I worked for a company which made ECUs for NACCO, although not the model that you show in your photos.
What another commenter mentioned is true, the main processor will be either a FPGA or a automotive processor. Unobtainium.
Having said this, the vast majority of the field failures were almost always related to the power drivers, which appears to be the 20 pin power-packs, of which your module has several.
Your photo is unfortunately of extremely poor quality, and neither the part number nor manufacturer can be read. Most likely are made by STMicro or Infineon.
