Hello rf-loop,
After your hint, I could search on the web about the problem of dead battery on a DS1220, and I decided to try
to fix the HP54601.
The first thing was to desolder the DS1220 (which is not that easy) and to install in place a socket for
future use.
Then I order a new DS1220, but as was impatient to see if that was the right problem, I tried to change the battery
on the DS1220 following some indications which appear in several places on the web, as
http://www.vk2hmc.net/blog/?p=245I use my proxxon drill to dig into the epoxy from the bottom, and manage to remove the battery.
Then I soldered two wires on the ground and + former connections of the battery (see photo).
I glued a CR2032 holder on the top of the DS1220, and put
it back in the socket.
Bingo, it works !
Maybe the calibration is lost, and I will have to do it. This is a nice fix. I would not have known how to start
without your very helpful comment, rf-loop. Thanks again.
