Author Topic: Fluke 17b broken battery clip needs repair  (Read 8328 times)
Offline billbyrd1945Topic starter
« on: August 09, 2018, 01:13:19 am »
Do any of you know where I can get one of these clips or where I can send the meter to be repaired? Not having any luck finding such a place. Thanks for any help.
 Also curious to know why this particular post corroded. The other one looks fine.
Offline RobertHolcombe
Re: Fluke 17b broken battery clip needs repair
« Reply #1 on: August 09, 2018, 01:26:47 am »
Keystone 5230/5330 or 5231/5331 might work but they would require bending as the "foot" for want of a better term is facing the opposite direction
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #2 on: August 09, 2018, 01:29:46 am »
If the meter is covered under warranty then you will need to contact your nearest Fluke Authorised Repair Center and ask them, otherwise as mentioned above it might be easier just to make or modify a replacement contact out of similar material.
Images attached below to show others how this meter should look.
Offline retiredcaps
« Reply #3 on: August 09, 2018, 03:52:04 am »
Fluke 17B meant for sale in China only so warranty is likely a NO GO.
Keystone makes a variety of connectors.
http://www.keyelco.com/
I had a look through
http://www.keyelco.com/search-results.cfm?addsearch=aa+battery&x=0&y=0
but couldn't spot anything compatible?
Offline coromonadalix
« Reply #4 on: August 09, 2018, 10:36:43 am »
you could take this, and form / bend  them to suit your needs, a pack of 20
Ebay : 20Pcs Silver Tone Metal AA/A/CR2/9V Battery Positive Negative Contact Plate
https://www.ebay.com/itm/20Pcs-Silver-Tone-Metal-AA-A-CR2-9V-Battery-Positive-Negative-Contact-Plate/322872100874?
« Last Edit: August 09, 2018, 10:41:36 am by coromonadalix »
« Reply #5 on: August 10, 2018, 12:25:59 am »
Thanks to all who responded. I kept checking my email and found no replies. I changed my profile, so now I should get them. I took a copper strip from a doorbell and made a clip. See pics attached.  I thought I had fixed it since it worked fine before the clip broke. After replacing it, everything works but continuity. Any suggestions? Thanks.
Offline tautech
« Reply #6 on: August 10, 2018, 12:37:38 am »
That's ohms mode. To get to continuity use the yellow button to toggle through the 3 modes; Ohms, Diode or Continuity.
Avid Rabid Hobbyist
« Reply #7 on: August 10, 2018, 12:49:55 am »
i think you have shorted an long pcb trace passing nearby,  unsolder your "copper" patch and check the pad and the nearby pcb trace (s)
« Reply #8 on: August 10, 2018, 01:58:28 am »
"I think you have shorted an long pcb trace ..."
Ahh! That's the kind of suggestion I was hoping for. (I did try the various knob positions. It won't even beep in the continuity mode).
I'll remove the patch and hope for a fix. Got nothing to lose. Thanks much.
« Reply #9 on: August 10, 2018, 02:45:56 am »
Bummer. Didn't work. Here's a pic of my re-work.
« Reply #10 on: August 10, 2018, 02:53:40 am »
check the trace continuity, and if possible  clean all solder flux residues
Offline retiredcaps
« Reply #11 on: August 10, 2018, 03:44:15 am »
Yes, remove all that leftover residue so we can get a better clearer look.  I can't tell if it is the blurry photo, left over residue, but the area circled in red may not have continuity?
more from o.p.
« Reply #12 on: August 10, 2018, 03:08:37 pm »
Discovered before taking it apart again that it will measure 2.77k or 0.214m with leads shorted together. All other readings are either open line, or some other crazy value, and touching the probes in beep mode will not beep. Here is a better pic. I checked all the circled traces and found continuity. The green arrow points to one remaining smudge that I couldn't clean without fear of breaking the trace. I'm really appreciating the help and learning a lot as I go through this. I realize my Chinese 17b ain't much. But I hate to toss it just for something I'm over-looking.
