Hello,
Hi!
If you can obtain either the 2CL73 or the BY9208 more easily and quickly, please feel free to use them – their P.I.V. and forward current rating will be quite adequate for use in your Gould oscilloscope!
Chris Williams
Thank you @Chris56000 for your reply.
Regarding diodes D718 and D719, just in case someone needs this info in the future:
BY409 (original)
http://mirror.thelifeofkenneth.com/lib/electronics_archive/MullardTechnicalHandbookBook1Part3Diodes1981_text.pdfQUICK REFERENCE DATA
Working reverse voltage VRW max 11,5 kV
Repetitive peak reverse voltage VRRM max 12,5 kV
Average forward current lF(AV) max 2,5 mA
Junction temperature Tj max 100 °C
Reverse recovery
Recovery charge Qs typ 2,5 nC
Recovery time trr typ 0,4 us
Alternative
BY9208http://pdf.datasheetcatalog.com/datasheet/philips/BY9210.pdfrepetitive peak reverse voltage VRRM1 8 kV
repetitive peak reverse voltage VRRM2 max. 5 seconds 11.2 kV
average forward current IF(AV) averaged over any 20 ms period 5 mA
repetitive peak forward current IFRM 500 mA
reverse recovery time (when switched from IF = 2 mA to IR = 4 mA; measured at IR = 1 mA) <35nS
Alternative
2CL73http://www.hvgtsemi.com/picv_351.htmlRepetitive Peak Reverse Voltage 12kV
Average Forward Current Maximum 5.0 mA
Non-Repetitive Forward Surge Current 500mA
Maximum Reverse Recovery (Time at 25°C; IF=0.5IR; IR=IFAVM; IRR=0.25IR) 100nS
Thank you.
Kind regards,
M
