Author Topic: ITT Shadow NE18T70  (Read 1345 times)
Offline kelchmTopic starter
ITT Shadow NE18T70
« on: February 08, 2018, 03:15:43 pm »
Does anyone know if there is a 'modern' equivalent of the ITT Shadow NE18T70 part? This seems to be a common power switch in HP and other test gear from ~20-30 years ago.
So far I've only managed to find very overpriced ($30 each) ones that ship from China or crusty looking NOS that looks like they sat on a shelf in 95% humidity for three decades.
Re: ITT Shadow NE18T70
« Reply #1 on: February 09, 2018, 04:52:25 pm »
Just to follow up on this it looks like the C&K NE182UEE6AMP is a good match and is readily avilable from both Digi-Key and Mouser.
I'll confirm once I receive the switch and verify the metal bracket from the old switch is able to be swaped over.
Offline MouradR
« Reply #2 on: August 11, 2018, 03:02:58 am »
Hi Kelchm,
I have the same issue that I am looking for this main switch. If you received the C&K version could you please confirm that it is a perfect match and the metal bracket can be swapped over?
https://au.mouser.com/ProductDetail/CK/NE182UEE6AMP?qs=u2NJ%252b70r0gq%2F3TOHxPM8mA%3D%3D
Cheers,
MR
Online coromonadalix
« Reply #3 on: August 11, 2018, 09:55:11 am »
i think its a good substitue minus the metal screws holder, you can remove it by slowly unbending the 4 small pins, and slide it away from the switch
