracell CEF14N nimh charger-not charging
https://www.ifixit.com/Guide/Duracell+CEF14N+NiMH+Battery+Charger+-+Not+charging/100409
