Author Topic: HP 608C Repair.  (Read 22152 times)
Offline neoTopic starter
  • The specialist.
Re: HP 608C Repair.
« Reply #150 on: March 17, 2018, 10:55:44 pm »
Sorry if i seemed to have abandoned this project, i just needed a break to sit and think. I got an idea and so i'm back at it, i fed 13 MHZ into the attenuator and it attenuated. Meaning that it just refuses to pick up the oscillation, i'm beginning to doubt my ability  to resurrect this boat anchor  :-//
Offline Cyberdragon
Re: HP 608C Repair.
« Reply #151 on: March 18, 2018, 02:28:39 am »
Is L17 blown?
*BZZZZZZAAAAAP*
Voltamort strikes again!
  • The specialist.
Re: HP 608C Repair.
« Reply #152 on: March 18, 2018, 03:16:54 am »
Is L17 blown?
As far as i can test it, no.
Offline Cyberdragon
Re: HP 608C Repair.
« Reply #153 on: March 18, 2018, 05:18:40 am »
Where did you feed the attenuator input when you saw it work?
Also did you check the wire continuity?
*BZZZZZZAAAAAP*
  • The specialist.
Re: HP 608C Repair.
« Reply #154 on: March 18, 2018, 05:22:23 am »
I probed this point here and got the dialed in frequency.
Offline Cyberdragon
Re: HP 608C Repair.
« Reply #155 on: March 18, 2018, 10:20:02 pm »
Doesn't matter.
Did you check the wire that connects L17 to the attenuator for continuity?
*BZZZZZZAAAAAP*
  • The specialist.
Re: HP 608C Repair.
« Reply #156 on: March 18, 2018, 10:51:46 pm »
Continuity across the inductor but i'm not getting a connection to the tines.
EDIT; there is continuity to the tines.
« Last Edit: March 18, 2018, 11:04:03 pm by neo »
  • The specialist.
Re: HP 608C Repair.
« Reply #157 on: March 18, 2018, 11:21:58 pm »
The thing just sprung to life, it seems all i needed to do to fix it was rule out every possible motive except for old and cranky.  :-DD
Offline Cyberdragon
Re: HP 608C Repair.
« Reply #158 on: March 18, 2018, 11:46:30 pm »
Exactly as I suspected, bad wire or solder joint. You poked it and restored continuity.
Jiggle it a little bit, the bad connection is still there.
*BZZZZZZAAAAAP*
  • The specialist.
Re: HP 608C Repair.
« Reply #159 on: March 19, 2018, 12:14:39 am »
I've jiggled the coaxial every which way and taken a good long look at the joint on the attenuator probe, all kosher. Then i tweaked the single wind inductor on the thing and it sprung to life, reattached it the sliding mechanism it and it still works.
« Last Edit: March 19, 2018, 12:20:58 am by neo »
Re: HP 608C Repair.
« Reply #160 on: March 19, 2018, 01:08:55 am »
Excellent news, so you now have a working unit.
From mobile device so predictive text might have struck again [emoji83]
  • The specialist.
Re: HP 608C Repair.
« Reply #161 on: March 19, 2018, 02:41:46 am »
Mostly anyway, the percent modulation meter is still screwy but i'm not sure i want to dig into THAT without a tube tester. Time will tell how well it is fixed, i suppose.
« Last Edit: March 19, 2018, 02:44:46 am by neo »
  • The specialist.
Re: HP 608C Repair.
« Reply #162 on: March 19, 2018, 06:13:50 am »
Having knocked it around plenty getting it back in the case and onto it's shelf i think it'll keep working. With how much i moved it for it to still work eliminates a short, almost definitely. Fingers crossed.