« Last Edit: August 10, 2018, 09:46:10 pm by billbyrd1945 »
Offline retiredcaps
Re: more from o.p.
« Reply #13 on: August 11, 2018, 03:23:10 am »
Well, that definitely is a problem.
Does DCV work?  If you measure a 1.5AA cell, do you get 1.5?
Offline retiredcaps
« Reply #14 on: August 11, 2018, 03:26:10 am »
Using the picture supplied by Muttley above, using another working meter, what value is (ohms measurement)
1) RT1
2) the green fusible resistor just north of RT2
3) RV1, RV2 and RV3
« Reply #15 on: August 11, 2018, 02:18:22 pm »
First, thank you. I was hoping for some trouble shooting values but didn't know where to start. I'm meter poor and only had an old and cheap analog for backup. This is what I found. I'm guessing this is good news. But I'll defer to your conclusion.
RT1
1k scale: 1
x10 scale: 150
1ohm scale: 1k
fusible resistor
1k scale: 1
RV1: 1 ohm
RV2: open
RV3: 1 ohm
Offline retiredcaps
« Reply #16 on: August 11, 2018, 07:02:52 pm »
RT1
1k scale: 1
x10 scale: 150
1ohm scale: 1k
fusible resistor
1k scale: 1
RV1: 1 ohm
RV2: open
RV3: 1 ohm
RT1 is a PTC and should measure around 1k ohm.
fusible resistor is 1k ohm.
RV are metal oxide varistors or (MOV) and should all read open.
I suggest desoldering RV1, RV2 and RV3.  Measure them again out of circuit to see if RV1 and RV3 are completely shorted.
With RV1, RV2 and RV3 removed, does resistance measurement work now?  Try measuring a 100 ohm, 1k ohm and 10k ohm resistor.  Try shorting probes and continuity.
PS. BTW, you didn't answer what a 1.5V AA cell reads on DCV.
« Reply #17 on: August 11, 2018, 07:38:45 pm »
Disregard everything I've said. When putting the MOVs back in, I realized I had mistaken one leg of the green ceramic resistor as a MOV leg when I was first measuring them. They all measure open individually off the board and open when soldered in. Somehow I've lost my display, so-- for now-- I'll be trying to figure how I did that.
------------hours later----------------
Problem solved. Hereby summarized for the benefit of other hobbyists like me who only know what they've learned without the benefit of actual job experience:
1. Needed meter for first time in months.
2. Found it dead due to an oxidized and broken negative battery prong.
3. Made new prong with copper strip from doorbell.
4. Eureka moment when meter came back to life upon reassembly (beeped with button, display on, mains measured, etc.)
5. Smile turned upside down when I discovered meter would not measure continuity.
6. Reached out to EEV blog. Troubleshooting provided by retiredcaps.
7. I then reported erroneous values which lead to MOV removal.
8. Reinstalled MOVs but display gone.
9. Discovered display problem caused by unnecessarily removing screws when removing board from case.
10. Back to original problem. Became suspicious of home-made battery prong. The copper lacks spring-back characteristics such that installing the battery pack collapses the fold providing zero pressure from prong to battery. Just guessing of course.
11. See pic below for solution that gave me back my beloved 17b. (Just need a real prong)
12. I learned a lot from this. The value of forums like this cannot be overstated. I'm one happy camper. Thanks to all.
« Last Edit: August 11, 2018, 11:46:09 pm by billbyrd1945 »
Offline retiredcaps
« Reply #18 on: August 12, 2018, 11:53:57 pm »
So I'm confused?  Does resistance and continuity work now?
« Reply #19 on: August 13, 2018, 12:36:33 am »
"So I'm confused?  Does resistance and continuity work now?"
