I managed to find this link to the service manual. It's pretty dense from the looks of it.
Will a heavy duty multimeter do for measuring voltages of that range?
It's a great manual, just what they used to do in the day.
You've got a bit of reading to do and I'd recommend you print any pages needed re storage function or you'll go nuts skipping back and forth through the manual.
At a glance only 120 V is used for storage and erase functions.
You might not even have to check that part, there are plenty of listed LV test points in the schematic.
But as is always best with repairs check the PSU is to spec first.
Ripple for a linear PSU (50/60 Hz) can be checked with a DMM on AC mV.
Don't forget it might be something real simple.....even the push button switch.
Just work you way bit by bit, you'll get there.
Take notes and post your findings.
