Rear Bulkhead Resistor
Yellow lead 748v
Series Pass
Collector Q8 137.5v
What is the part number of the bulkhead resistor on the schematic?
Have you noticed that there are 2 K1 relays? There is one in the preregulator ckts shown at the lower left on sh 1 of 332B-1001 and 1 in the interlock ckt shown on the right hand side of sh 2 of 332B-1001.
If the preregulator K1 doesn't pick up, there will be no high voltage from T2. There is still high voltage from T1 thru the bridge on the lower right on sh 1 of 332B-1001. This may be the source of the voltages you're measuring. Its purpose is to provide a minimum forward current thru the series pass ckt.
If interlock K1 doesn't pick up the negative leg from the HV ckts is disconnected from the output and you will read 0 or very low voltage at the output.
There are also 2 K2 relays. One is the 'crowbar' which throws a load across the HV capacitors to quickly lower the voltage. It is located a little below and right of center on dwg 332B-1001 sh 1. There is a N.C. K1 contact in parallel with the K2 crowbar contact. (I don't know which K1 relay but I suspect it's the interlock K1)
The interlock K2 is shown in 2 places. One is at the lower left of sh 1 dwg 332B-1001 (to energize the preregulator K1) and also in the interlock on the right side of 332B-1001 sh 2. This one allows energizing the HV supply if all the cards & covers are in place.
I haven't figured out how the interlock K1 & K2 get energized. The circuit description says that they are energized by Q3 on the series pass driver board when relay K2001 is energized in STDBY. The drawings that I have show the connections but interlock K1 has diodes connected in opposition and the 332 dwg (sh 2 of 332B-1001) has a single diode connected in reverse of what I would expect. A drawing error to check out the next time I open the beast.
My 335D 'buzzes' when it is in current limit. The protection circuit trips on high voltage (as it should) and limits current on a short circuit (as it should).
Do you get any current reading on the meter?
Here are the 332 drawings I'm working from. They are from the April 1972 Rev 1 3/75 332D manual. (P/N353292) Do they match your unit?
I have 2 sets (1971 & 1978) for the 335 and a 4th set made up of a mix from 332/335 drawings that seem to match my 335D.
Also attached is a block diagram from the 335A/D 1/69 manual rev 1 8/71. The 332 is the same but without the null detector. The 335 HV assemblies are A8... and the 332 HV assemblies are A7.... The block diagram doesn't show the 500V supply feed from T1.
According to a note above the editor, there have been 8 new messages added to the tread since I started composing this. I see that today the 332 has decided to work.
