Hello everyone
So here's the problem,
On the ouput of my Hifi audio system, i hear a High frequency noise
I've tried to use an oscilloscope but it turns out the only noise I see is around 25kHz, which surprises me because i didn't thought i could be able to here above 20kHz .
Whenever i change the audio input (Line, DLNA, Airplay or USB) I still get the noise.
The case is made of metal and when I mesured with my multimeter, i got some voltage but even when i grounded the case, the noise was still there. :/
Also when i turn the volume all the way down to mute it, the noise disappear
The model is the following : Sharp XL-HF401PH
I've bought it around 2 years ago and the noise appeard few months ago but it's only now that i am trying to repair it
Any ideas ?
I'll try to make some inside pictures tomorrow
