Hi everyone. I hope you are enjoying you're Sunday.
A week ago, I purchased 9 Tektronix TDS scopes from a local business that closed their doors (for a nice price). Two of the scopes are working well based on me running the self-test and SPC. I also measured and checked some waveforms using my BK Precision 4011 5MHz FG. One is a TDS784A, and the other is a TDS644B. I have placed those to the side until I have learned what further tests I can do in order to make sure they are working properly.
I am currently working on a TDS744A with intermittent SPC failures, but here is what I have left to work on:
2x TDS744A - One scope would not boot when I first received it. I took the case off of it and started poking around. With further examination, I noticed that the J2 ribbon cable that connects to the A11 Processor/Display board was unplug. I plugged it up, and booted the scope again. This time it came on, but only lite up all the front panel LEDS. A few seconds later, I smelled a weird smell which had somewhat of a grapefruit odor to it (that's my best description. It was not a familiar electronics problematic smell, but please keep in mind I am new to scope repair, but not electronics repair in general). Maybe it was from bad caps.
The other 744A just has SPC issues (intermittent Pass and Fail when SPC is run). It passes start up self test. I have decided to use the non booting 744A as a parts mule. I am currently checking the relays* from the hybrid Attenuators on the non booter to see if they are okay and I can switch them out to the working scope with SPC issues.
1x TDS724A - Consistently fails SPC test - Passes Start up self test.
1x TDS694C - I started a thread about this one. The trigger chips seems to be the issue but I'm not
sure how to test if they are bad or not. Any suggestions would be greatly appreciated. I have yet to look at the chips under the microscope for a more detailed visual inspection, but I have eyeballed them and didn't see anything (Thanks to @Jwalling for his input on the other thread about this unit). I do know for certain that there is an overheating issue because it has shut down once. After I put an external fan on it, it stayed on (very hot that day). Since then, it hasn't shut off again after initial boot, however it still radiates a ton of heat by the trigger ASICs under the casing.
1x TDS684C - Powers on, All LEDs light, but doesn't boot. It just sits with the LED on (I already checked the write-protect switch position)
1x TDS544A - Powers on, All LEDs light, but doesn't boot. Caps need replacing. I've examined the board under my microscope.
1x TDS7154B - Came with no hard drive. I haven't a clue as to how I should address this, but I have a few HDDs from laptops but I'm not sure how this would work. I am very partial to this scope and this is the only one I plan on keeping for myself. I will work on it once I am done with the others.
Pardon the long winded post. I just want to make sure I have given enough information so you guys can understand what I'm dealing with. Right now, I want to know the best way to test the hybrid attenuators and the relays. I have been applying voltage across pins 1 and 6 on the DS1E-M-DC12V until I hear them click (right at around 6.3-6.6V .02a) and slowly go to 12V and the current increases. I then take a test light and check pin 12 to see if my test light lights up. I also checked for resistance across pins 1 and 6 (inductor) and they are within spec (360? +- 10%). I have yet to test the TN2E. So far, for the one I have check, 3 of the 4 are bad. My question here is, am I checking them correctly? Does anyone have a better test method other than the DMM and power supply method I am using? I would be most grateful for guidance.
Lastly, I would like to know what boards are interchangeable. I've been told that the 744A are which is what I am working on now and attempting to do (thanks @eKretz), but I wanted to test the A11 board from the donor to make sure all was well before I go through the trouble of reassembling only to find out that I have the same issues with the transplant board.
I know I have a tall task ahead of my but I'm up to it and I really want to get good with repairing scopes. Any advice or suggestions would be greatly appreciated. Thanks everyone.
