Author Topic: HP 6966A Lab Power Supply Manual  (Read 2463 times)
Offline SchnibbelwindTopic starter
  • electronic engineer student
« on: December 05, 2017, 06:20:27 pm »
I got my self an HP 6966A lab power supply in very good condition, from the dumpster ;D. But when I switch it on, it's output voltage jump to 60V. :bullshit: (The HP 6966A is a 0-36V and 0-10A power supply)
Now I'm trying to Fix it and a manual with an schematic could save hours :-/O
HP 6966A, 6965A, 6964A and Helmut Singer(Harrison) LVR 6367A are similar.
Offline oventech
Re: HP 6966A Lab Power Supply Manual
« Reply #2 on: December 06, 2017, 06:00:19 am »
Thank you for the link, but this model is far more modern than my.
The 6966A is from the 1970s, with SCR preregulation and GA-Transistor.
http://www.helmut-singer.de/stock/1373.html]
[url]http://www.helmut-singer.de/stock/1373.html
[/url]
Offline oventech
« Reply #3 on: December 08, 2017, 01:36:09 am »
Found this on the Power Supplies http://hpmemoryproject.org/an/pdf/an_06-65.pdf.
Offline oventech
« Reply #4 on: December 08, 2017, 01:45:33 am »
Sorry the link did not work. Looked up "HP 6699a Lab power supply" got to a reprint of a 1965 power supply application PDF. Covers features of the power supplies. Might give you an idea on yours. Hope it helps.
Offline JoeB83
  • Longmont, CO
« Reply #5 on: December 17, 2017, 04:02:46 pm »
If you remove the period from the end of the link it works just fine.
