hi all,
Bought a Fluke 87v recently advertised as "As new". It is like new on the outside and inside but the current range is dead.
I've checked everything in the path and everything checks out all the way to U1, I'm suspecting this one is broken.
When measuring current the indication jumps when there is a transient on the input, at steady input it slowly goes down to 0.04mA(or something like that, completely de-attached from reality).
My thinking is that it have been overloaded on the amps input and that U1 is broken to the point that there is only capacitive connection between the input pin and the internal circuitry, hence the jumps when the input changes.
Anyone had this problem or have further ideas?