Yes. It's working fine. I took us down a rabbit hole when I measured the wrong solder points on the bottom of the board (the movs). That lead to taking them off for no reason. The problem turned out to be my homemade clip not making a good contact. Everything worked fine when the wires were soldered on to the battery. I reshaped the clip and everything worked fine. Thanks again for all your help!
« Reply #20 on: August 16, 2018, 09:52:34 pm »
I spoke too soon.
Everything does work, but leads together display about 10 ohms instead of 0. My 47 ohm resistors display 57 (that's how I discovered the problem). One megaohm is pretty dead on. Seems confined to lower resistance readings. Checked the leads, they're fine. Tweaked all 8 pots to no avail. Any help will be appreciated.
Offline retiredcaps
« Reply #21 on: August 17, 2018, 12:37:39 am »
Thoroughly wash and dry the entire pcb in IPA.  Use a soft toothbrush to scrub off any potential contamination from battery electrolyte leaking.
Dry thoroughly use a PC fan or let dry overnight (12 to 24) hours.
Retest.  If 10 ohms goes to 5 ohms, literally rinse with IPA and repeat.
Offline retiredcaps
« Reply #22 on: August 17, 2018, 12:39:29 am »
In all your photos, I see some sort of residue all over the backside of the pcb.  Remove rotary knob selector and lcd to get best IPA pcb cleaning.
« Reply #23 on: August 17, 2018, 03:15:12 am »
Will do.
« Reply #24 on: August 17, 2018, 04:06:37 am »
Eureka!
Sir, I owe you a beer if you're even down my way.
I apologize for thinking there was no chance in hell that cleaning would do anything other than make me feel better about it.
Gotta listen to the man, retiredcaps!
Actually, I did more than one thing, a no-no if you want to really know what's going on. At this point I just wanted the problem solved. So I joined the battery post on the second of two holes which I figured were just there for placement. Wouldn't hurt.
Cleaned everything spic and span with 91% IPA.
I suspect the grease behind the selector may have been the nasty of all places. Left it dry for now.
Check out the pics (Resistor is 220R).
Thank you so much!
Offline retiredcaps
« Reply #25 on: August 17, 2018, 04:31:26 am »
Any contamination on the pcb will affect the readings.
Offline Avinash lewis
« Reply #26 on: August 19, 2019, 07:24:46 am »
The Fluke 17B ans 17B+ battery compartments are badly made, Mine broke today, will open 17B+ this weekend and post the images, do not want to toss the Fluke in dump, one idiea is to solder the batteries and take the silicon wire
Offline mzacharias
« Last Edit: August 24, 2019, 05:59:58 pm by mzacharias »
Offline phormosa
  • Country: tw
« Reply #28 on: October 26, 2019, 03:33:32 am »
Another 17b+ failure here. Seems to be due to battery clip corroding and snapping off.
Fluke repair rep response:
Fluke-17B+  is low end product, we don’t provide repair service for this model,
It’s repair by replacement, suggest you to contact with to purchase a new one.
Online andy3055
Offline phormosa
  • Country: tw
« Reply #30 on: October 27, 2019, 10:06:25 pm »
Thanks.
In my case the failed contacts are the other end of the battery box.
I didn't see that piece on ebay.
They are single pieces for each battery and terminate in a springed tongue that contacts through with the PCB when everything is assembled.
Thinking of trying to craft a piece, however some of the plastic has degraded and I also notice discoloration on some of the circuit pads across the PCB.
Online andy3055
« Reply #31 on: October 28, 2019, 02:20:02 am »
Cut it into 2 pieces, file the edges and use it. All you want its the correct size and the "springyness" (if you know what I mean).
Offline phormosa
  • Country: tw
« Reply #32 on: October 28, 2019, 03:52:29 am »
Understand
The piece corroded on the other side of the battery holder (in two pieces), in addition to being springy for the battery also has two tongues that reach below the battery holder and establish contact with pads on the main PCB also with mechanical springyness
appreciate your ideas and input
