Hi again,
Unless you've checked the values of the various resistors around IC320 with at least one end disconnected from the pub, I'd not worry too much about the lower readings. As suggested, clean the pot wipers gently if you can, then insert a new CA082E into IC320 and see what happens!
Regards, Sarah
