did some further investigations.
After opening the case and inspecting the components i did not find any burn marks or visual damaged parts :-(
If i power up the unit in mega ohms mode with open circuit it starts at 15 mega ohm and clim up till arround 20 mega ohms...
shorting the terminals result in arround 2 ohms Looks like Switch range and Auto ranging is working.
i read about troubleshooting mode in the manual but i can not anderstand it fully. Entering troublshooting works fin but what should i check?
