Just had a thought regarding extender cards, which I don't have.
If I use some heat shrink, I could connect wires to the test points, mark them and insulate the ends with heat shrink....
That way, I've extended the test points and should be able to work my way through the troubleshooting on the Power Amplifier section without the use of extender cards.
