Author Topic: Fluke 87V Screen Polishing  (Read 6339 times)
Offline CarsonReidDavisTopic starter
« on: June 24, 2018, 11:48:57 pm »
I snagged a cheap 87V off Ebay. The meter is perfect, except the screen is pretty scratched and scuffed up.
A combination of deep scratches and scuffs mar the screen.
I started using the polish by hand, but it had very little effect. I moved on to a dremel and a polishing wheel. I was careful to keep the screen wet with lubricant and to reapply the polish to the wheel and to the screen.
IMPORTANT! Early on in the process, I pressed the wheel into the screen while there was no lubricant. This left a nasty mark on the screen. My final technique was to hold the dremel by the end and let its own weight apply the pressure.
Here is the finished screen, with all of the scuffs buffed out. Many of the deeper scratches remain. For a full restoration, I think I would need to be more aggressive and sand it with multiple grits before doing the final polish. I believe ModemHead has done this before with success.
« Last Edit: June 24, 2018, 11:51:42 pm by CarsonReidDavis »
Offline joeqsmith
Re: Fluke 87V Screen Polishing
« Reply #1 on: June 25, 2018, 12:16:22 am »
« Reply #2 on: June 25, 2018, 12:59:10 am »
I've polished a few and have had to wet sand some of them.
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/msg1262271/#msg1262271
I read over your posts in that thread, but just to make sure, did you do 1000 then 2000 then polish?
« Last Edit: June 25, 2018, 01:42:01 am by CarsonReidDavis »
Online IanB
« Reply #3 on: June 25, 2018, 01:04:23 am »
I read over your posts in that thread, but just to make sure, did you do 2000 then 1000 then polish?
Isn't 2000 finer than 1000? And what about 4000?
One thing I found very quickly is that plastic is very sensitive to aggressive polishing. Unless you have a super light touch, you can quickly add to the damage rather than reducing it.
« Reply #4 on: June 25, 2018, 01:40:42 am »
Yep. I just don't know how to type.
I have this set https://www.amazon.com/gp/product/B000H6HIK2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It goes from 1,500 to 12,000 I also have some more reasonable grits laying around. Is there something else you would recommend?
Online IanB
« Reply #5 on: June 25, 2018, 02:01:19 am »
My first foray into polishing plastic was not at all successful. Fortunately it was not something that mattered. But since then, I am rather scared to try with anything valuable in case I destroy it. I am trying to figure out where to get something to practice on, made of the same kind of plastic as a typical LCD display, but something disposable.
« Reply #6 on: June 25, 2018, 02:10:43 am »
Just buy a nice little Aneng AN8008 and scratch it up?
Online IanB
« Reply #7 on: June 25, 2018, 02:59:21 am »
Lol. I have one, but it works, and unlike AvE I can't bear to destroy things that work...
Offline GreyWoolfe
  • NW0LF
« Reply #8 on: June 25, 2018, 11:43:06 am »
Sounds like a free Harbor Freight meter is just the ticket.
Offline joeqsmith
« Reply #9 on: June 25, 2018, 11:56:05 am »
It really depends on how deep the scratches have been.   Just sand them using plenty of water.   I have never tried using a dremel for this and would be concerned about damaging the plastic or creating waves in the surface.
Offline vehiculeselectriques
« Reply #10 on: June 25, 2018, 12:53:24 pm »
if it is polycarbonate AND you can dismount it, the easiest though destructive if you are to agressive is cleaning and VERY gently torching it from far away with a gaz torch, never staying at the same place or it will bubble definitely, if done well it will erase ALL scratches and make it clear as glass.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #11 on: June 25, 2018, 01:14:12 pm »
I use 1) fine grit sandpaper then 2) paint polish.
Offline jkf1000
« Reply #12 on: June 26, 2018, 10:09:53 pm »
After wet rubbing I found rubbing with normal whitening toothpaste and then normal household polish works a treat.
Karl
Offline james_s
« Reply #13 on: June 27, 2018, 12:33:44 am »
It's almost certainly polycarbonate, the same stuff CDs are made of. Old CD-Rs or other junk CDs make good practice material.
I typically use Novus plastic polishes but there are other similar products. A Dremel type tool is dangerous, too easy to spin it way too fast and melt the plastic. Something slower like a cordless drill is preferable.
Offline bitseeker
« Reply #14 on: June 27, 2018, 07:12:50 am »
And when you're all done, you can get some smartphone screen protector sheets to preserve your hard work.
Offline Synthtech
« Reply #15 on: June 27, 2018, 08:54:28 am »
There is a product sold on EBay and Amazon called Polywatch and it’s designed for polishing the face of watches such as Rolex Submariners that have the older acrylic face. It is not expensive and it gives a perfect finish. I cleaned up the screen of my Keysight meter with it to an mirror shine. Once you get the deep scratches out Polywatch will do the rest.
Offline pelule
  • What is business? It’s other people’s money
« Reply #16 on: June 27, 2018, 06:35:21 pm »
I used "Novus" to make scratches of my K2000 display unvisible.
Have a look to:
https://www.eevblog.com/forum/repair/keithley-2000-replacerefurbish-display-lens-(pn-2000-304b)/msg863670/#msg863670
/PeLuLe
You will learn something new every single day
Offline stevelup
« Reply #17 on: June 28, 2018, 05:25:21 am »
CDs are good to practice on
Offline 6PTsocket
« Reply #18 on: August 25, 2018, 11:06:19 pm »
If you can get it out, why not replace it with a fresh piece of polycarbonate?
Sent from my SM-G900V using Tapatalk
Offline orin
« Reply #19 on: August 25, 2018, 11:32:48 pm »
If anyone else is looking into polishing up test equipment clear plastic covers - look into the kits available for 'restoring' plastic car headlights.  They are really cheap on amazon and likely less than getting sandpaper and polish separately.
I've used the 3M kit on headlights and it worked well - just mask really well if you are using power tools!
Offline coromonadalix
« Reply #20 on: August 26, 2018, 02:47:53 am »
water sanded meter screens with 1000 after and 2000 and finished with novus scratch repairs and plastic polish almost perfect each time, the masking is important
Offline linux-works
    • netstuff
« Reply #21 on: August 26, 2018, 03:30:18 am »
toothpaste on an old cotton tee shirt.  hand force only, no machines.
