Hello everyone!
I've just purchased a GW Instek GPS-3030dd Lab DC power supply and here are the specs:
Product Features:
Power: 0 - 90W
Voltage: 0 - 30V
Current: 0 - 3A
Light and Compact Design
Dual LED Display for separate readouts
0.01% High Regulation
Constant Voltage and Constant Current Operation
Series or Parallel Operation Function
Remote Control for External Programming
Internal Select for Continuous or Dynamic Load
Low Ripple and Noise
Overload and Reverse Polarity protection
Available in alternate configurations:
GPS1830D - 0-18V, 0-54W, 0-3A
GPS1850D - 0-18V, 0-90W, 0-5A
GPS3030D - 0-30V, 0-90W, 0-3A
The problem is.. The package didn't arrive very nicely.. the box was dropped I guess and I see that the output knob panel was pushed into the device (not a big deal)
But! when I powered it on, the adjusting AMPS and Voltage didn't work... The amps won't adjust (when it's turned, it'll click and make show the amp and voltage though!) and the voltage stays at 49V. No matter which knob I turn it just stays there.. =( Also, the AMP knobs do the same.
My question is.. Do you think this is a complicated problem? I would like to fix this so that I can save money because the seller has claimed this shipment damaged with their insurance and has refunded me my money back
So, If I can fix this, it'll be a GREAT experience and be worth it too!!
If you had this issue before, please guide me to where I should be looking first! Thanks in advance YOU!
P.S. I couldn't find the schematics for the boards....
-Jason
