Hi ladies and gentlemen,
my venerable 6P seems to have had enough. I've been looking to replace it with a newer Epson AL-M200 for a while now, as with every once in a while it would spit out a blank page with %12345 at the top (I chalked it up to the chinese Centronics/USB converter) but now it started to 'ghost' the prints. I opened up a NOS (yeah, they are around) 03A cartridge and replaced the whole toner/drum assy, but it is still doing it.
Made two prints, the first one is the self-diag page, you can see the old demo page from the prev. print on it. Then I did a half-print, because I suspected the fuser unit, but the ghosting is happening at the drum.
Pulled the PSU, completely shooting in the dark I replaced the two caps on the low voltage rails (the smaller one had bad ESR), checked the triac that controls the fuser (okay), and the little HV panel (all diodes are okay). No change. At least I didn't make it worse.
So... I suspect the HV supply died that's supposed to clean the drum after it rolls the toner over the paper?
Time for that EPSON or does anyone know a way to fix this?
